Topic: Removing Visualisation from new foobar? (Read 4878 times) previous topic - next topic
  • Bangers
The new foobar with the new UI and ability to quickly color/customize it is great!  Even better for recommending it to friends who are in a similar position to me (quick, simply mp3 player).
Quick question, with the Preset "Visualization + Cover Art + Tabs" Quick Setup.  How  do I remove the Visualization at the bottom?
I just want to extend the Play list down more.  I want to keep the left panels the same.
  • Demetris
1. Enable Layout Editing Mode (from View -> Layout)
2. Right-click on the Playlist and Copy UI Element
3. Right-click on the splitter below and Paste UI Element
In other words, you copy Playlist View, you select the area you want it to cover (by clicking on the splitter between the Playlist View and Customisation Visualisation), and then you paste it over this area.
  • Last Edit: 19 February, 2008, 10:21:59 AM by Demetris
  • Bangers
all that's done is display another Album View under the existing one.  I want to remove that Panel completely.
I tried "Cut UI Element" but now it just shows a grey box.
  • Demetris
Maybe I did not use the right term when I said splitter. Let me try again: :-)
You have to right-click on the border between the Playlist View and the Visualisation panel, not on the Visualisation panel. The whole area will then get selected, and you can paste the Playlist View over it (or select Replace UI Element from the menu, and pick something else).
  • Bangers
Thanks mate!  Got it working, perfect!
  • Demetris
Glad you got it working!
It took me a few tries to figure this out myself the first time.
  • dhromed
Crap, that's a handy trick.  I was a bit miffed about the lack of an unsplitter.
Tip for UI customisers: use the scratchbox.
Thanks man, it really helped me to get a very good understanding over the foobar customization, it really helped me, i just started using foobar, replacing winamp because winamp is pain in the you know where. thanks again for your time on explaining others, i learned by listening to you.
