Topic: Rendering oddity (FireFox + MacOS X) (Read 4661 times) previous topic - next topic
  • chelgrian
Under FireFox on MacOS X I get a misrendering of the top of any hydrogenaudio page where the Google search box is render on top of the the "io" of "hydrogenaudio" in logos.png. It doesn't seem to happen under Safari.
Obviously this isn't a big problem but I was wondering if it was only me or if anyone else can reproduce it?
  • pepoluan
Can you provide a screenshot?
Nobody is Perfect.
I am Nobody.
http://pandu.poluan.info
  • MichaelW
No problem here.
Firefox 2.0.0.11
OS X 10.4.11
  • neomoe
No problem here.
Firefox 2.0.0.11
OS X 10.4.11
same here - not a problem.
firefox on osx (tiger) has issues rendering some fonts. check yours and perhaps remove those you don't need.
klick,klack.
remember to keep at least:
    * Geneva.dfont
    * HelveLTMM
    * Keyboard.dfont
    * LastResort.dfont
    * LucidaGrande.dfont
    * Monaco.dfont
    * TimesLTMM
    * Times LT MM
which are system fonts and therefor located in "/Library/Fonts". you don't have to delete fonts. you can just use "Font Book.app" to deactivate them. in my case the problem laid in *ttf (PC) fonts which I had installed for correctly using darwine.
klick for image.
just drag those (in case you installed windows fonts) off the said folder and be fine.
  • Last Edit: 07 January, 2008, 05:54:15 PM by neomoe
  • chelgrian
On closer inspection it appears to be because the google search box is rendering ontop of the graphic because my browser window is only 900 odd pixels wide.
