Topic: Discussion of "Default UI Gallery" (Read 255646 times) previous topic - next topic
  • Rain
Here is mine. Very simple but I like it:
How do you make it display "Megan McCauley / 2007 / MP3"
  • antiKk
Preferences > Display > Default User Interface > Playlist View:
Add New Group
%artist% / %album% / %date% / %codec%
  • Nitrius
That's mine (using Default UI, v0.9.5):
Where did you get the Artist/album mod?
Edit: Also where do i find a rating mod to the default ui?(like the one shown in @lextune post above)
Moderation: Moved your post to this thread.
  • Last Edit: 10 November, 2007, 03:08:00 PM by Nitrius
  • antiKk
To get Artist / Album Mod
Create a custom Column and use the following code:
$ifequal(%track%,1,[%artist% ],)$ifequal(%track%,2,[%album%]['('%date%')'],)$ifequal(%track%,3,[%__replaygain_album_gain%][ / %genre%],)
  • Jose Hidalgo
  • Banned
Hi everyone,
I have some questions related to the new 0.9.5, DefaultUI and Facets. So rather than opening a new topic I figured that maybe people here could answer me :
1/ Is there a way with 0.9.5 to get the Playlist View display the rating information column, with one to five stars per song ?
2/ Even better, is there a way to change the rating directly on the PlayList view ? (like in YouTube - hovering mouse over the stars changes rating, clicking enters rating - that would be awesome  ).
3/ Is there a way to replace the cursor icon in the seekbar with another icon ? (not in the prefs but by changing files for instance)
4/ Is there some kind of "peak-meter plugin" that would be somewhat customizable ?
5/ (sorry for this one) what's the difference between "random" and "shuffle" ?
Thanks in advance.
  • Last Edit: 12 November, 2007, 09:54:17 PM by Jose Hidalgo
Reply #30
Hi everyone,
I use:
$repeat($char(9733),%rating%)
for Rating "stars" in the Playlist view
or
$repeat($char(9733),%rating%)$repeat($char(9734),$sub(5,%rating%))
for filled/empty stars
I use the Quick Tagger to rate songs (context menu and/or keyboard shorcuts)
There is a Peak Meter component you can run in a Dockable panel
Random is random, shuffle works off of a set pattern.
  • Jose Hidalgo
  • Banned
Thanks nightfishing for all this useful information !
Regarding rating, I have entered your code (the second one) in Prefs > Playlist View > Rating, but I can't see any stars. I only see 5 small symbols, like unknown characters. I'm using all default foobar 0.9.5 fonts. Do I have to change something ? Thanks.
As for the quick tagger, it seems to work, but I have two questions :
- Can we have also the ratings displayed as stars rather than "1; 2; 3; 4; 5" ?
- Is it possible to access the ratings directly and not via a sub-menu "Tagging > Quick Tagger > Set <Rating> to" ? That would be great.
Thanks again, I'm making progress here !
Stars are dependent on the font (some have stars, some do not.) I use Arial Unicode which can be found with a little Googling.
The Rating tag needs to use numbers (1,2,3 etc). The tag then can be displayed graphically (with stars, hearts etc).
The quick tagger context menu is a bit "deep" for my liking, also, but I do not know any way around it. You can use keyboard shorcuts (I use shift+F3, shift+F4, shift+F5 etc).
  • Jose Hidalgo
  • Banned
Reply #33
Yep, I got Arial Unicode and it works. Thanks again nightfishing.
The side effect is that Arial Unicode displays text lines with more spacing than the default foobar font. And my screen is a small one...  so I have to reduce font size to 8, and at size 8 I can barely see the stars with Arial Unicode !  Who knows, maybe there's a topic somewhere listing the best "rating-compatible" fonts ?
Besides, why stars after all ? I've seen a very nice interface with just colored dots, plain and simple  So I'd like to understand the basics in order to find the code for given character out of a given font and display it as rating. For example, I understand that 9733 means "full star" and 9734 means "empty star", but how do you find these codes ? (the best would be some "font display software" that would give these codes directly, but does such software exist ?).
Oh, and an important question : how do you get that nice anti-aliasing all over your foobar ???  Is it Vista, or can you achieve the same thing with XP ? (no, I won't jump over to Vista just to get some fancy anti-aliasing even if it looks good  ).
  • Last Edit: 13 November, 2007, 01:34:59 PM by Jose Hidalgo
Reply #34
I ***think***
($char(9679)
is dots for "normal" Windows fonts.
