Topic: mpc quality analyzer & EAC (Read 3944 times) previous topic - next topic
Got some more questions for ya...
I'm currently using mpc 1.16 and EAC .99 prebeta 3 with AccurateRip.
I'm wondering if there is a way to have EAC work like this with MPC and AccurateRip.
also, please forgive me if the order doesn't make sense... just work with me ;^)
Insert CD
Grabs freedb nfo
*Analyze the CD for a MPC Quality Level that has the most quality/compression
---I ask this because I keep reading that some tracks are more complex sometimes requiring higher than 5.
*Apply the quality levels found
Burst Rip cd
Check AccurateRip for confidence
*For tracks not confident, Re-Rip in Secure Mode
*Check for confidence
*Include a log that covers the whole process.
I'm wondering if the community know if this is possible if EAC plugins/command line para AND/OR if there are 3rd party programs to do that?
Hope I ya'll followed, if not please ask me.
PS: In Foobar for the Codec Profile it says:
Codec Profile : Musepack 'Extreme' (when I set quality 6)
I want:
Codec Profile : Musepack 'Q6" or "Quality 6)
Anyone have an idea?
  • Last Edit: 12 November, 2007, 07:46:01 PM by Saphoroth
  • shadowking
I am sure there is no auto-quality detector ! This is what a good vbr psymodel already does..BTW - Don't believe what you read that MPC needs more than Q6 'Xtreme' because you will not find even a small collection of samples that people can easily tell apart.
To change foobar profile I think you will need to modify the decoder.
  • [JAZ]
<kidding mode on>
I have a button on the bottom left part of my screen that says "Start". I want it to say "I'm the F*kng boss".
</kidding mode off>
There's a difference between changing an option and coding an action. MPC was coded to be "quality 6 -> preset extreme", and the decoder made for foobar to play mpc's followed this.
If you want to ask the plugin coder to have that, either hardcoded (doubt it), by a setting in the configuration, or by showing both.... It's up to him.
  • xmixahlx
no you'll just have to modify the code that detects the profile used and the text it displays after detection. it is located in the header.
