Topic: Where to get AAC player for pocketPC (Read 4328 times) previous topic - next topic
hi i have an Ipaq with the microsoft pocketPC.
is there anyway i can make media player play AAC files. ?
Sven Bent - Denmark
Have you tried Nic's AAC directshow?
http://www.freewebz.com/nixstuff/
(Although I don't know if, somehow, media player architecture is different for PocketPC)
Regards;
Roberto.
I'll try that put i think the architectureof PocketPC media player is WAY different then Windows MediaPlayer
Sven Bent - Denmark
how fast is the ipaq?
i am jut wondering because aac tends to use a lot of resources
206Mhz ARM processor, and all PPC2002 handhelds use the same processor.  Figure ~12-16MB of free ram (assuming 32MB RAM).
Source: http://www5.compaq.com/products/quickspecs...a/10632_na.HTML
Kimberly aka
Baroness Sylvia von Zurich (the only Goldwater Conservative) endorses the Meadow Party's Bill and Opus for the 2004 Presidential election!  A sometimes dead cat and an overweight penguin who looks like a puffin couldn't possibly do any worse than a Shrub.
these are the shop's spec on the device
266 MHz Intel® StrongARM SA-1110 processor
64 MB RAM
16 MB ROM
should be fast enough
otherwise I'll OC the darn thing
Sven Bent - Denmark
i guess it also depends what sort of aac you are trying to play....
i think the different profiles require different cpu powers
I know about two possibble solutions:
PocketMusic Player with AAC Plugin, shareware here.
or get TCPMP with the aac plugin (you need aac plugin version 0.6, in later versions aac support was removed due to some license issues. With help of Google you can still find it on the net
