Topic: Album Art Downloader XUI (Read 1291829 times) previous topic - next topic
  • ton
Reply #1475
If you've already got the latest versions of the scripts, then please let me know the artist and album you were searching for, and which scripts were not returning any results, and I'll look into it for you.
Alex
Thanks for your reply.
I updated the scripts but that does not help. Btw, I said that I sometimes get results but on second thought I think that that probably were local files.
It doesn't matter what album or artist I search for. Even when I enter, for instance only, artist "Bob Dylan" (without quotes of course), nothing is found. I see the progress bar on all search engines for some time, then all stop and no covers are shown.
Because I saw that .NET Framework 4 is installed on my pc, I even uninstalled it and installed 3.5, but that doesnt help either.
Moreover I have this problem on my wife's pc and my laptop as well, both with Windows 7. (I also tried running AAD in Windows XP compatibility mode).
  • AlexVallat
Reply #1476
XP Compatibility mode should not be turned on, AAD is developed under Windows 7 and requires no compatibility flags. From what you are describing, it looks like AAD is not able to download data from the internet. Do you have firewall software which might be blocking it? Or do you use a proxy server to connect to the internet?
  • ton
Reply #1477
I don't use a proxy server and only have Windows Firewall. I tried it with Windows Firewall disabled, but that didn't make a difference.
But meanwhile I did get results sometimes but very randomly. Maybe 1 out of of 7 of 8 attempts I almost immediately get covers for a certain album, but the other times nothing is returned for the same album.
  • AlexVallat
Reply #1478
Let's take this out of the thread - I've sent you a PM. If we come up with a solution of general interest I'll post it here too.
  • Brand
Reply #1479
Does .NET Framework 3.5.1 under "Windows features" in Win 7 need to be turned on for this to work?
I've never had problems with other programs that need .NET otherwise with that thing disabled.
  • AlexVallat
Reply #1480
I would have thought so. It is a .net 3.5 application after all. Of course, if you've managed to get it to work without that feature turned on then I'm not going to argue the point!
  • Brand
Reply #1481
I've enabled that and it's working now!
  • icon123
Reply #1482
Nevermind - This is a great program!
  • Last Edit: 30 October, 2010, 11:22:36 PM by icon123
  • AlexVallat
Reply #1483
Album Art Downloader XUI v0.37 Released
This release fixes up some scripts, and adds a couple of requested command line parameters:
/new ensures that a new window is opened by the command line. If this isn't specified, and you have "Open search results in new window" checked, and there is only one window open, then that window would be replaced by any new search initiated by the command line.
/minimized makes any window shown by the command line start minimized. It doesn't affect already open windows.
/config opens notepad showing your Album Art Downloader user.config file. This is just a shortcut to avoid having to search for the file under %LOCALAPPDATA%\AlbumArtDownloader manually. Generally, you shouldn't need to change anything in this file directly.
However, I have added a new hidden setting which can be enabled by editing the user.config file, called UseSystemCodepageForID3Tags. The ID3 specification states that tags must either be in Unicode, or Latin1 encoding. Unfortunately, some software produces incorrect tags, encoding them with the system codepage instead. This isn't a problem if your system codepage is Latin1, but if you're running a different locale version of Windows, then it's likely to be your locale-default codepage, not Latin1.
Basically, if you're running non-English Windows, and tags you've saved are showing up mangled or with invalid characters when read by the File Browser in Album Art Downloader (and you don't want to fix whatever software you are using to write these tags that's doing it wrong), then you can search for this property in the user.config file and change it from False to True. This will fix the display of those tags, but may mean that tags in files which have been written correctly in Latin1 may show up mangled or with invalid characters.
(Also: this is the first release since I moved to using Visual Studio 2010 for development, but it still targets .NET 3.5, not 4.0, so it shouldn't mean any changes for users.)
Download:
AlbumArtDownloaderXUI.exe (Installer. Recommended)
AlbumArtDownloaderXUI.zip (zip archive for those who don't like installers)
.NET Framework 3.5 SP1 (required, except for Windows 7)
  • iQwerty
Reply #1484
Is it possible to let the program just download the first lastfm cover it finds?
