Topic: Problem compiling vorbis-tools on OSX, help! (Read 2427 times) previous topic - next topic
I'm trying to compile ogg vorbis on OS X, and the ao, ogg, and vorbis components compile fine via ./configure make make install. However, I run into a problem when trying to compile the vorbis tools, this is a screen dump of the problem-
gcc -fno-common -O4 -Wall -fsigned-char -ffast-math -o oggenc oggenc.o audio.o encode.o platform.o  -L/usr/local/lib -lvorbisenc -lvorbis -lm -logg ../share/libutf8.a ../share/libgetopt.a
/usr/bin/ld: multiple definitions of symbol _getopt
/usr/lib/libm.dylib(getopt.o) definition of _getopt
../share/libgetopt.a(getopt.o) definition of _getopt in section (__TEXT,__text)
/usr/bin/ld: multiple definitions of symbol _optarg
/usr/lib/libm.dylib(getopt.o) definition of _optarg
../share/libgetopt.a(getopt.o) definition of _optarg in section (__DATA,__common)
/usr/bin/ld: multiple definitions of symbol _opterr
/usr/lib/libm.dylib(getopt.o) definition of _opterr
../share/libgetopt.a(getopt.o) definition of _opterr in section (__DATA,__data)
/usr/bin/ld: multiple definitions of symbol _optind
/usr/lib/libm.dylib(getopt.o) definition of _optind
../share/libgetopt.a(getopt.o) definition of _optind in section (__DATA,__data)
/usr/bin/ld: multiple definitions of symbol _optopt
/usr/lib/libm.dylib(getopt.o) definition of _optopt
../share/libgetopt.a(getopt.o) definition of _optopt in section (__DATA,__data)
make[2]: *** [oggenc] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
yes, I know that the system and the getopt part are both trying to define the same thing, which they can't do. Any help on this would be appreciated.
