Topic: .Ogg Vorbis aotuv (Read 501493 times) previous topic - next topic
.Ogg Vorbis aotuv
Reply #75
This makes a fine birthday present.  I'm glad you put this together.  As an individual and on behalf of the community, I thank you.
+ The differences from the aoTuV beta 5...
+   1.  The frequency domain width of M6 was revised.
+   2.  For q-1/-2, a pre-echo reduction code was applied (M3).  In addition,
+   the M3 code was improved.
+   3.  The floor setup parameters in the low bit-rate was changed.
+   4.  The part including bug of noise normalization was rewritten.
+   5.  libvorbis 1.2.0 were merged. Furthermore, a revision of Bug #300 and
+   #1229 was applied.
+   6.  The ATH curve of the high frequency area (more than 32kHz) was revised.
+ ...and I tune up many parameters.
+ 2008/03/30
+ Aoyumi
ckjnigel:  The impetus to learn Japanese came from Aoyumi-san, eh?  That's awesome... XD
You know what else is awesome...?  For the first time, I'm unable to consistently abx some of my music at -q0 (lowpass 18).
Copy Restriction, Annulment, & Protection = C.R.A.P. -Supacon
.Ogg Vorbis aotuv
Reply #76
Are there any noticeable improvements when using q -5 between the previous beta and the current one?
Also, are there noticeable differences between using Auyumi's tuned-up build and Xiph.org's latest build at q -5?
Thanks for your hard work, Auyumi!
.Ogg Vorbis aotuv
Reply #77
Im kind of interested about the first question aswell.
Is there anyone who did any advance tests on the new built?
.Ogg Vorbis aotuv
Reply #78
Audible improvements at q5?  If a5 was transparent to you before, there's no "audible improvement" possible, no matter what build you use.
.Ogg Vorbis aotuv
Reply #79
But what about the pre-echo problems at high bitrates that some people mention on the previous beta? Is there any pre-echo reduction at q5 on the new beta?
.Ogg Vorbis aotuv
Reply #80
Does anybody else have problems with this beta 5.5 release? I encoded a few albums at -q0 for my portable player (iRiver S10) and even though the files plays in foobar, I only get 2-4 seconds of each song on my portable and then it tries to play the next song which is also about 4 seconds long and so on and so on...  It even says the songs are 4 seconds long!
Aoyumi, did you change something in the bit-stream?
/Kef
.Ogg Vorbis aotuv
Reply #81
/Kef
AFAIK, aoTuV beta5.5 uses official Vorbis 1.2.0 as its base. Previous versions use Vorbis 1.1.x.
Try Vorbis 1.2.0 (Xiph.Org libVorbis I 20070622) and you'll see if this matters.
Anyway, my Samsung YP-U3 plays such files (aoTuV beta 5.5, q0) without problems.
.Ogg Vorbis aotuv
Reply #82
/Kef
Ah, good catch, that might be it... I'll check
.Ogg Vorbis aotuv
Reply #83
/Kef
You where right, it's not aoTuV beta5.5, it is Vorbis 1.2.0 that causes the problem.
Good catch. Thanks! (off to iRiver to ask for a firmware-update)
/Kef
But that's not the whole story though... oggdrop works just fine with both beta5.5 and Vorbis 1.2.0, but not with foobar and either command line encoder... Strange!
.Ogg Vorbis aotuv
Reply #84
Which command line encoders are you referring to? oggenc2 output should match oggdropXPd output and if there is some fatal difference, I need to look into it.
.Ogg Vorbis aotuv
Reply #85
I'm referring to oggenc2.
I can send you the files, if you like, but ... I would probably be the next target of RIAA...
.Ogg Vorbis aotuv
Reply #86
What command line are you using from foobar and what options are you specifying in oggdropXPd? Sorry to be a pain, but I need to know whether foobar is doing something different.
.Ogg Vorbis aotuv
Reply #87
I'm just using default settings and -q0.
oggenc2 and oggdropXPd downloaded from rarewares
.Ogg Vorbis aotuv
Reply #88
No tagging at all?
.Ogg Vorbis aotuv
Reply #89
No tagging at all?
Ehum... I usually don't use tags but I checked the source (reference libFLAC 1.1.2 20050205) files and yes they are tagged.
No tagging at all?
Maybe it would be a good idea to use wav's to eliminate any tagging problem?
<edit>
I tested with a wav file and it worked perfectly, when I use the flac file it doesn't (using foobar2000 for both). Seems like some tagging problem to me.