Because with this run command:
"C:\Program Files\AlbumArtDownloader\AlbumArt.exe" /ar "%artist%" /al "%album%" /mn 300 /mx 1000 /s "LastFM Cover" /path "$replace(%_path%,%_filename_ext%,)cover.jpg" /t f /autoclose
I basically always find the correct cover. Would be nice if the process could be automated for my whole library, instead of having to run it for every album and hit save each time
Do YOU hear the difference? www.mp3ornot.com
  • AlexVallat
Reply #1485
Yes, if you're feeling lucky. Start the file browser, or foobar browser from within AAD, and make sure it can find all your albums. Once you've selected all the albums you want to automatically get the first lastfm cover for, check that the option "Automatically download and save the first result that meets set criteria" is selected (click the options link to show it). From your command line, you want the image to be called cover.jpg, so in the "Specify path to find images" box, remove the "Folder%preset%.%extension%|" so that just the "Cover%preset%.%extension%" part remains (you can put the Folder part after the Cover part, if you like, so it will also look for Folder.jpg when checking if there are existing images - the important thing is that the start of that string is the name you want the images to be automatically saved as, in this case "cover").
Then, click the Get Artwork for Selection button, and the automatic image downloader window will appear.
In this window you can set the minimum and maximum size for the image to 300 and 1000, like your command line, and make sure only the LastFM Cover source is checked on the list of sources on the right. Hit the Start button, and let it do its thing.
Alex
  • iQwerty
Reply #1486
Alex
Amazing!!! Just downloaded about 300 covers with a single click!!!
Thanks for this program, really made my music library even better!
  • Jedi82
Reply #1487
and what about mac users?
  • AlexVallat
Reply #1488
Out of luck, I'm afraid. Mono might someday gain WPF libraries, and if it does, they might just run on Mac OS too, in which case it could potentially be possible to run it on a Mac. I wouldn't count on it, though. Certainly there won't be any official support for it on Mac OS from me - I won't ever own a Mac, or develop specifically for one.
Alex
  • tuxman
Reply #1489
[pointless flame]
As always. That's what they chose.
[/pointless flame]
Thanks for your great work, I still like your continuous improvements.
audiophile // FLAC and Vorbis user // Winamp addict
  • the_miker
Reply #1490
Hey Alex,
Can you see if something changed on VGMdb's end?  I'm not getting any results from their site no matter what I search for.  I've tried it with and without login credentials in the vgmdb.boo file.  No errors or anything in AAD, the search just comes up empty every time.
  • AlexVallat
Reply #1491
Argh, wish I'd spotted that before releasing 0.37. I've put up an updated script that should fix it. You'll have to re-enter your username and password into it after it updates, though.
  • the_miker
Reply #1492
That fixed it.  Thanks man!
  • sle118
Reply #1493
Alex, I took the latest version which created a problem with the save location.  When launching the program from the context menu, images are no longer saved under the directory where music file was found.
Any hint on how to fix this?
  • AlexVallat
Reply #1494
Could you tell me what you have in the box "Specify path to find images" in the File Browser window? (click the Options link to show it). There was a small fix in the behaviour of paths with ".." in them when file path pattern matching was enabled, but this shouldn't have caused the issue you describe.
Alex
  • sle118
Reply #1495
This is odd.
Here is what was the problem
  • Right click on a folder (context menu)
  • Choose Browse for album art...
  • Select the album where artwork is missing and click get artwork for selection
  • The default save folder is user\picture\...
I tried again this morning, and now in place of the default folder I see "This path was set automatically from the browser..."
So all is back to normal; false alarm.
thank you!
p.s. You should have a donation link somewhere. This would allow me to pay you a beer or something.
  • AlexVallat
Reply #1496
Glad it's back to working again now. There's a Donations link under the Help menu; I don't want to be too pushy about it, but I think I'll put one on the first post of this thread too. Any beer money is gratefully received here: donations
Thanks,
Alex
  • sle118
Reply #1497
You could just embed a paypal icon somewhere in the app. It's so useful I think it would encourage people to contribute.  I am a developer myself and have a sense of how many hours were spent on this.
You live in the UK? Life is expensive there (I lived in Beaconsfield for about 8 months) so I tried giving enough for a trip to the pub.
cheers
  • AlexVallat
Reply #1498
Thanks, I appreciate it!
I'd consider having a graphical paypal donation button in the installer, but not in the app itself. I think it looks awful, and dislike seeing it in other apps I use - so it would be hypocritical of me to include it in my own. Even the menu entry can be easily removed if it offends, just hover the mouse over it and press the delete key.
Alex
Reply #1499
Great app, have been using it since it first came out.
However, something seems to have broken with the latest 0.37 release - Foobar integration no longer works. I've made sure I have the latest version of the COM server files installed and the latest Foobar, and tried uninstalling and reinstalling both Foobar and AAD - 0.37 just gives me a fatal error, followed by the logs, when I click File -> New -> Foobar browser. Can post logs on request. 0.36 works fine.
