Topic: iPod Shuffle won't play Nero AAC (Read 29331 times) previous topic - next topic
  • verbajim
When I convert to AAC with Foobar2000 and the newest version of Nero Digital Audio (1.1.34.2) the files will not play on my iPod Shuffle (2nd generation). iTunes can play them fine, and when I use an older version of Nero Digital Audio (1.0.7.0) it also works on the iPod.
Does anyone know what causes this problem and if there is a work-around for it?
  • Last Edit: 27 September, 2007, 01:11:27 PM by verbajim
  • dyneq
Uh-oh!  I've got the same issue with my 2nd generation shuffle.  I have a 1st generation 30G iPod that can play the newer files, so would this be a firmware issue?
After searching around, I found this page from Apple.  I wonder what changed in the Nero encoder that broke things...
  • Last Edit: 27 September, 2007, 04:22:05 PM by dyneq
  • muaddib
  • Developer
Does this happen with all settings (LC,HE,HEv2) ?
  • verbajim
muaddib, yes, as far as I can tell. I had originally just used LC, but I've now tested with HE and HEv2 as well. But no luck there either. All settings work with 1.0.7.0.
  • muaddib
  • Developer
Thank you for reporting this. We will check what is the problem as soon as possible.
  • dyneq
Thanks very much!  I only use LC (-q 0.35), but can test the others if needed.
  • menno
  • Developer (Donating)
Maybe try if the optimise option of mp4creator helps in any way?
  • dyneq
I visited the MPEG4IP download page, but it looks like only source code is offered?
Where can I download mp4creator for win32?
  • Teqnilogik
Try using the Optimize MP4 utility in Foobar2000.  If you don't have the option, reinstall Foobar2000 and do a Full install.  Just right-click the files and select Utils and click Optimize MP4.
  • dyneq
Thanks for that.  I didn't even know fb2k had that!
I ended up finding the compile through an old link to it at rarewares.  Optimizing it did allow the file to be played on the shuffle.
  • menno
Ok thanks. That already helps a lot, I will try to figure out what is the exact problem. AFAIK the files we encode come out "optimised", so something else in our mp4 library must be causing this.
  • Squeller
What exactly does "optimize" mean here?
OK, found it myself. FB2K says: "Puts tagging data at the beginning of specified mp4 files and strips away any unused blocks"
  • Last Edit: 02 October, 2007, 02:04:00 AM by Squeller
  • menno
Indeed, but the data we write is already at the beginning of the file, so there must be something else in our files that cause this.
  • dbAmp
Was this problem ever solved?
  • menno
Sorry, lost this thread somehow
Well, we did some testing and it seems that the iPod Shuffle (2nd generation) only reads MP4 descriptor (some sort of info blocks inside a mp4 file) sizes that are written in 4 bytes. We always write the minimal amount of bytes.
We are checking if we should just write it in 4 bytes always also.
Seems the only affected device is the 2nd generation iPod Shuffle.
  • alanw
I am having the same problem. I have used the "optimize mp4 layout" on FB2K but the files will still not play on my shuffle (2nd generation). Can anyone suggest anything else to try?
  • dbAmp
Did you make sure to force the encoder to use the low complexity profile (-lc) in your command line? The iPod Shuffle 2nd Gen won't play HE-AAC even if it's been optimized.
  • alanw
Yes, all files are lc (-q 0.5).
  • Numaios
The same thing happens to me...
Any idea of when a new version of Nero AAC encoder is coming? Until then, should we use version 1.0.7.0 instead of 1.1.34.2 + OptimizeMP4?
  • MMongeau
I came across this post while researching the same problem.  I just bought two 2nd Generation iPod Shuffles and found that AAC files created with Nero AAC Encoder 1.1.34.2 would not play on them.  I tried the Optimize feature of Foobar2000 - no luck. Same thing with a similar feature in Mp3Tag.
After more searching I found this troubleshooting page for the Roku Soundbridge network music player:
http://www.rokulabs.com/support_sb_ts_playback.php
In the item about AAC files locking up it references a command line utility that is part of the mpeg4-ip utilities available at RareWares.org.
  http://www.rarewares.org/files/mp4/mpeg4ip...s-1.4.15cvs.zip  (Windows version)
I wanted a command line utility since I have automated the conversion of my FLAC files to AAC.  I downloaded the tools, used the command "mp4creator -optimize file.m4a" and the files now play just fine on the Shuffle!  Yeah!!  Now I don't have to re-encode my 5,000 FLAC files with another encoder.  Decided to post this solution here in case anyone else encounters the same problem.
  • menno
You could also use Nero 8.3.2.1, for example the Encode Files dialog, to encode, the encoder included with this version has the problem solved.
(shortcut: Nero.exe -Dialog:EncodeFiles)
  • Numaios
The Optimize feature of dBpowerAMP Music Converter did work for me!
-Has Nero 8.3.2.1 the same core as in free encoder v1.1.34.2?
-Any idea of when an updated version of the free CLI encoder will be released?
-Are these issues also fixed in Nero 8.3.2.1?
  • muaddib
  • Developer
List of bug fixes can be found here: http://www.hydrogenaudio.org/forums/index....mp;#entry553898
This year  It is very hard to tune high bitrates, because there are not many people that can hear problems there. But yet, we don't want to release a version where again somebody would appear and notice some problem which didn't exist in previous versions.
Those issues are not fixed in Nero 8.3.2.1, but also have in mind that there are some quality issues in February release which sound better in August version, like these:
http://www.hydrogenaudio.org/forums/index....mp;#entry554993
  • Numaios
Thanks muaddib for your explanations
So (please correct me if I'm being too simple), should we use Feb version for classical music and Aug version for other music styles?
  • Buckchoi
Is there any way to use the encoder in 8.3.2.1 via command line, so I can use it in Foobar2000?
