Topic: 2 New Skins for foo_popupplus (Read 46954 times) previous topic - next topic
Here are 2 new skins I wrote for popup+. The components thread can be found here.
Comments and feedback are welcome. If you discover any bugs or have suggestions / questions please post!
Install: Extract the zip files into components/foo_popupplus directory. In foobar go File/Preferences/Popup Plus/Skins, and select the downloaded skin. Above the preview image of the skin you can find options to customize it to your needs.
Download:
[attachment=4120:attachment]
[attachment=4121:attachment]
Changes:[/b]
Simple CD 1.5 (2007. 12. 27.)
- Modified CD and background images
- Option added: position CD case right (see screenshot nr 3.)
- Other small changes
Simple Vinyl 1.8 (2007. 12. 27.)
- Option added: position vinyl case right (see screenshot nr 6.)
- Option added: Hole in the case (see screenshot nr 5. and 8.)
- New no cover picture (see screenshot nr 8.)
- Modified images
Thanks to:[/u]
- LeMarquis @ deviantart for the CD and Vinyl images
- cristox for the idea of the CD case version
Screenshots:
CD Version:
1.
2.
3.
Vinyl Version
4.
5.
6.
7.
8.
Wow this is great.. especially the Vinyl version..
I'm a newb.. so i gotta ask..
how did you format the text the way you have it there?
Thank you. These are awesome.
For the play couter you will need foo_playback_custom + foo_custominfo (see here)
For the rating see this topic
'[b]''[size=12]'[%artist%$crlf()]
%title%'[/size]''[/b]'$crlf()
'[size=6]'$crlf()'[/size]'
[Length: %length%  ?  ]Quality: %codec% $if($strstr(%codec_profile%,VBR),%codec_profile%,%bitrate%kbps)$crlf()
$if($stricmp($left(%path%,7),'http://'),Streaming...,$if(%play_counter%,Playcount: %play_counter%x,Not Played)  ?  $if(%rating%,Rating: $repeat(?,%rating%),Not Rated))
Updated Simple Vinyl skin to v1.2
changes:
-improved cover frame
-modern effect option
-old effect option
Thanks for the info!
nice idea.
very original.
wait...i know that from somewhere...
aaah...its my idea...you are a genius.
nice idea.
very original.
True, I was inspired by your idea, sorry for not mentioning.
looks good man! both look great,  im not a big fan of the glare over the album art though also i noticed you spelled length wrong in your config.
The code is ok and you need the lastest v20071025 of PopUp Plus.
Updated!
Simple CD 1.1
-Improved background
-Possibility to choose square or rounded edges for the background
Simple Vinyl 1.4
-Improved background and effects
-Rearranged options
-Possibility to choose Vinyl or CD
in the next version i will add an option to remove gloss effect
Simple CD 1.2
-Option added: show / remove gloss
Simple Vinyl 1.5
-Modified options
Simple Vinyl 1.5
-Modified options
if i can have a feature request for vinyl version (for i like it more than cdbox ) can we have option to possition booklet right too?
Wow... those skins look amazing! I'll definitely have to give it a look-see!
Would you like something like this?
PS. I coded it as a separate skin, i will integrate a "position CD/vinyl case right" into the present skins. Update will come soon.
Big update finished. Go grab now.
thanks... now im heaven...
and new "hole in center" effect looks quite nice
short question: how is "no album art" picture handled? is it defined in skin or popup+ component itself define it over skin?
You can define it in both. In the skin I put a "no cover" picture behind the layer of the avatar (albumart), which means if there is no cover found, the avatar layer will be blank and you can see the the picture behind it (you can still replace it with your own)
Defining in pop+ means that the avatar layer won't be blank at all, it will be always filled with image.
Go Preferences/Popupplus/Advanced
insert:
$replace(%path%,%filename_ext%,*.jpg)
$replace(%path%,%filename_ext%,*.png)
$replace(%path%,%filename_ext%,front.jpg)
(etc etc, you can define to put different pictures for audio cds, radio streams, search for it in the forum)
Put your no cover picture in program files\foobar\images\nocover.jpg This will be the no cover picture but will be displayed as an avatar so it still overlays the nocover picture in the skin. This must be the last entry, otherwise the other expressions below it wont be noticed. The component scans from up to down and finds the first true expression (the "images\nocover.jpg" is always true)
I hope I explained well and you understand now.
This is really nice. Great work!
Nice Skin!
And could you tell me how to make the buttons in the task bar? (like the screen you showed)
Extract Taskbar Shortcuts folder into Program Files\foobar2000
Extract Taskbar folder into Program Files\foobar2000\Images
right click on taskbar: Toolbars > New Toolbar
navigate to folder: Program Files\foobar2000\Taskbar Shortcuts > Select Folder
right click on the new toolbar > tick out show title and show text
and it should work
and it should work
It works perfectly!
Thank you, Totyo
