Topic: .Ogg Vorbis aotuv (Read 504083 times) previous topic - next topic
.Ogg Vorbis aotuv
Reply #275
Can anyone upload linux binaries?
.Ogg Vorbis aotuv
Reply #276
Big thanks to Aoyumi and John33  .
I sure wish ogg vorbis getting more hardware support.
.Ogg Vorbis aotuv
Reply #277
To Aoyumi and John33 - thank you.
.Ogg Vorbis aotuv
Reply #278
thanks fpr yet another update^^ Keep up the good work.
HF, Clobon
.Ogg Vorbis aotuv
Reply #280
Thank you very much guys
It is ALWAYS appreciate your efforts and time spending on ogg vobis project. I'm always happy everytime i see another release comin out
Thanks again
.Ogg Vorbis aotuv
Reply #282
Thanks Aoyumi for the great fork, thanks john33 for the Windows binaries, and thanks artfwo for the GNU/Linux binaries. I am an advocate of the Vorbis format and you all three help a lot to spread a better free (as in freedom) tool.
FLAC and MP3 have me covered in everything.
Sansa Fuze v2 w/ Rockbox
.Ogg Vorbis aotuv
Reply #283
Oh yeah, Vorbis rules; thanx to everyone involved!
.Ogg Vorbis aotuv
Reply #284
There are a lot of DAPs that can play Vorbis nowadays. One should look beyond the iPod to really see the light
I am listening to AoTuv 5.7 -q5 files on my Cowon D2 right now....
.Ogg Vorbis aotuv
Reply #285
Hi
So... The D2 hasn't got the bad habit of annoyingly bad Ogg playback?
My iAudio7 sounds awful when playing back Ogg (~Q7  ).
Sorry for OT. HF, Clobon
.Ogg Vorbis aotuv
Reply #286
Aoyumi, I was looking through the old XIPH mailing lists and I read that the xiph team wanted you to become the official maintainer for Vorbis but you declined the offer. I was wondering what was the reason behind this as you would be doing the same thing you are right now but the source would be accessible to more public (like linux distributions, game developers, etc etc who right now use the stock vorbis code). I don't think the changes right now in your branch might take a very long time to be merged back if at all. I know you must have a reason but I was just confused.
.Ogg Vorbis aotuv
Reply #287
Aliumalik
I was wondering the same thing.
.Ogg Vorbis aotuv
Reply #288
As for time, I am limited. I must throw something away if I undertake it.
.Ogg Vorbis aotuv
Reply #289
No. They have fixed that in the D2.
.Ogg Vorbis aotuv
Reply #291
Hello rt87. Is this new build aimed at handling problem samples mentioned in this thread?
.Ogg Vorbis aotuv
Reply #292
Don't know.
release notice translated by excite.jp:
The new test version of aoTuV was up-loaded to the test page.
The nature that especially put up the hand about the problem by the mistake of the block switching of the encoder did not exist at all though some problems peculiar to a current Vorbis encoder remained. Because this part is a very slight part in the patent surroundings. I did not want to be related for the comment to refer the patent to exist also in the source code of foundation if possible. However, because the artifact caused by this problem stands out though there are not a lot of ratios where the problem around the block switching is caused, the mistake is not found in the part it that should mend.
The problem of causing it with some samples was reduced as a result of this trial and error by enhancing the range where the change in a rough algorithm is not accompanied, and it was possible to cancel it. The average bit rate's rising a little, the encode time has expanded a little. I think a problem all already-known to be a trade-off not bad as for the improvement though no made translation.
Please inform me though it doesn't think the problem to be if something a peculiar problem is caused. The change point of this version has the influence in all the encode modes.
Sorry for my English.
.Ogg Vorbis aotuv
Reply #293
I am quite convinced that it indeed has to do something with the samples in that thread! Let us wait and watch.
.Ogg Vorbis aotuv
Reply #294
Hello, I'm using CDex 1.70 beta 2 on Vista 64 SP1. So far I've been using aoTuVb5.5 without any problems. But as soon as I install aoTuVb5.7 the OGG option disappears from the list of encoders in CDEx. When I put back the 5.5 files, it's ok again.
Did anyone notice that problem ? Any solution ?
Thanks in advance
Mirko
.Ogg Vorbis aotuv
Reply #295
You may need the libmmd.dll (10.1 version) from the 'Others' page at Rarewares.
.Ogg Vorbis aotuv
Reply #296
aoTuV b5.5 depends on MSVCRT.DLL but aoTuV b5.7 requires MSVCR90.dll. Install Microsoft Visual C++ 2008 Redistributable.
.Ogg Vorbis aotuv
Reply #297
Thanks a lot, now it works
.Ogg Vorbis aotuv
Reply #298
Yep, I forgot that one!!  Thanks.
.Ogg Vorbis aotuv
Reply #299
Supplement:
The aoTuV beta 5.7 DLL in my page does not need additional DLLs.
This depends on the difference of the compiler (setting) simply.
