Topic: DAE quality report on Plextor PX-708A (Read 4627 times) previous topic - next topic
As stated here, I've tested my drives with the DAE quality test from the EAC homepage.
Further explanations about the test procedure can be found here, so here are the facts about the PX-708A:
Drive: Plextor PX-708A
Firmware:: 1.12
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]Test at full speed ("Actual" speed setting in EAC)[/size]
http://www.hydrogenaudio.org/forums/index....ost&id=4272
DAE log
Errors total        Num : 159510
Errors (Loudness)  Num :  6310 - Avg :  -71.8 dB(A)  -  Max :  -18.7 dB(A)
Error Muting        Num :    429 - Avg :    1.0 Samples -  Max :      1 Samples
Skips              Num :      0 - Avg :    0.0 Samples -  Max :      0 Samples
Total Test Result      :  80.9 points (of 100.0 maximum)
EAC log
Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
EAC extraction logfile from 6. February 2008, 23:35
Unknown Artist / Unknown Title
Used drive  : PLEXTOR DVDR  PX-708A  Adapter: 2  ID: 0
Read mode : Burst
Read offset correction                      : 30
Overread into Lead-In and Lead-Out          : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Not detected, thus appended to previous track
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 | 74:00.00 |        0    |  332999
Track  1
    Filename D:\DAE\Plextor PX-708A (2)\EAC - Actual\2\Track01.wav
    Peak level 96.0 %
    Copy CRC 29498C7D
    Track not present in AccurateRip database
    Copy OK
None of the tracks are present in the AccurateRip database
No errors occurred
End of status report
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]Test at 24x[/size]
http://www.hydrogenaudio.org/forums/index....ost&id=4271
DAE log
Errors total        Num : 87886
Errors (Loudness)  Num :  15658 - Avg :  -79.1 dB(A)  -  Max :  -43.9 dB(A)
Error Muting        Num :    241 - Avg :    1.0 Samples -  Max :      2 Samples
Total Test Result      :  80.5 points (of 100.0 maximum)
EAC log
EAC extraction logfile from 8. February 2008, 19:27
Read mode : Burst
Track  1
    Filename D:\DAE\Plextor PX-708A (2)\EAC - 24x\2\Track01.wav
    Peak level 77.4 %
    Copy CRC AF3CC877
    Copy OK
No errors occurred
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]Test at 8x[/size]
http://www.hydrogenaudio.org/forums/index....ost&id=4270
DAE log
Errors total        Num : 258407
Errors (Loudness)  Num :  14135 - Avg :  -73.2 dB(A)  -  Max :  -22.0 dB(A)
Error Muting        Num :    498 - Avg :    1.0 Samples -  Max :      2 Samples
Skips              Num :    30 - Avg :    6.0 Samples -  Max :      6 Samples
Total Test Result      :  69.5 points (of 100.0 maximum)
EAC log
EAC extraction logfile from 8. February 2008, 19:37
Read mode : Burst
Track  1
    Filename D:\DAE\Plextor PX-708A (2)\EAC - 8x\Track01.wav
    Timing problem 0:24:44
    Timing problem 0:25:45
    Peak level 77.4 %
    Copy CRC 7455DB03
    Copy finished
No errors occurred
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]Test at 4x[/size]
http://www.hydrogenaudio.org/forums/index....ost&id=4269
DAE log
Errors total        Num : 1539752
Errors (Loudness)  Num :  36741 - Avg :  -61.1 dB(A)  -  Max :  -6.3 dB(A)
Error Muting        Num :  1945 - Avg :    1.1 Samples -  Max :      4 Samples
Skips              Num :    521 - Avg :    7.2 Samples -  Max :    24 Samples
Total Test Result      :  61.3 points (of 100.0 maximum)
EAC log
EAC extraction logfile from 6. February 2008, 21:11
Read mode : Burst
Track  1
    Filename D:\DAE\Plextor PX-708A (2)\EAC - 4x\Track01.wav
    Timing problem 0:10:53
    Timing problem 0:11:45
    Timing problem 0:12:02
    Timing problem 0:12:36 - 0:12:37
    Timing problem 0:15:12
    Timing problem 0:15:24
    Timing problem 0:15:46
    Timing problem 0:15:54
    Timing problem 0:16:06
    Timing problem 0:16:23
    Timing problem 0:16:29
    Timing problem 0:16:35
    Timing problem 0:16:43
    Timing problem 0:17:08
    Timing problem 0:17:55
    Timing problem 0:18:05 - 0:18:06
    Timing problem 0:18:08
    Timing problem 0:18:17
    Timing problem 0:18:29
    Timing problem 0:18:48
    Timing problem 0:18:55
    Timing problem 0:18:58
