Topic: Default UI Gallery (Read 787910 times) previous topic - next topic
Re: Default UI Gallery
Reply #650
foobar2000 1.6.18. Audio file organizer.
Reply #651
large
Reply #653
what title formatting are you using to display the cover size column?
[%front_cover_width%x%front_cover_height%]
But, because I still use version 1.6, I use an old version of this component - https://marc2k3.github.io/component/cover-utils/
Reply #655
Post here, if there is interest, a specific thread will open:
Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]
https://www.virustotal.com/gui/file/...615b?nocache=1
moderator: broken link removed
sha256:
695fc9fe6cc6e02edf811aed42c336a725eb8a87f6bd1117c32ba6e16ce7615b *Apache Evolution Theme 32 BIT [RC 03-08-2024 Public].7z
Updated Theme last fix
sha256:
4194c18af02dfd52d481abd43b81f3fe5afe3459907f3040f105e56c40c9d9ee *Apache Evolution Theme 32 BIT [RC 03-08-2024 Public] Theme.7z
Updated Radio last fix
sha256:
0f42b818add73a19ce80e5b457a5ba01af2ab8514cd06350058fb2a2c49615a4 *Radio.7z
Reply #656
sha256:
sha256:
Fix Link / Updated
https://mega.nz/file/my4UmI4S#obghwQZzCJxgGSCpuZ8jL22xrfUBZNVQYkhrm_e3j_w
sha256:
9b45fc603037cb11295197f57b4b37915f64c3b53613e682ea85917caa955618 *Apache Evolution Theme 32 BIT [RC rv2 03-08-2024 Public].7z
https://mega.nz/file/Pvo0gCSK#L6ZZfULhbGeCSvB75qV7DYokOFvmQ53n37LUiYNc8aA
sha256:
6d2fd651f7dd61a88e4f49aa94733f3d02d8bd48258d5316caeac80a067bbdfc *Radio updated.7z
Portable Mode
c:\foobar2000 Portable\Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]\
import DUI Theme
c:\foobar2000 Portable\Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]\foobar2000\profile\Apache\
Delete folder Radio and replace whit new folder Radio (Radio updated.7z)
Reply #657
Uploading standard Components, including the foobar2000.exe executable file, is prohibited.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Reply #658
I knew it.
I removed the main link, but no one will be able to use the theme at this point.
Reply #659
Users will prepare their own Portable installation foobar2000 forder.
It would be great if you could use it in this foobar2000 folder (profile folder).
This is helpful. It is ready to use right away.
Georgia-ReBORN
https://github.com/TT-ReBORN/Georgia-ReBORN
Reply #660
This link:
https://mega.nz/file/2jYnDaia#zLVH-1-de_WjJNBdGVIkgHlqrobmWaDg5Nkdi7OyZH4
contains only the profile folder
sha256:
a3aecad762883a7c026622249cfe005ed42172ce5eb2caf7239a21690f8b410c *Apache Evolution Theme 32 BIT [RC 03-08-2024 Public].7z
Let me know if it's okay.
Reply #661
This link:
sha256:
Some clarifications for the less experienced and non-experts.
For everything to work correctly it is better to respect the path and therefore proceed as follows:
1) download the foobar2000 32bit version from the official website (foobar2000 v2.2 preview 2024-07-07);
   https://www.foobar2000.org/download
2) install fooba2000 in portable mode following the path c:\foobar2000 Portable\Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]\;
3) extract the profile folder into c:\foobar2000 Portable\Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]\foobar2000\
4) do not update the foo_uie webview plugin, the version that uses the theme is foo_uie_webview v0.1.5.0-alpha4;
5) in preference webview, in user data folder path, enter the path C:\foobar2000 Portable\Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]\foobar2000\profile\foo_uie_webview
6) in preference webview, in template file path, enter the path C:\foobar2000 Portable\Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]\foobar2000\profile\Spin Disc.html
7) in c:\foobar2000 Portable\Apache Evolution Theme 32 BIT [RC 03-08-2024 Public]\foobar2000\ create an encoder folder so that the Convert Bar Codec & App module works correctly.
    https://www.foobar2000.org/encoderpack
I attach fonts and latest theme.
Reply #663
Nice one Apache  ;D  ;D  ;D
Reply #664
I would have also liked to do a 64-bit version.
But as said in another thread, if the m-TAGS plugin is not converted to 64 bit, due to how the radios are organized it is not possible.
Reply #665
I am also working on this problem of the radio playlist with my f2k 64bits . It's not perfect.
I have to download the image of the radio logo and assign the same name of the %artist% and %albumartist% in the properties .
It would be great to automate the process ?
Reply #668
finally honing in after ~15 years to my perfect jukebox experience
So unfortunate that FB v2 "dark" doesn't actually update component chrome?! :-X
If only I could upgrade the iframes in bios/reviews sections with proper webview file i/o @pqyt  ;)  :P
Reply #672
Can I post your theme?
Sure, I'm using  x86 v216 DUI.
Simplaylist and Facets (Library tab not shown in image) are not available for x64, but majority is x64 friendly.
Basically the pieces are already available in the forum.
One could recreate the layout and then in Jsplitter: Panel Properties>Import the json settings provided below.
I will try and add "biography remix" to the "made with webview" thread and more detail on the weekend.
You can hit me up here with any specific questions: https://hydrogenaud.io/index.php/topic,58686.0.html
Reply #673
First of all, thank you for your reply, and can I share your webview threading script?
Reply #674
I need your webview thread script for spinning disks, okay?
