Topic: What is the best Ogg settings for Portable Player? (Read 15281 times) previous topic - next topic
  • shaohao
What is the recommended Ogg encoder setting for portable player?
I used to set "-V4 --vbr-new " for MP3 format. Now, I want to switch to Ogg to get a better Sound quality.
Can anyone give me a hint?
  • Last Edit: 29 February, 2008, 06:04:43 AM by shaohao
I've found -q 3 (using aoTuVb5) to be perfect for my iAudio X5; this will give each song an average bitrate of 112kbps.
Music washes away from the soul the dust of everyday life.
  • Nicos
I think -q4 with aotuv will be very satisfactory. Even -q3 could be ok if you want to save more space
  • shadowking
Q5 ~ 160 k might be a bit better and Q4 might be be close to V4. In 128 k tests lame V5 was competitive with vorbis Q4. Unfortunately you are not gonna get much better than V4 because that is already pushing many peoples ears to the limit  and it is known to be better than V5.
  • Last Edit: 29 February, 2008, 08:28:05 AM by shadowking
wavpack 4.80 -b5x4
  • S-12
I use the Ogg Vorbis Lancer build at -q4 on my WM5 phone, although I'd recommend as low as -q3 to fit more songs into the same space.  No one I've ever known has ever been able to differentiate Vorbis -q3 from a lossless reference.  If in doubt, try ABXing some -q3-encoded tracks yourself - after all your ears are the ones that count the most for the quality of music on your portable player.
This was my experience, hence my settling on q -3. I must admit, it took a while to get used to listening to music at such a low bitrate that sounded so good.
  • m_l
I use -q 4, I'm very happy with that setting
  • MoonWolf
I use Q5.0 for desktop & portable players.
Then, dissatisfaction is not in tone quality.
  • shaohao
Q4 or Q5.
THX everyone^_^,
  • HydroFred
I use q1 for portable use.
  • slks
It depends on how much space you have, and how much music you're trying to fit on it.
If space isn't much of an issue -q 4 should be more than enough, but if it's a small player you can probably go down to -q 2 or -q 1 without things getting ugly.
  • lex_nasa
If you've got a really resolving MP3 player and good IEMs, you're going to hear Q4 and below quite clearly.  I'm  happy with Q5 95% of the time using Beosound 6 (yes I know, don't start, please listen to it before you judge me) and Sensaphonic Prophonic IVs.
  • OggY68
I use q3 for my Cowon D2, encoded with the latest aotuv.  Completely transparent for me ...
  • HotshotGG
I would use somewhere just between -q 5/6, which is dependent upon size of the portable. Most HD players are least 20 or 30 GB. That might be considered "ideal".
budding I.T professional
  • pepoluan
It all depends on:
1. Quality of the player
2. Quality of your earphones
3. Environment in which you will be listening
For example, my situation:
1. Quality of the player: Good enough (PocketOgg running on Windows Mobile on an iPaq 2210 (yes I know it's old, but it's still serviceable))
2. Quality of the earphones: Good enough (TDK in-ear plugs. Too much bass, but acceptable for my environ)
3. Environment in which I listen: Public Bus (with nearly no sound-deadening material between engine bay and passenger space)
For my needs, I find -q 1.0 and even (sometimes) -q 0.0 quite acceptable.
So, I suggest anyone trying to find the best setting to:
- Use the latest & greatest aoTuV
- Encode 3~5 fave tracks at -q 3, -q 2, -q 1 and -q 0
- LISTEN
BTW, does anyone notice that OP's post is actually a 1-year-old post?
Nobody is Perfect.
I am Nobody.
http://pandu.poluan.info
