I have not used AAD for a while and when I tried it today I got this error message:
Album Art Downloader has encountered a fatal error, and has had to close.
If you wish to report this error, please include this information, which
has been written to the file: C:\Users\Xx\AppData\Local\Temp\AAD_errorlog.txt
App version: 0.41.1.0, running on Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
System.Configuration.ConfigurationErrorsException: Det gick inte att initiera konfigurationssystemet ---> System.Configuration.ConfigurationErrorsException: Rotelementet saknas. (C:\Users\XX\AppData\Local\AlbumArtDownloader\AlbumArt.exe_Url_1zgksjkmmjcisnmrjqjtxoq5srobf12i\0.41.1.0\user.config) ---> System.Xml.XmlException: Rotelementet saknas.
vid System.Xml.XmlTextReaderImpl.Throw(Exception e)
vid System.Xml.XmlTextReaderImpl.ParseDocumentContent()
vid System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors)
vid System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
--- Slut på stackspårning för interna undantag ---
vid System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
vid System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
vid System.Configuration.ClientConfigurationSystem.OnConfigRemoved(Object sender, InternalConfigEventArgs e)
vid System.Configuration.ConfigurationManager.GetSection(String sectionName)
vid System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
vid System.Diagnostics.DiagnosticsConfiguration.Initialize()
vid System.Diagnostics.DiagnosticsConfiguration.get_IndentSize()
vid System.Diagnostics.TraceInternal.InitializeSettings()
vid System.Diagnostics.TraceInternal.TraceEvent(TraceEventType eventType, Int32 id, String format, Object[] args)
vid AlbumArtDownloader.App.Main(String[] args)
Is there anything that can be done?
