Topic: DAE quality report on HP DVD Writer 300c (Read 4231 times) previous topic - next topic
Firmware Version:    7H29
Serial Number:    PHCX07442C
Read offset correction:    +1292
Write offset:        +78
Combined offset correcting:    +1370
Lead-in:        Can't be detected with my current test cd. Since offset is positive it is not important.
Lead-out:        Yes, at least 1280 samples (can't be sure there is more data on the cd).
HTOA:        No
Test at full speed
[img]http://www.hydrogenaudio.org/forums/index.php?act=Attach&type=post&id=4240"]
Errors total        Num:    9009582
Errors (Loudness)    Num:    41641 - Avg :  -18.1 dB(A)  -  Max :  -6.4 dB(A)
Error Muting        Num:    1752 - Avg : 3082.1 Samples -  Max :  3584 Samples
Skips        Num:    0 - Avg :    0.0 Samples -  Max :      0 Samples
Total Test Result:    71.0 points (of 100.0 maximum)
