Topic: MP1 and MP2 files needed (Read 6503 times) previous topic - next topic
  • Ravi
Hi All,
    Anybody is having any MP1 or MP2 files. Or anyone has any MP3 to MP2 and MP1 converter. I need it .
-R/\\/I-
  • 2Bdecided
  • Developer
mp2: http://sourceforge.net/project/showfiles.php?group_id=19022
mp1: There is at least one old buggy encoder (which also does layers II and III, very badly) based on the ISO reference code, but I can't remember the name.
  • Synthetic Soul
  • Global Moderator
wav2mp will do MPEG-1 Layer I and II.
http://home.cogeco.ca/~avi2vcd/
I'm on a horse.
  • menno
  • Developer (Donating)
The only reliable source for such files are the MPEG reference files (available from the same server as the MPEG-4 reference files, links can probably be found on this website somewhere). Tools like Wav2mp and scmpx have problems with either layer 1 or layer 2, don't remember which one has problems with which. Also the reference files cover a much broader range of bitstream possibilities than most encoders ever will.
  • Antonski
Just out of curiosity, is there an appropriate tag format for such files?
  • menno
The "container" is the same as for MP3, so whatever you use there you can use on MP1/MP2.
  • Antonski
Thank you, Menno for the prompt reply.
  • DualIP
http://netsell.com/dahb-music/mpeg/ampeg43.zip
It's an old MS-DOS based program, encoding Layer 1 & 2.
When using proper psycho-acoustic model, audio quality was very good for L2 files (192...256kb/s)
Back in 1996 I ran many nightly encoding jobs with it
  • Ravi
Thanks to you all for help
Regards
-R/\\/I-
I needed to transcode audio to .mp1 (MPEG-1 Layer 1) too, and I was able to do so by using wav2mp.  Thank you!
At first I was confused because the output of wav2mp is only .mp2 but the containers can be interchanged (rename to .mp1), and I verified the audio properties with MediaInfo.
  • Last Edit: 18 August, 2011, 10:31:15 AM by db1989