</edit>
<edit2>
I removed the tags from the ogg file and still no luck
</edit2>
.Ogg Vorbis aotuv
Reply #90
<edit>
</edit>
<edit2>
</edit2>
So, if I understand this correctly, the ogg files created from the FLAC files using foobar, with tags copied from the FLAC files, fail in your portable.
The ogg files created from the FLAC files using oggdropXPd are read fine in the portable, but do they contain tags, or not?
The fact that removing the tags from the ogg files doesn't solve the problem may suggest that the tagging routines in foobar are behaving in a way that is not quite standard, or if the oggdropXPd generated files aren't created with tags, then there is something about tagging that the iRiver doesn't like.
Edit: Sorry, thinking about it, the comment about foobar tagging routines is probably complete nonsense since it will presumably just feed the tagging routines in oggenc2!
.Ogg Vorbis aotuv
Reply #91
Correct
They don't contain any tags.
Yeah, that's the question isn't it?
Anyway, I'm glad to find out it probably isn't a bit-stream problem. This is the first time I have encountered this problem and I have done a lot of conversions with both foobar and oggdropXPd. But as a previous poster suggested, it might have something to do with the new 1.2.0 libvorbis. I haven't used 1.2.0 until now (there was no reason to) and since aoTuVb5.5 is using 1.2.0 that might indeed be the problem. Luckily, there are workarounds for me.
<edit>
I'll test with libvorbis 1.2.0 later today and let you know if the problem is still there.
</edit>
.Ogg Vorbis aotuv
Reply #92
foobar2000 calls oggenc.exe with commandline like that:
"C:\Program Files\foobar2000_09\oggenc.exe" -s 38500796 -Q -q5,500000 - -o "temp-76C393E9766F3169AEED5705EBD7EA3B.ogg"
So fb2k don't rely on codecs when tagging.
.Ogg Vorbis aotuv
Reply #93
Try a conversion using oggdropXPd and set the option to copy the FLAC tags. If that causes a problem, then the tags would seem to be the problem.
Slightly more confusing is that the tagging routines in the library appear unchanged relative to the previous version.
.Ogg Vorbis aotuv
Reply #94
I did convert using oggdropXpd and copying the tags. It worked perfectly.
.Ogg Vorbis aotuv
Reply #95
In which case, the problem must lie on the foobar tagging! Which, in the context of lvqcl's post, certainly seems a possibility. Mal-formed tags, I would guess, although somewhat unexpected.
.Ogg Vorbis aotuv
Reply #96
/Kef
I don't discover the cause of the problem. However, I know that a problem gets up by the state of the comment header at a low bit rate depending on DAP.
I think that it is not a problem of the library. Because the reason is because the problem does not depend on the version of the library.
I suppose that padding domain of the Vorbis comment or the size of the Vorbis comment domain influences it.
.Ogg Vorbis aotuv
Reply #97
Are you still interested in material that provokes artefacts, to tune your psycho acoustics further? Or may I possibly add some "Advanced Encoder Options" here to test for you if they improve the result?
__
Listening to Ogg Vorbis audio with a Home Cinema set was in general satisfying for me. Most of my CDs sound well even when compressed with just Quality 3/10.
Some time ago I bought a pocket audio player which supports Ogg Vorbis files (Samsung YP-...), and I am in general satisfied too. Until I heard a remarkable exception. So I compared several oggenc2 versions (usually I prefer the aoTuV variants, the song I heard was encoded with aoTuV-b4), and even with the current b5.5 "release", I still get "twitting" noise at quality 3 with:
The Prodigy: 04. Your Love [Remix] (Experience, 1992)
for the synth percussion at the time 01:12-01:14, and even more at the time 03:29-03:31. I understand that this sound is possibly very provoking, it has sharp attacks and some flat "pappy" noise afterwards.
I can send you some material if required (e.g. short cuts around these positions).
.Ogg Vorbis aotuv
Reply #98
__
I understand the cause of the problem. But, I don't find an efficient solution for the moment.
Probably the basic solution is not possible in "Advanced Encoder Options".
When somebody finds the good method, I am glad.
.Ogg Vorbis aotuv
Reply #99
Thanks for this new release, Aoyumi!  The low bitrates keep getting better and better.
Also, I just asked in the Vorbis 1.2.0 release thread whether they included any of your tunings (beyond what was put in the Vorbis 1.1.0 release).  But looking here, I see I don't need to worry, since you already integrated Vorbis 1.2.0 into your latest release.
I second making a news thread.
