Topic: Vinyl vs Digital and 24 bit vs 16 bit from vinyl. (Read 210271 times) previous topic - next topic
Reply #150
Not quite. I'm not necessarily comparing the same product in different formats but you're quite right that I'm saying it's not as straightforward as digital = good, analogue = bad/inferior
No, the distinction is more nuanced than that. Some listeners might not be able to distinguish the two. This is not to say that the noise floor of vinyl/fm/analog/whatever cannot be measured and compared to the noise floor of digital. However, "digital" is broad. Are we talking 8-bit/11kHz? 32-bit/192kHz?
The characteristics of digital can also be measured, and the upper-end of digital is vastly in excess both of the frequencies we can hear as humans and the noise floor we can reproduce as scientists recording signals. It is yet unclear whether or not CD audio is distinguishable from digital formats with superior properties. On the other hand, I've yet to hear a consumer analog source that I could not hear the analog distortion on.
I've yet to see the truth of the assertion that vinyl is indistinguishable from CD properly evaluated, but I admit that such a claim sounds like nonsense given my personal experiences with vinyl. The properties of FM radio and other analog sources are quantifiably inferior to vinyl so I'm not even going to bother going there.
Reply #151
Then you are very confused about what you are comparing and how to compare things in general. And as long as you keep mixing up medium and message, and avoid using reliable references, you are pretty much guaranteed to remain confused.
All other things being equal, and relating to recorded audio media performance, digital = practically perfect, and analog = something that is audibly less than perfect.
Reply #152
High speed open reel tape inferior to vinyl? I think not
I disagree. I think it's perfectly reasonable to compare say a live BBC broadcast of a string quartet with a "loudness wars" CD and make qualitative judgements about the relative sound quality of the two.
Reply #153
1) Why do you assume that Canar said all other analog sources are inferior to vinyl when this is not what he said?
2) Regarding your response to Arnold, what part of "All other things being equal" don't you understand?
Reply #154
While I respect the comment you are making here (I was not anally-retentive enough to add a couple words to prevent this kind of nonsense), your behaviour is that of a troll. I see very little evidence to the contrary here. You are cherry-picking the claims you dislike and ignoring completely the thrust of the arguments being made.
Reply #155
Apologies. I reacted a bit quickly as I felt that I was being ganged-up on a bit. I'm definitely not trolling. And I'm not ignoring counter arguments. From where I sit it seems that people are ignoring what I'm suggesting and simply reiterating the same statements about digital's superiority, which I have not at any stage disagreed with
1) I've apologised to Canar for reacting a bit hastily
2) I simply disagree that all other things have to be equal in order to make valid judgements about relative sound quality
Reply #156
I'm not exactly sure if that was ever meant, but FWIW, I recall a JAES paper that explicitly stated that lacquer masters beat 15ips on noise and distortion. Granted, that was before Dolby, but that was also before DMM too.
I've heard tape hiss on several records.
Reply #157
From where I sit it seems that people are ignoring what I'm suggesting and simply reiterating the same statements about digital's superiority, which I have not at any stage disagreed with.
So then digital is superior and you're making no claims to the contrary? Would you mind succinctly recapitulating what exactly you're trying to discuss here? This is going around in circles. There is no faith needed to place trust in digital recordings. The scientific measurements speak for themselves.
Reply #158
It *is* perfectly reasonable to compare a live BBC broadcast of a string quartet with a "loudness wars" CD and make qualitative judgements about the relative sound quality of the two, as they are two different representations of the same performance.
But, it is downright simple-minded to attribute your opinion of  "loudness war" CD solely to the fact that it is a CD, and ignore the fact that the differences in production steps such as mastering explain the difference.
Reply #159
...not to mention that the CD is not the only chosen format to deliver hyper-compressed audio:
http://www.hydrogenaudio.org/forums/index....showtopic=66401
Reply #160
I think you need to cite that article.  There may have been a point in history where lacquers beat 15 ips 2 track, but 15 ips 2 track was more of a moving target.
Besides, if you play the lacquer a few times, it would degrade. The 15 ips tape was more consistent.
So have I, or so it seemed.
But without hearing the master tape, that would not be known for sure.
Disc mastering chains can have a good number of signal processors in them, and they can do all sorts of things. For example, if there is a compressor in the mastering chain, it has the effect of reducing the dynamic range of the source. Or if you will, it can bring up the noise floor of just about anything.
In the end, this is just a data point that means nothing without more information about the context.
Agreed.
The two plots provide evidence that the hypercompression was in procesing that was common to both.