    Timing problem 0:19:16 - 0:19:17
    Timing problem 0:19:25
    Timing problem 0:19:36
    Timing problem 0:19:38
    Timing problem 0:19:41
    Timing problem 0:19:52
    Timing problem 0:20:00 - 0:20:01
    Timing problem 0:20:05 - 0:20:06
    Timing problem 0:20:10 - 0:20:11
    Timing problem 0:20:15
    Timing problem 0:20:20
    Timing problem 0:20:24
    Timing problem 0:20:30
    Timing problem 0:20:34
    Timing problem 0:20:38
    Timing problem 0:20:43
    Timing problem 0:20:46
    Timing problem 0:20:50
    Timing problem 0:20:53
    Timing problem 0:20:57
    Timing problem 0:21:00
    Timing problem 0:21:03
    Timing problem 0:21:08
    Timing problem 0:21:10
    Timing problem 0:21:13
    Timing problem 0:21:15
    Timing problem 0:21:19
    Timing problem 0:21:24 - 0:21:25
    Timing problem 0:21:30
    Timing problem 0:21:32
    Timing problem 0:21:35
    Timing problem 0:21:38
    Timing problem 0:21:41
    Timing problem 0:21:45
    Timing problem 0:21:47
    Timing problem 0:21:51
    Timing problem 0:21:54
    Timing problem 0:21:58
    Timing problem 0:22:01 - 0:22:02
    Timing problem 0:22:06
    Timing problem 0:22:10
    Timing problem 0:22:13
    Timing problem 0:22:16
    Timing problem 0:22:19
    Timing problem 0:22:23
    Timing problem 0:22:26
    Timing problem 0:22:30
    Timing problem 0:22:34
    Timing problem 0:22:37
    Timing problem 0:22:41
    Timing problem 0:22:43
    Timing problem 0:22:47
    Timing problem 0:22:50
    Timing problem 0:22:54
    Timing problem 0:22:57
    Timing problem 0:23:01
    Timing problem 0:23:04
    Timing problem 0:23:08
    Timing problem 0:23:11 - 0:23:12
    Timing problem 0:23:14
    Timing problem 0:23:16
    Timing problem 0:23:20
    Timing problem 0:23:23 - 0:23:24
    Timing problem 0:23:28
    Timing problem 0:23:31
    Timing problem 0:23:35
    Timing problem 0:23:39
    Timing problem 0:23:43
    Timing problem 0:23:46
    Timing problem 0:23:50
    Timing problem 0:23:54
    Timing problem 0:23:57
    Timing problem 0:24:00
    Timing problem 0:24:04
    Timing problem 0:24:07
    Timing problem 0:24:11
    Timing problem 0:24:15
    Timing problem 0:24:18
    Timing problem 0:24:22
    Timing problem 0:24:26
    Timing problem 0:24:28
    Timing problem 0:24:31
    Timing problem 0:24:34
    Timing problem 0:24:38
    Timing problem 0:24:42
    Timing problem 0:24:45
    Timing problem 0:24:49
    Timing problem 0:24:52
    Timing problem 0:24:55
    Timing problem 0:24:59
    Timing problem 0:25:02
    Timing problem 0:25:05
    Timing problem 0:25:08
    Timing problem 0:25:11
    Timing problem 0:25:15
    Timing problem 0:25:18
    Timing problem 0:25:22
    Timing problem 0:25:25
    Timing problem 0:25:28
    Timing problem 0:25:32
    Timing problem 0:25:36
    Timing problem 0:25:39
    Timing problem 0:25:42
    Timing problem 0:25:46
    Timing problem 0:25:49
    Timing problem 0:25:53
    Timing problem 0:25:56
    Timing problem 0:25:59
    Timing problem 0:26:03
    Timing problem 0:26:06
    Timing problem 0:26:09
    Timing problem 0:26:13
    Timing problem 0:26:15
    Timing problem 0:26:19
    Timing problem 0:26:22
    Timing problem 0:26:24
    Timing problem 0:26:27
    Timing problem 0:26:30
    Timing problem 0:26:33
    Timing problem 0:26:36
    Timing problem 0:26:39
    Timing problem 0:26:42
    Timing problem 0:26:45
    Timing problem 0:26:48
    Timing problem 0:26:51
    Timing problem 0:26:54
    Timing problem 0:26:57
    Timing problem 0:27:00
    Timing problem 0:27:03
    Timing problem 0:27:07
    Timing problem 0:27:10
    Timing problem 0:27:13
    Timing problem 0:27:16
    Timing problem 0:27:19
    Timing problem 0:27:23
    Timing problem 0:27:26
    Timing problem 0:27:29
    Timing problem 0:27:32
    Timing problem 0:27:35
    Timing problem 0:27:38
    Timing problem 0:27:41
    Timing problem 0:27:45
    Timing problem 0:27:48
    Timing problem 0:27:51
    Timing problem 0:27:54
    Timing problem 0:27:57
    Timing problem 0:28:01
    Timing problem 0:28:04
    Timing problem 0:28:06
    Timing problem 0:28:10
    Timing problem 0:28:12
