Topic: Porting my toolbar to 0.9.5 (Read 4332 times) previous topic - next topic
  • NEMO7538
I have tested my QuickSearch Toolbar with 0.9.5 and it basically seems to work as an independent window (available from the Library Menu).
It was also working as a panel, and declared in this regard as an UI extension
(class quicksearch_extension : public ui_extension::window)
I would like to get some help in reimplementing it as a "native" toolbar that would thus be available in the standard UI as a toolbar or within/through a toolbar header in layout editing mode.
Thanks for your answer.
  • Last Edit: 21 October, 2007, 08:38:43 AM by NEMO7538
  • KalleGuld
I don't have an answer for you, sorry. But if you update your quicksearch, i'll be very happy. It's really a great plugin, and I can't have my Foobar without it. Luckily enough I can still open it in a seperate window, but that kills my beautiful config.
Good luck on converting.