Furthermore the lower plot shows that the LP had excess low frequency phase shift, which is no big surprise.
Reply #161
I agree it's going round in circles so I'll say no more after this. Here's what I actually said :
"People tend just take one side or the other. I have investigated and to my ears digital is sometimes superior. Vinyl is sometimes superior. Sometimes FM radio is superior to both. It's all in the care taken over recording, mastering and manufacturing in my opinion"
and
"I was simply pointing out that while in my opinion the superiority of digital is not always audible there are some members of this forum who are guilty of the same prejudice they scorn analogue-lovers for....."
The 1st statement doesn't look partricularly contentious to me so I guess it's the 2nd one that's upset some people
Reply #162
Of course it does, because the simplicity of logic in determining that, comparing mediums, digital CD format is superior to vinyl, is crystal clear for those 'some people'.
If a CD recording can sound worse than that of the same song on a vinyl record, then it can be stated for sure (not even an assumption, but a certainty) that something went wrong with the recording/mastering/processing-whatever before the CD was pressed, and not because of any limitations of the digital CD format that can add noise or distortion.
Vinyl sounds better, more warm, less 'grating', because of added distortion. Pleasing, yes, but it will be too much of a stretch to implicitly equate 'added distortion' with 'superior' when accurate audio reproduction is the goal of music-lovers (or so I think).
Reply #163
Yes, this is understood, but no matter how good the master behind the keyboard, a toy piano still has it limits no matter how much you have grown to like the sound.
Paul
"Reality is merely an illusion, albeit a very persistent one." Albert Einstein
Reply #165
I personally feel that 16 to 24 bit is a small, but noticeable step up. I have a soundcard which lets me change the bit depth while music is playing. I have played around with it and I would say that it was about as noticeable as going from 720p to 1080p on a 35 inch tv. Few would notice. But at close glance, you can see the extra detail. But when you go from 44.1k to 48k BIG difference. Most noticeable when a quiet passage is played at a high volume. CD's suffer a digital hiss, which are basically the steps in between samples. DVDs sound clearer than cd's to me because of these extra "steps." More steps in the same amount of space = smaller step. But the sound is of a lower quality than a cd, if that even makes sense. I am not very good at expressing my thoughts through words sometimes :'(. And I was joking about the lower.
Here is my stance. I am a guy who still buys records and loves to flac em 96k times a second with 24 bits in them samples.  You could have the normal 1(16 bit) lock on your doorknob. But I have a deadbolt, locking knob, and a chain.(24 bit) And instead of a wooden or plastic (44.1 khtz)door,  I have a steel door.
Am I actually safer(sound better) than you just because of that, maybe. But I definitely feel safer.
Was that too dumb
I realize that I am responding to an old post. But I just got here
Digital audio, properly implemented, is not stepwise. Properly dithered, 16-bit digital audio can have a dynamic range of nearly 115 dB -- even greater than the 96 dB implied by 2^16. For produced, pre-recorded sources, it is more than enough for any human listener. The dither completely removes the stepwise nature of digital audio, and provides a noise floor that is identical to analog.
24-bit audio actually challenges modern electronic technology, which is really only capable of about 22-bits of precision before thermocouple effects and other noise sources kick in. 24-bits is more useful in production studios, where you don't know in advance how loud a live performance will get, and the level build-up that occurs when you sum channels together. 24-bits are for the headroom, not the precision.
That is not to say that you might not hear differences between the two, but it is more likely to be due to secondary effects, such as how well the ADC, DACs, and dither are implemented, and perhaps even more significantly, output level shifts when you switch between 16 and 24 bits. Loudness differences affect subjective quality in listening tests, which is why A/B/X tests are always carefully level matched.
Some computer sound cards and computer multimedia applications do not bother to preserve dither throughout the audio processing chain, which can result in raw, undithered 16-bit sound. Switching to 24 bits may mitigate (or change in some way) some of the processing deficiencies.
Reply #166
An oversimplifictaion for those without a physics degree. lol Having spent my formative years in the 70's, I love vinyl! With high end gear vinyl is awsome. However, I can now decipher lyrics on CD that were masked by muddiness on vinyl. There is obviously more information being read by the laser than the needle. Also, vinyl requires $$$ as an inexpensive table and cartridge sound terrible, not to mention the need for a phono preamp. Hmm, my $100-$400 cd players or my $5000 turntable/cartridge/preamp? Bang for the dollar is certainly with CD!
Reply #167
Hey everyone. My inaugural post.
