Topic: AAC & Vorbis (Read 4560 times) previous topic - next topic
  • ozmosis82
AAC & Vorbis
I just don't get it. How is it that I can ABX AAC files with ridiculously high bitrates (Nero @ 0.50 and the new QuickTime/Core Audio VBR @ q127) against their lossless versions and be able to spot the differences, but I can encode those same files with aoTuVb5 at q3.5 and can't hear the difference for the life of me? It just makes owning an iPod that much more frustrating.
  • Kef
AAC & Vorbis
Most likely because listening test are highly subjective. One person might be more sensitive to the artifacts produces by one encoder while an other person might be more sensitive to another.
If you want to play ogg vorbis files on your ipod I'd recommend find out more about "rockbox" here: http://www.rockbox.org/
/Kef
  • Last Edit: 19 November, 2007, 03:03:52 AM by Kef
  • ozmosis82
AAC & Vorbis
/Kef
Yeah... I tried it awhile ago. Unfortunately it can't use it with my iPod adapter in my car (playing + charging = happy road trips). I also now have a 160GB Classic, which it doesn't work on yet.
  • Garf
  • Developer (Donating)
AAC & Vorbis
Would be interesting to post some clips. At least the Nero devs read this forum and can fix issues.
  • pdq
AAC & Vorbis
I would also recommend before abx testing that you decode both files to wav to avoid any possibility of them being processed differently in your system.
  • ozmosis82
AAC & Vorbis
I will after I try pdq's suggestion. It seems to be really noticeable for me on two of my samples. In both cases, it's how the hi-hats sound... they sort of sound smeared.
Good idea. I'll do that. I'm currently using foobar to ABX... doesn't it convert them to Vorbis? I seem to remember seeing something like that flash on the screen just before the main ABX window loads.
