Topic: decoding offsets & wave compare util (Read 3401 times) previous topic - next topic
Decoding the same .mp3 with lame, cdex and winamp gives different size .wav files (with lame's decode being the smallest).
I can't hear any difference between the .wav's, and I take it the difference might have to do with lame's info line "skipping initial 1105 samples (encoder+decoder delay)".
Now the question... Using a wave-compare utility (WAVComp from http://players.shoutclub.com/wavdownload/), the lame decode appears to be best "synchronized" with the original. Meaning that after encoding a .wav to .mp3 and then decoding it back with lame --decode, WAVCompare reports 250 "error mean bits". Comparing the .wav decoded by winamp gives 4000 error mean bits - problem being that WAVComp does a brute sample-by-sample compare from time 0 on.
Does anybody know of a smarter wave-compare able to detect slight time-shifts between two .wav files and find a "best fit" before comparing?
P.S. This is just lab work, please don't flame about the pointlessness of comparing .wav bits.
Perhaps this site might give you some useful information:
http://privatewww.essex.ac.uk/~djmrob/mp3decoders/index.html
Daffy
Edit:  Oops...sorry if this doesn't answer your question about a .wav compare utility.....I just thought you might be interested in these decoder tests
This doesn't answer my question, indeed - all 3 of them (lame, cdex, winamp) have perfect scores there ;-)  Thanks for the pointer, anyway.
And, yes, forgot to mention... I tried EAC's wave-compare function but it reports the whole .wav's as different - which is correct, but doesn't help, either.
