Topic: "Bad allocation" error on Windows Vista (Read 3881 times) previous topic - next topic
Ever since the betas of .9.5, I've been having a lot of crashes of the "Unhandled exception: bad allocation" variety.  I have no idea what's causing them, and I don't expect anybody else to either.  This is because there are no crash logs being generated, as far as I can tell, by either Foobar or Windows.
How do I proceed from here?  I love .9.5, but I hate having it crash on me every hour or so.  I'm running Vista Ultimate, 32-bit.
This problem is very likely because you have component(s) that is/are compiled with the old SDK. Please double check and upgrade your components first if necessary. If it still crashes then post your component list please.
Not that I want to dig up an old post, but this is the most relevant post that I've seen to my issue.
Pretty much what sinfony said, is my situation.
I will, however, list the components I have installed...
Core (2008-07-05 15:46:02)
    foobar2000 core 0.9.5.4
foo_abx.dll (2008-05-24 10:23:50)
    ABX Comparator 1.3.3
foo_albumlist.dll (2008-07-05 15:45:20)
    Album List 4.3
foo_audioscrobbler.dll (2008-03-09 14:08:00)
    Audioscrobbler 1.3.16
foo_burninate.dll (2006-08-04 21:56:44)
    Audio CD Writer 2.0.1
foo_cdda.dll (2008-06-25 12:18:24)
    CD Audio Decoder 2.1.3
foo_converter.dll (2008-07-05 15:45:22)
    Converter 1.1.2
foo_dsp_std.dll (2008-06-23 13:41:10)
    Standard DSP Array 1.0
foo_fileops.dll (2008-06-07 14:14:56)
    File Operations 2.1
foo_freedb2.dll (2008-06-07 14:15:10)
    freedb Tagger 0.6
foo_input_std.dll (2008-07-05 15:45:42)
    Standard Input Array 1.0
foo_lock.dll (2007-01-25 13:57:56)
    Pause on Lock 0.4
foo_pqview.dll (2008-03-11 19:02:54)
    Playback Queue Viewer 0.2
foo_removefromqueue.dll (2007-07-14 14:30:00)
    Remove from Queue 1
foo_removeplayed.dll (2007-09-02 13:15:30)
    Remove played Files 1.4.0
foo_rgscan.dll (2008-06-11 13:30:18)
    ReplayGain Scanner 2.0.8
foo_ui_columns.dll (2007-10-11 18:02:04)
    Columns UI 0.2
foo_ui_std.dll (2008-07-05 15:45:42)
    Default User Interface 0.9.5
foo_unpack.dll (2008-07-05 15:45:22)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
foo_winamp_spam.dll (2008-10-04 18:37:38)
    Winamp API Emulator 0.98
Thanks in advanced.
look for updates for these components
    Pause on Lock 0.4
    Remove from Queue 1
    Columns UI 0.2
Or just remove them from foobar folder.
/Edit: Solved. Old "foo_uie_quicksearch.dll" was the problem.
    Pause on Lock 0.4
    Remove from Queue 1
    Columns UI 0.2
Wow, I just saw this response (and it was based upon a notification of the other response).
I am not 100% sure what I did to fix it but after time I got it all working, haven't had an issue since.
Thanks. :-)