    Timing problem 0:28:15
    Timing problem 0:28:17
    Timing problem 0:28:21
    Timing problem 0:28:24
    Timing problem 0:28:27
    Timing problem 0:28:30
    Timing problem 0:28:33
    Timing problem 0:28:35
    Timing problem 0:28:38
    Timing problem 0:28:42
    Timing problem 0:28:44
    Timing problem 0:28:47
    Timing problem 0:28:50
    Timing problem 0:28:52
    Timing problem 0:28:55
    Timing problem 0:28:58
    Timing problem 0:29:00
    Timing problem 0:29:03
    Timing problem 0:29:06
    Timing problem 0:29:09
    Timing problem 0:29:12
    Timing problem 0:29:14
    Timing problem 0:29:16
    Timing problem 0:29:19
    Timing problem 0:29:22
    Timing problem 0:29:25
    Timing problem 0:29:28
    Timing problem 0:29:30
    Timing problem 0:29:33
    Timing problem 0:29:35
    Timing problem 0:29:38
    Timing problem 0:29:40
    Timing problem 0:29:42
    Timing problem 0:29:44
    Timing problem 0:29:46
    Timing problem 0:29:49
    Timing problem 0:29:51
    Timing problem 0:29:53
    Timing problem 0:29:56
    Timing problem 0:29:59
    Timing problem 0:30:01
    Timing problem 0:30:04
    Timing problem 0:30:07
    Timing problem 0:30:09
    Timing problem 0:30:12
    Timing problem 0:30:14
    Timing problem 0:30:17
    Timing problem 0:30:20
    Timing problem 0:30:22
    Timing problem 0:30:25
    Timing problem 0:30:27
    Timing problem 0:30:30
    Timing problem 0:30:32
    Timing problem 0:30:34
    Timing problem 0:30:37
    Timing problem 0:30:40
    Timing problem 0:30:42
    Timing problem 0:30:45
    Timing problem 0:30:47
    Timing problem 0:30:50
    Timing problem 0:30:53
    Timing problem 0:30:55
    Timing problem 0:30:57
    Timing problem 0:31:00
    Timing problem 0:31:02
    Timing problem 0:31:04
    Timing problem 0:31:07
    Timing problem 0:31:09
    Timing problem 0:31:11
    Timing problem 0:31:14
    Timing problem 0:31:16
    Timing problem 0:31:18
    Timing problem 0:31:20
    Timing problem 0:31:22
    Timing problem 0:31:24
    Timing problem 0:31:27
    Timing problem 0:31:29
    Timing problem 0:31:31
    Timing problem 0:31:34
    Timing problem 0:31:37
    Timing problem 0:31:39
    Timing problem 0:31:41
    Timing problem 0:31:43
    Timing problem 0:31:45
    Timing problem 0:31:48
    Timing problem 0:31:50
    Timing problem 0:31:53
    Timing problem 0:31:55
    Timing problem 0:31:57
    Timing problem 0:31:59
    Timing problem 0:32:01
    Timing problem 0:32:04
    Timing problem 0:32:06
    Timing problem 0:32:08
    Timing problem 0:32:11
    Timing problem 0:32:13
    Timing problem 0:32:16
    Timing problem 0:32:18
    Timing problem 0:32:20
    Timing problem 0:32:23
    Timing problem 0:32:25
    Timing problem 0:32:28
    Timing problem 0:32:30
    Timing problem 0:32:33
    Timing problem 0:32:36
    Timing problem 0:32:39
    Timing problem 0:32:43
    Timing problem 0:32:46
    Timing problem 0:32:50
    Timing problem 0:46:20
    Peak level 99.9 %
    Copy CRC 16B6E096
    Copy finished
No errors occurred
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]Conclusion[/size]
I tested two different PX-708A drives. One was not able to rip the test CD with speeds lower than 24x (I've tried it for 5 hours - it just got stuck). The other thing which was very interesting: I've done the test with every speed setting twice. On the drive mentioned above, the results for any specific speed quite differed. As all of the results of this drive were a little bit "fishy", I dropped them altogether. So all the results posted above are taken from one drive only.
The DAE results of the PX-708A are better than these of the PX-755A (see the correspondig thread). Very astonishing is the fact, that the best results are produced with the highest speed ("actual" in EAC). The lower the speed gets, the more problems the painted triangle (simulated dirt, I suppose) is causing.
On the other hand, the artifical scratches are handled all the same, there are no big differences between the speed settings.
On the slower speeds (4x and 8x) the extraction took a very long time.
So the PX-708A is a good drive for DAE, but still far away from perfect.
