Topic: Album Art Downloader XUI (Read 1367162 times) previous topic - next topic
Reply #2000
Would it be possible to add a script for this site?
Hmm... could be a tricky one, I can't see any way of searching for a specific artist and album at the same time, which makes it harder. Once the page for the album is found, it wouldn't be hard to get the images for it though. I'm off on holiday for a week now, so won't be able to take a look at this until later.
Alex
Reply #2001
Have a nice holiday!
Reply #2003
The script is not finding any art for singles. It works for LPs.
Could this site be added as well? http://www.45cat.com/
(Yes, I am back upgrading cover art for singles and singles cover art for individual tracks in compilations.)
Reply #2004
The script doesn't try and make any distinction - can you give me an example of a single with art that it should have found?
45cat should be possible, I'll have a go at that later today, or maybe tomorrow.
Alex
Reply #2005
I think I tried with:
Gene Austin   Without You Sweetheart
Clif Bruner   Born To Be Blue
and two others that I cannot remember now.
Via the "Preserved Recordings" page you can find singles that has cover art.
Thanks for trying to add 45cat!
Reply #2007
Which archive did you find them in? I'm searching University of Texas at Austin Historical Music Recordings and Bowling Green State University, as those seem to be the only ones with cover art for LPs.
I found them on the Audio Preservation Fund site itself, for example http://audiopreservationfund.org/acquisiti...gles&id=265 (Click on one of the small images and you will get a very large image.)
Reply #2009
I've used a few times the .NET Framework Cleanup Tool to repair corrupted .NET installations with success. I don't know if it will help with WIC problems but it's worth a try if everything else fails.
Thanks for the suggestion but no joy.
I ran the clean up app which removed .Net from my system.
I then did a fresh install of .Net 3.5
This time AAD just crashed (error below).
Just to be sure I tried installing WIC again but the same error about me having a later version came back.
This is comfirmed by WIC.log (below).
I am guerssing that XP SP3 contains a non-uninstallable version of WIC 6.3.4.0 and this is incompatible with AAD
WIC error log...
0.219: ================================================================================
0.219: 2011/09/23 11:24:34.578 (local)
0.219: d:\ca95abc5e30f90d3f3348a\update\update.exe (version 6.3.4.0)
0.219: Hotfix started with following command line:
0.250: In Function GetBuildType, line 1170, RegOpenKeyEx failed with error 0x2
0.375:  C:\WINDOWS\system32\WindowsCodecs.dll is Present
0.422: FileVersion of C:\WINDOWS\system32\WindowsCodecs.dll is Greater Than 6.0.5840.16388
0.422: Condition Check for Line 1 of PreRequisite returned FALSE
0.454: WIC Setup encountered an error:  Newer version of update is already on the system.
0.500: Newer version of update is already on the system.
65.438: Message displayed to the user: Newer version of update is already on the system.
65.438: User Input: OK
65.438: Update.exe extended error code = 0xf0f4
65.438: Update.exe return code was masked to 0x643 for MSI custom action compliance.
AAD error:
Album Art Downloader has encountered a fatal error, and has had to close.
If you wish to report this error, please include this information, which
has been written to the file: C:\Program Files\AlbumArtDownloader\errorlog.txt
App version: 0.42.1.0, running on Microsoft Windows NT 5.1.2600 Service Pack 3 (32 bit)
System.Windows.Markup.XamlParseException: Cannot create instance of 'BrowserResults' defined in assembly 'AlbumArt, Version=0.42.1.0, Culture=neutral, PublicKeyToken=null'. Exception has been thrown by the target of an invocation.  Error at object 'System.Windows.Controls.Grid' in markup file 'AlbumArt;component/filebrowser.xaml'. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'AlbumArtDownloader.BrowserResults' threw an exception. ---> System.NotSupportedException: No imaging component suitable to complete this operation was found. ---> System.Runtime.InteropServices.COMException (0x88982F50): Exception from HRESULT: 0x88982F50
  --- End of inner exception stack trace ---
  at System.Windows.Media.Imaging.BitmapEncoder.EnsureUnmanagedEncoder()
  at System.Windows.Media.Imaging.BitmapEncoder.get_CodecInfo()
  at AlbumArtDownloader.BrowserResults.<GetSupportedCodecs>d__8.MoveNext()
  at System.Linq.Enumerable.<SelectManyIterator>d__31`3.MoveNext()
  at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
  at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
  at AlbumArtDownloader.BrowserResults..cctor()
  at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck)
  at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache)
  at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache)
  at System.Activator.CreateInstance(Type type, Boolean nonPublic)
  at System.Windows.Markup.BamlRecordReader.CreateInstanceFromType(Type type, Int16 typeId, Boolean throwOnFail)
  at System.Windows.Markup.XamlParseException.ThrowException(String message, Exception innerException, Int32 lineNumber, Int32 linePosition, Uri baseUri, XamlObjectIds currentXamlObjectIds, XamlObjectIds contextXamlObjectIds, Type objectType)
  at System.Windows.Markup.XamlParseException.ThrowException(ParserContext parserContext, Int32 lineNumber, Int32 linePosition, String message, Exception innerException)
  at System.Windows.Markup.BamlRecordReader.ThrowExceptionWithLine(String message, Exception innerException)
  at System.Windows.Markup.BamlRecordReader.GetElementAndFlags(BamlElementStartRecord bamlElementStartRecord, Object& element, ReaderFlags& flags, Type& delayCreatedType, Int16& delayCreatedTypeId)
