Topic: Columns UI in 0.9.5: Del Key disabled? (Read 3346 times) previous topic - next topic
  • John Doe
Just updated to FB2K 0.95. Since then the Del Key is not recognized anymore.
I created a custom keyboard shortcut but that is not the same because befor you could remove "passively selected" tracks from the playlist (ie by adding them from the database and not actively select them). That is not possible with custom shortcuts.
Yours JD
/edit: content
  • Last Edit: 10 January, 2008, 11:51:07 AM by John Doe
  • foosion
  • Moderator
I suppose you are not using the Default UI or the most recent version of Columns UI. As of foobar2000 0.9.5, the playlist view is expected to implement editing actions like deleting tracks using the Delete key.
http://foosion.foobar2000.org/ - my components for foobar2000
  • John Doe
Hm I was using Columns UI 0.2.0 beta1. I'll check if there's an updated version (again...an automatic update function would be an evolutionary, timesaving step!!).
JD
  • John Doe
Updated Columns UI without luck: Del key still not working properly.
JD
  • thuan
It works for me which version you're using? Please try the latest alpha version if you haven't done so.
  • Last Edit: 11 January, 2008, 10:48:07 AM by thuan
  • John Doe
I'm using Columns UI v0.2.1alpha10v3 (is that an official version counting? ;-)
JD
  • Last Edit: 15 January, 2008, 04:49:32 AM by John Doe
  • lucser
Hello All,
For me is also not working. What is worst is that I've tried to find some info about it (if is disabled/bug/etc or how to enable) but not able to find.
It is strange for me since is a basic thing, beeing as important as possibility to add tracks to playlist.
Thanks in advance
Edit
Now I use as workaround: adding to the preferences-context menu the command " edit/ remove from playlist".
  • Last Edit: 17 January, 2008, 01:03:48 AM by lucser