I have been fascinated by this discussion from the recording artist's perspective. I am working on a major art rock musical and was contemplating releasing it on vinyl as well as CD/mp3. I was wondering if having the lacquer cutting people use 24 bit files rather than 16 bit would yield a better product. Now I'm not so sure it would matter. Still, I love the look and experience of vinyl, with that great canvas for artwork!
With regard to audio perceptions of bit depth, I would have to say that from my own personal experience there is a WORLD of difference between 16 and 24 bit--but only at extremely low levels. If you listen to the same program material recorded with the same field equipment at either bit depth, during extremely low levels (stuff barely above the noise floor) the 16 bit will sound like a low-res digital answering machine, while the 24 bit will still sound decent, comparatively speaking. Both will sound much worse than higher level program information. I remember hearing the difference between 16 and 20 bit ADATs in the 90's when I worked in the music retail industry. There was a real difference.
Having said that, for regular program material they are utterly indistinguishable for 99.999% of the population, so I don't want to oversell the difference. From an artist's perspective, however, 24 bit is nice because it offers a much lower potential noise floor and more headroom prior to clipping. This really helps keep things clean at mixdown. Once the final mix is finished, the whole thing is going to be compressed for the intended medium anyway, so headroom is far less important an issue. 44.1/16 bit is fine--in fact, most people are going to bit-crush the music into their iPods anyway. FM radio will have a field day with recorded mixes, compressing them radically. So 24 bit is almost totally worthless, except for the hard-core audiophile market.
I am in more of an internal debate with regard to sample rate than bit depth. If humans can really only hear to about 20k, why wouldn't 44.1k be sufficient? Yet lots of people swear that 96k and even 192k recordings are better. Better for whom? Unless you are a dog or a bat, and listening on scientific audio lab equipment that can actually recreate 48k or 96k audio signals, the point just has to be moot. A set of iPod headphones are certainly one hell of a hi-pass/low-pass filter combo!
If someone can sell me on the ultra-high harmonic content argument, I'm all ears. Unfortunately, none of my mics can record it, peaking out at around 20k typically, so even if those harmonics are there, I'm effectively prevented from benefitting from them.
Back to the original point of this thread. Until I read all of this, I, too, was under the impression that some sort of analog "magic" was occurring with LPs that digital could not accurately replicate. While the math might be questionable, the first post was a fascinating one--that 24 bit might have more resolution than an LP could physically compete with on the atomic level! Funny.
There may be some "euphonic" enhancements that are occurring with LPs, not to mention the visual/tactile accompanying experiences and the huge nostalgia factor, but after reading your discussions I now doubt it is anything more than that. I was wondering why the vinyl replication houses all want 44.1/16 bit sound files and not anything more hi-res. Now I know.
Bart
Reply #168
By most accounts, vinyl is equivalent to 12-13 bits, and maybe 32-40 KHz sampling. This ignores some other built-in problems with vinyl.
I don't know that many people are doing much in the way of recovering their investment in vinyl productions these days.
Well, as perceptions anything goes, but as far as scientific audiblity goes, lots of people have looked for reliable proof of the audible benefits of 24 bits, but they all come up empty.
You'll find a lot of emphasis on HA for reliable listening tests - look at TOS 8 and many of the sticky threads. You've probably never done a truely reliable listening test. Few people in general have, but there is a lot of activity like that  around here.
Been there, done that and you are simply not well-informed. I've done that comparison dozens of times, as have a number of others around here, and once you control all of the relevant variables, it is a very tough comparison to get any traction on. I'm hardly alone in this, there is a well-known test like this that was published in the JAES in the past year.
When people say the difference is obvious, they're tacitly admitting that the alleged listening test they did was not good.
Now you're talking anecdotes, not science. An ADAT is a complex machine with many relevant variables besides just the bit depth of the converters. In the early 1990s, converter quality and pricel/performance were nothing like they are today. Doing proper comparisons between players and recorders is non-trivial. The really nasty part is geting two digital players to synch within a few milliseconds and keeping them that way. If you don't you can identify them by swithching back and forth and noticing the switch-over. Leading switching to lagging sounds different than lagging switching to leading when the synchoronization is off by even as little as a dozen milliseoncs or two.
Nope, its a problem of 16 and 24 bits being difficult or impossible for *everybody* to distinguish, even well-known and very successful recording engineers like Katz and Massenberg.
