Topic: timestamp %added% only for files without this tag? (Read 5574 times) previous topic - next topic
i want to timestamp my files with the tag ADDED when added to db but only if this tag dont exist, so i did following mass tagger script:
Time Stamp: NoW
Format "ADDED" using "$if($greater($len(%ADDED%),5),%ADDED%,%NOW%)"
Remove "NOW"
and added this to new files tagger. seems to be ok, doesnt it?
but it doesnt worked, cause i did a fault:
*external hdd wasnt plugged in
*update db --> all files from external hdd deleted from db
* plugged in external hdd
*update db --> all files are added to db and also get currend date/time as added stamp
so maybe someone now a better way to detect if %ADDED% exist and dont overwrite it then?!?
This is what i use. Should work.
Time Stamp: DATE ADDED_TEMP
Format "DATE ADDED" using "$if(%DATE ADDED%,%DATE ADDED%,%DATE ADDED_TEMP%)"
Remove "DATE ADDED_TEMP"
If there is already DATE ADDED tag. it will format from itself and romove new time stamp (DATE ADDED_TEMP).
If not, it will format from DATE ADDED_TEMP then delete them.
so $if2(%DATE ADDED%,%DATE ADDED_TEMP%) should also work?
if a tag exists, it returns true and if it not exists it returns false, right?
yes.
i know what I was doing wrong... I was doing guess instead of format for the comparison hence it didnt work.. now it works a charm!!!
thx guys
One question. Why do you create a temp-tag first and delete it later?
Maybe I'm wrong, but isn't this possible and delivers the same result?
Format "DATE ADDED" using "$if2(%DATE ADDED%,%cwb_systemdate%)"
Masstagger doesn't recognize %cwb_systemdate%
Sorry, Just saw this.