I used dots with Columns UI where you could add color info into the string. (I don't believe that is possible with the Default UI).
I run XP, so the anti-aliasing is not a Vista-thing.
I do run Clear-Type, but other than that it is a default XP setup.
  • Jose Hidalgo
  • Banned
Reply #35
ClearType ? I didn't even know about it !  Now I've downloaded it and it just works. Isn't life beautiful ?
This is my current config with ClearType (work in progress) :
[a href="http://img213.imageshack.us/my.php?image=myfoobar01kg3.jpg" target="_blank"] ) :
$repeat($char(9608)  ,%rating%)$repeat($char(9480)  ,$sub(5,%rating%))
Another solution would be to have different colors between "full" and "empty" characters. But it seems that it's no more possible with the new Default UI ?
  • Last Edit: 13 November, 2007, 07:28:19 PM by Jose Hidalgo
Reply #36
1. Already answered...
2. It's not possible to use anymore custom toolbar buttons?  When right clicking the buttons, there used to be "customize"... has it moved to somewhere else?
  • Last Edit: 15 November, 2007, 08:37:15 AM by Tony Soprano
  • Frank Bicking
  • Global Moderator
Reply #37
I tried this but nothing happened?!
You of course have to switch to the created grouping pattern. Right-click on the playlist column headers.
Not in the default user interface.
Reply #38
Thanks.  Have been using foobar for years but I'm complete n00b with this syntax string stuff.
Was that part of Columns UI then? Is there any other way of doing that then?
  • Last Edit: 14 November, 2007, 04:50:22 PM by Tony Soprano
  • lextune
Reply #39
Yes it is part of Columns UI, and no there is no way to do it with the Default.
  • Last Edit: 14 November, 2007, 06:07:12 PM by lextune
foobar2000 + EAC + Burrrn = Happiness
  • Nitrius
Reply #40
Hi everyone,
I use:
or
Got the stars to show, but i have no clue how i set the rating?
  • Jose Hidalgo
  • Banned
Reply #41
Download a component called Quick Tagger and put it in your components folder.
Then start foobar, right-click on a track and you'll see "Quick Tagger" in the context menu.
You can also customize it to some extent via foobar preferences.
  • Last Edit: 14 November, 2007, 06:43:41 PM by Jose Hidalgo
  • Trappski
Reply #42
Here ya go:
Oh yea... and the Volume-indicator in the bottomright-corner is there as well...
  • Emon
Reply #43
Wow, that's fantastic, thank you.
Reply #44
How can I remove those disc numbers (like pointed in the screenshot) from the track number column? So it would be 01, 02, 03 etc. and not 1.01, 1.02, 1.03 like it's now (this happens only on double disc albums).
  • Last Edit: 15 November, 2007, 11:01:40 AM by Tony Soprano
Reply #45
@tony soprano
i use this one:
preferences > display > default UI > playlist view: new custom group:
%album artist% - '['%date%']' -$ifgreater(%totaldiscs%,01, '['Disc %discnumber%/%totaldiscs%']' -,) %album% '['%genre%']'
phiber
Reply #46
Thanks, that string code was what I was looking for. I have no idea how to make these from scratch but I have some understanding how to modify them, so I modified it:
%date% | %album% $ifgreater(%discnumber%,00, '('Disc %discnumber%')' ,)
Now it's exactly how I wanted it.
  • Last Edit: 15 November, 2007, 10:37:47 AM by Tony Soprano
  • Frank Bicking
  • Global Moderator
Reply #47
Unless you explicitly tag some files with Disc Number = "0" or "00", you can shorten this part to:
[ Disc '('%discnumber%')']
Reply #48
Yup, that was unnecessarily complicated. I asked this same thing on another forum and got this much simpler:
$if(%discnumber%,'('Disc %discnumber%')',)
Now I just want to remove those unnecessary numbers from the track number column (see my previous post with the pic, updated now). Anyone knows how?
  • Last Edit: 15 November, 2007, 11:01:10 AM by Tony Soprano
  • start78
Reply #49
As far as i know:
$if(%discnumber%,'(Disc '%discnumber%')',) =
$if($meta(discnumber),'(Disc '%discnumber%')',) =
['(Disc '%discnumber%')']
Would  $if2('(Disc '%discnumber%')',)  work the same way?
Btw: i got used to put all plain text in quotes because i think it's more strict. Or do i only have to put qoutes around brackets so they won't be confused with string brackets?
