Topic: foo_infospect (Read 25058 times) previous topic - next topic
  • foosion
  • Moderator
foo_infospect
Infospect is a UI Element that displays low-level playback information for the currently playing track.
The "Source" dropdown list selects the level of information to display. The available levels and their meaning are as follows:
  • Static: Displays information that is available at all times, even when the track is not playing.
  • Dynamic (track): Displays dynamic information that changes on track change. Online radio streams and special input formats can have track changes while still playing the same URL.
  • Dynamic (full): Displays dynamic information that may change at any time. This includes the dynamic bit rate for formats that report it.
Known issues
  • The Infospect element does not obey the font and color settings in the Default UI. Very low priority since this is intended only as a tool for developers and for troubleshooting.
foo_infospect
hey! the date of the infospect component in your webpage seems to be switched with the date of the screen saver host component.
  • foosion
  • Moderator
foo_infospect
No, the dates are correct.
  • Fandango
foo_infospect
It misses a COPY text feature...
PS: you probably know that the GUI becomes extremely unresponsive in full mode... but I just want to warn people about it here.
  • Last Edit: 05 August, 2008, 11:55:02 AM by Fandango
  • foosion
  • Moderator
foo_infospect
Not here. Does it happen with all audio formats/files for you?