I do a ton of live recording - I've recorded over a thousand choirs and maybe 400 or 600 bands and orchestras in the past 4 years. One of  my irritating little sayings is that "If you can't set levels and headroom within 20 dB, you shouldn't be passing yourself off as a professional recording engineer."  The bottom line is that there are very few recordings with more than about 70 dB dynamic range, which still leaves you with 24 or more dB headroom with 16 bits.
Multitrack mixdowns can have more variation in dynamic range because of the range of possible numbers of tracks. I mix from 2 to 22 tracks for live recording, and up to 36 independent sources for live sound. I can see the advantages of mixing at 24 bits or even 32 bit floating point.  The good news is that I have a 24 bit digital console (02R96) and 32 bit floating DAW software.
I would say that 95% or more of the work I do never sees any adjustment of dynamic range other than normal mixing and gain riding. I have over 50 channels of compression at my disposal and simply never see the need for it.
IPODs and their many competitors are often just fine. Many are effective competitors or replacements for even the finest CD players.  Most will play non-lossy compressed files, either AIFF, WAV, or FLAC and the like.
Reply #169
Why answer so hard-edged to hist first post? The stated difference isn't even wrong. When you just turn up the volume high enough, low-volume passages are very easily ABXable between 16 and 24 bit. The only problem would be that this chosen volume level would result in turbofan jet engine sound pressure levels for the louder parts of the same record. The difference between 24 and 16 must be analyzed at non pathological volume levels, that don't hurt your ears at full amplitude, and there 24 and 16 bit are indeed indistinguishable as all serious testing has shown.
Reply #170
This is a gross oversimplification of lossy compression.  Maybe it was intentional, I don't know.
You do realize that mp3 coefficients are floating point and that the format is actually capable of delivering greater dynamic range than 16-bit LPCM, right?
Reply #171
Why bother taking us for a stroll down excluded-middle lane? If I turn up the volume on a 24 bit recording, I can show that a 36 bit recording would be even better!
The difference between 24 and 16 bit *cannot* be found if you consider an entire real-world recording, and restrict yourself to real-world music-lover listening contexts.  The noise floor of even the better recordings around is 10-25 dB above the 16 bit noise floor. The noise floor of a typical listening room is at least 35 dB SPL, which puts peak levels at an ear-shattering 131 dB.
If you got a story to tell, please make sure it conforms to TOS8 and involves real world recordings played in real-world spaces.
Reply #172
Yikes! people here are pretty testy.
I thought I qualified my assertion with regard to hearing the difference between bit depth samples, but evidently not well enough. In the demo I heard, yes, we ridiculously cranked up a very, very soft passage, far beyond "real world" normal listening. IIRC, it was an ambient reverb tail on a sustaining grand piano. To be fair, this was a sales demo and wasn't done in a lab. If super-cranking 24 bit could prove 32 bit better, and if that's the comparison you want to make to my "anecdote", then fine--it's all pointless. In the "real world" people can't hear the difference between 24 and 16 bit recordings, all other things being equal. Not 99.999% as I suggested in my initial post. 100%. Will that suffice? As far as synching ADATs is concerned, we didn't really worry about it. We played the cuts sequentially, not simultaneously. Having said that, if we wanted to A/B them simultaneously the BRC we would have been using back then could have sync'ed them to within sample (1/48,000 of a second). Close enough?
So you seem to have an abrasive way of agreeing with me when I stated that it really didn't make much of a difference. Or you have a pretty low tolerance threshold for the opinions and reflections of new posters who haven't read every JAES blurb or scanned the previous 500 threads on these topics.
Also, to be honest, no, I didn't really consider the fact that mp3s could actually be better than a standard 44.1/16 bit CD. I'm a musician, not an engineer. I was referring to how 99% of the listening public tend to use mp3 players--with lossy compressed versions of their favorite songs. Artists worry about these things.
Evidently I haven't been sufficiently indoctrinated enough to offer a post here not worth shredding over minutiae.
Reply #173
...no more indoctrinated than learning that 2+2=4.
I recognize that you've qualified your ability to distinguish 16 bit from 24 through a massive volume increase.
To stir the pot regarding the ability to distinguish audibility between 16-bit and 24-bit, allow me to point to this discussion:
http://www.hydrogenaudio.org/forums/index....st&p=610558
Considering that this thread is about vinyl and that it's already well established that 16/44 is more than adequate for delivering vinyl transparently, I think this other discussion would be a better place to take the general discussion about 16-bit vs. 24-bit.
Reply #174
They shouldn't. Engineers and technologists should worry about lossy compression. Artists need only concern themselves with making good music (and, secondarily, making money...if they choose)
