Topic: Discussion of "Default UI Gallery" (Read 389938 times) previous topic - next topic
Reply #277
The thumbs up and thumbs down buttons run masstagger scripts that increase and decrease the rating.
The stars are just displayed by a text display box.
elevatorladylevitateme
Reply #278
Heres mine, Facets + Text Display:
Lyrics:
EDIT: Also, Pretty Popup and Luceo's icon:
How'd you get the lyrics working?  If you used Dockable Panels, how do the lyrics only display when you click the tab?  Thanks!
Reply #279
Lyrics are show with foo_textdisplay, using the following config (right-click > settings):
%artist% - %title%$crlf()
$crlf()
$if(%lyrics%,%lyrics%,No lyrics)
Using %lyrics% tag provided by Lyrics Grabber
Here's my updated config btw, now with artist.jpg (hooray!)
foobar > *
Reply #281
One request that future posters include a link to the fth or config file with a screen. Thanks!
Guinness for strength!
Reply #282
[a href="http://img155.imageshack.us/img155/5312/20090512.png" target="_blank"]
This look amazing, mate!
Any chance you can share your vertical rating?
Reply #283
Thanks. Here's the code I use for the vertical rating :
$ifgreater(%rating%,0,?,?)$crlf()
$ifgreater(%rating%,1,?,?)$crlf()
$ifgreater(%rating%,2,?,?)$crlf()
$ifgreater(%rating%,3,?,?)$crlf()
$ifgreater(%rating%,4,?,?)
Reply #284
I have yet to seen someone show config that..
- Not a minimalist config, I want to see configs that at least have all of these and does NOT hide in Tabs : Album art view, Any type of Vis that are not embedded in toolbar, Album list or (more preferably) Facet with 3 or more columns, Playlist view.
- Densely pack yet easily readable, any text (Title, Album name, etc) show in anywhere should not clipped and show ellipsis for most of the times.
- Rectangle shape, and not tall.
- and the most important, NOT huge! foobar size should have height no more than 550 pixels.
I find it difficult to design such layout that still look neat, foobar DUI need a lot of spaces to use efficiently IMO. I did have my own layout but so far after a lot of time and tinkering, I came up with only 1 layout which I currently using.
I need some more ideas.. Anyone?
Reply #285
foobar version 0.9.6.7
Reply #286
[a href="http://img25.imageshack.us/img25/5280/capturerrp.png" target="_blank"]
[note] Don't take this serious
Reply #287
Hey, your album art is of low quality, and in which resolution do you run windows?
I run windows in 1680*1050.
And some of my album art are not so good indeed, I have some 300*300 and other in 500*500.
Yes, I'll try to switch to CUI, that's why I post my config now just before changing ^^
Sorry for the bad english, I'm french .
Reply #288
Well OK, I meant it's not 32bit, it looks like it's run in some compatibility mode, but nevermind
I think everyone can enjoy CUI as DUI or vice versa, and that's all same lovely foobar but with different details
[edit] this silly posts refers to this image
Reply #289
Well, I don't really undestand what looks like it's run in compatibility mode ? The album art ? Foobar2000 ? Could you explain ?
Aero was disable on the capture... Here another capture: [a href="http://img194.imageshack.us/my.php?image=sanstitredgx.png" target="_blank"]
Reply #290
You probably used "windows basic theme", which also appears when some program changes the display mode or you are running in compatibility mode
In you second screenshot this isn't the case
Reply #291
shakey_snake,
a beautiful desktop wallpaper you have, I love such themes.
I see a playlist named "Needs Tagged" in your foobar screenshot.
Is it an auto playlist and would you share the code for it?
Robertina.
Reply #292
Right-click the "New Music" branch in your album list when viewing "by folder structure".
It's just a sub-folder I use as a staging area. Not everything needs some complicated formula.
Reply #293
I recently got a 22" LCD monitor, which has been an awesome change from my hulking 19" CRT beast.
Click thumbnail:
This is pretty sweet, can you share?
Reply #294
Hey NappyHead,
I uploaded the config in this topic. I'm not 100% whether the thing exported properly but hopefully it works
Reply #296
Hmhm  I was just thinking what would Peter`s Foobar look like
@Phoo! thats cool
Reply #297
My config
Reply #298
My improvement over visualisation + cover art + tabs
My first post! =)
Is there a way to add album art to the playlist? like columns ui but without using columns ui?
Reply #299
no
terry
