Inconsistent AccurateRip results?
Reply #9 – 2007-11-18 07:14:31
Here: different T&C crc but same AR crc:Exact Audio Copy V0.99 prebeta 1 from 25. May 2007 EAC extraction logfile from 30. June 2007, 13:22 Led Zeppelin / II Used drive : PLEXTOR DVDR PX-760A Adapter: 4 ID: 0 Read mode : Secure Utilize accurate stream : Yes Defeat audio cache : No Make use of C2 pointers : Yes Read offset correction : 30 Overread into Lead-In and Lead-Out : Yes Fill up missing offset samples with silence : Yes Delete leading and trailing silent blocks : No Used interface : Native Win32 interface for Win NT & 2000 Gap handling : Appended to previous track Track 3 Filename C:\EAC Rips\Led Zeppelin - II (Remaster)\03 - The Lemon Song.wav Pre-gap length 0:00:01.52 Peak level 100.0 % Track quality 100.0 % Test CRC 8B5A3B71 Copy CRC F915A77B Accurately ripped (confidence 60) [064518F0] Copy OK No errors occurred --- Exact Audio Copy V0.99 prebeta 1 from 25. May 2007 EAC extraction logfile from 30. June 2007, 13:30 Led Zeppelin / II Used drive : PLEXTOR DVDR PX-760A Adapter: 4 ID: 0 Read mode : Secure Utilize accurate stream : Yes Defeat audio cache : No Make use of C2 pointers : Yes Read offset correction : 30 Overread into Lead-In and Lead-Out : Yes Fill up missing offset samples with silence : Yes Delete leading and trailing silent blocks : No Used interface : Native Win32 interface for Win NT & 2000 Gap handling : Appended to previous track Track 3 Filename C:\EAC Rips\Led Zeppelin - II (Remaster)\03 - The Lemon Song.wav Pre-gap length 0:00:01.52 Peak level 100.0 % Track quality 100.0 % Test CRC 8B5A3B71 Copy CRC 8B5A3B71 Accurately ripped (confidence 60) [064518F0] Copy OK No errors occurred