  at System.Windows.Markup.BamlRecordReader.BaseReadElementStartRecord(BamlElementStartRecord bamlElementRecord)
  at System.Windows.Markup.BamlRecordReader.ReadElementStartRecord(BamlElementStartRecord bamlElementRecord)
  at System.Windows.Markup.BamlRecordReader.ReadRecord(BamlRecord bamlRecord)
  at System.Windows.Markup.BamlRecordReader.Read(Boolean singleRecord)
  at System.Windows.Markup.TreeBuilderBamlTranslator.ParseFragment()
  at System.Windows.Markup.TreeBuilder.Parse()
  at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
  at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
  at AlbumArtDownloader.FileBrowser.InitializeComponent()
  at AlbumArtDownloader.FileBrowser..ctor()
  at AlbumArtDownloader.App.ProcessCommandArgs(String[] args)
  at AlbumArtDownloader.App.OnStartup(StartupEventArgs e)
  at System.Windows.Application.<.ctor>b__0(Object unused)
  at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
  at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
  at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
  at System.Windows.Threading.DispatcherOperation.InvokeImpl()
  at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
  at System.Threading.ExecutionContext.runTryCode(Object userData)
  at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
  at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
  at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
  at System.Windows.Threading.DispatcherOperation.Invoke()
  at System.Windows.Threading.Dispatcher.ProcessQueue()
  at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
  at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
  at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
  at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter)
  at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg)
  at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
  at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
  at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
  at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
  at System.Windows.Threading.Dispatcher.Run()
  at System.Windows.Application.RunDispatcher(Object ignore)
  at System.Windows.Application.RunInternal(Window window)
  at System.Windows.Application.Run(Window window)
  at System.Windows.Application.Run()
  at AlbumArtDownloader.App.AlbumArtDownloader.IPriorInstance.Run()
  at AlbumArtDownloader.InstanceMutex.RunAppAsServiceHost(IPriorInstance instance, String channelUri)
  at AlbumArtDownloader.App.Main(String[] args)
Reply #2010
@spile:I can confirm that the AAD error log is indicating the same problem. Is anyone else running AAD successfully on XP SP3? If so, it would be really useful to know the version number of C:\WINDOWS\system32\WindowsCodecs.dll that you have!
@vagskal:Here's a script for 45cat to try out: 45cat.boo. It doesn't look like 45picturesleeves.com has a search function, and I don't really fancy writing one for them. LP art is probably niche enough that two scripts are enough anyway :-)
Alex
Reply #2011
Thanks! You are fast.
I think that the 45cat script finds too much. It is like it is not restricting the search to releases by the artist you search for. Perhaps it is a limitation of the search function on the site.
Is the Chartstat script working? It never finishes.
Reply #2012
The search I'm using for 45cat is just "artist name" "album name". According to the instructions on the advanced search page, using quotes should make it search for the phrase, but I don't really see any evidence of that, unfortunately. I don't understand how some of the results it's returning are chosen at all!
Chartstats is working fine for me, maybe it was a temporary problem? Or the specific thing you were searching for?
Reply #2013
Alex, Thank you for this wonderful program!
I am running on XP SP3 without any problems.
windowscodecs.dll v6.0.6001.17009
windowscodecsext.dll v6.0.6001.17009
Glass half full!
Reply #2014
Works fine here: XP Pro SP3 - WindowsCodecs.dll v6.0.6001.22211
Alessandro
Reply #2015
Thanks for these! I've got hold of a Win XP CD and tried it out on a fresh blank virtual machine. After installing SP3 and .Net 3.5 through Windows Updates, I have WindowsCodecs.dll v6.0.6001.17009 too. I don't know how mobyduck got a newer version, but can you check what version you have, Spile?
Reply #2017
see here.
Oh, nice find! It's got to be worth having a go at downloading and installing that, Spile. If it's newer than the version you've got, it might overwrite your broken installation with a new one, which might then work. That's a lot of 'might', but not a lot of other ideas going around at the moment.
Alex
Reply #2018
@mobyduck
Is there something that you need in the newer versiona or can you simpky go to the older version which seems to be the current standard.
Glass half full!
Reply #2019
Sorry, I'm not sure I understand... As I said, I don't know how I got that version but if it ain't broken why fix it?
Alessandro
Reply #2020
But you are reporting that it is broke with AAD. Using the standard version may solve the problem!
Glass half full!
Reply #2021
Nope, Spile is complaining: I have zero problems with AAD.
Alessandro
Reply #2022
I downloaded and installed the hotfix above.
Have also updated my graphics card drivers to latest version.
Installed version 0.42 of the application.
Program launched and then immediately creashed (error below)
Checked Windows codecs and they are 6.0.6001.22211
Reply #2023
hi Alex
not sure if it's not just me again, but discogs doesn't find anything at all these days. maybe the script needs to be updated?
thanks in advance
Reply #2024
also, I think all iTunes images are now restricted to 600x600? wonder what's that about and is there any way to fix it, cause it's VERY unpleasant
