Topic: WMPCDText - CD-Text plug-in for Windows Media Player (Read 201742 times) previous topic - next topic
  • Tim De Baets
  • Developer
Reply #50
If the title has been actually written to the CD as "CD Text Test Disc", then that indeed sounds like an issue with WMPCDText.
Is the 'convert caps' option still unchecked in WMPCDText's settings?
Which program did you use to burn the CD?
In CDex, please open the CDDB menu and choose Read CD-Text to make sure that it's the actual CD-Text that you're seeing. What's the exact title that is shown there?
  • dbminter
Reply #51
Convert caps option is still enabled right now.  I changed it back to being checked after one of the last replies.
The CD was created by, and the CD Text inserted by, ImgBurn.  (I'm a beta tester for that software.  )
CDex returns the Track name as "CD Text Test Performer Track: Village People / Cd Text Test Title Track 1: In The Navy"
Ah, ha!  Perhaps, I made a typo when typing in the text and that it really is "Cd Text Test" on the disc instead of "CD Text Test."  I will recreate the test disc and make sure I type it in correctly this time.
  • Last Edit: 21 July, 2011, 05:02:08 PM by db1989
  • dbminter
Reply #52
I MUST have made a typo before.  I recreated the disc making sure the necessary capitals were capitals.  CDex returned the CD Text I was expecting.
  • Tim De Baets
  • Developer
Reply #53
Aha, that explains a lot
Just to be sure, does WMPCDText also show the expected CD-Text now? (you may have to use the Read CD-Text context menu option again to force a re-read).
  • dbminter
Reply #54
Yes, it shows the correct text.  I can't get the garbage text anymore, no matter how many times I use the context menu option.  My guess is it maybe returns this garbage text the first time the plugin is used?  Or the first time a disc is read?  I don't know.    I can't get a repeat of the junk text anymore, so, I can't test it anymore.
  • Tim De Baets
  • Developer
Reply #55
I did some more tests on my Windows 7 system, but never got any garbage text either, not even on first plug-in use or the first disc read. Oh well
  • dbminter
Reply #56
Yeah, it's weird as I got garbage text when I first tried the plugin on 2 computers.  A custom built one from 2009 and a new Dell XPS 8300 that I got last week.  As long as the plugin works with Read CD-Text context menu, that's all that matters, anyway.    Besides, neither of us can replicate a similar result, so, there's no way to test anything.
  • dbminter
Reply #57
One thing I have noticed with the plugin installed.  Whenever I open video files, like AVI, WMP opens with a sub window opened for displaying the options for the WMPCDText plugin along with the window displaying the video.
  • Tim De Baets
  • Developer
Reply #58
Are you using the 64-bit version of Windows 7? If so, then this is probably a known bug in WMP that you're seeing. My Windows Media Player Plus! plug-in already includes a fix for this bug, so I suggest that you try installing that. You can uninstall the plug-in again afterwards if you don't need it - the fix will stay on your system.
  • Last Edit: 27 September, 2011, 03:32:44 PM by Tim De Baets
  • dbminter
Reply #59
Yes, I am using the 64 bit version of Windows 7.  I was not aware of this.
Reply #60
Minor enhancement I'd like to suggest: Ability to read Composer (or Songwriter, if Composer is blank). While WMP doesn't display Composer in the list pane, it can be accessed by right-clicking on a track and selecting Properties - Content when CD media information has been obtained from online database, or when playing an MP3 disc with ID3 tags.
I don't yet know if WMPCDText can read Genre because my burning software has no provision for adding that, but that's also desirable.
  • Tim De Baets
  • Developer
Reply #61
WMPCDText should already read Composer from CD-Text, doesn't it do that for you? It also reads Songwriter and tries to fill this into WMP's Writer field, but this probably fails because that field isn't available for CD tracks. Using Songwriter if Composer is blank is a decent suggestion, although they're technically a different thing.
WMPCDText should already read Genre correctly as well.
Reply #62
Thanks for responding. It was a glitch with Cyberlink Power2Go burning software all along. I like your plug-in even better now!  :)
  • Last Edit: 18 October, 2011, 09:06:39 PM by preservationist
Reply #63
Burning software I'm using allows Comments, presumably equivalent to keyword MESSAGE described in Wikipedia article on CD Text. I just found that this plug-in allows such comments to be displayed as captions, if you set "Lyrics, Captions, and Subtitles" to "On if Available" (in WMP 11 under Play menu, which is only visible if you select View Classic Menus). Cool!
  • gabrus
Reply #64
Hi, i have just now installed WMPCDText, but in my system seems to be that doesn't work.
The installer says that all is ok, but i can't see "Read Cd-Text" in any submenu of Media Player and in Media Player options i see that the plug-in is installed.
My system is Windows 7 Service Pack 1, and Windows Media Player 12.0.7601.17514.
  • Last Edit: 12 January, 2012, 09:33:19 AM by gabrus
  • Tim De Baets
  • Developer
Reply #65
Did you install the latest version of WMPCDText (1.2)?
The Read CD-Text menu item should appear when right-clicking a CD track in WMP's Play pane on the right. See this screenshot:
The menu item should also be available when right-clicking a CD track in WMP's Now Playing mode.
  • gabrus
Reply #66
Yes, software is 1.2 version, and i can't see the text menu as the screenshot: it appear as normal, when WMPCDText is not installed, but in options say that is installed
The software needs some particular service to be running? I have disabled some services in autostart...
  • Last Edit: 12 January, 2012, 06:20:55 PM by gabrus
  • Tim De Baets
  • Developer
Reply #67
Please check if WMPCDText is loaded in WMP - it should be listed in WMP's Tools - Plug-ins menu, and should have a checkmark next to it (press Ctrl+M if you don't see the Tools menu).
Are you sure that you're right-clicking the track of an actual audio CD (and not, for example, the track of a data CD containing MP3 files)?
If you use Windows Explorer to go to WMP's Program Files folder (the same folder where wmplayer.exe is located), do you also see a wmp.dll file there?
No, disabled services shouldn't be causing this problem.
  • gabrus
Reply #68
Yes, i have WMPCDText loaded in Options > Plug-in and also in right click > Tools > Plug-in with checkmark enabled. Also in have the wmp.dll in "C:\Program Files\Windows Media Player". It's really strange, i have formatted just from one week my pc from Xp to Seven, and when i have XP in the past no problems with the plugin: it was working perfectly
Just one small thing: Media Player is in Italian, but i think this is not a problem...
  • Last Edit: 13 January, 2012, 04:11:16 PM by db1989
  • Tim De Baets
  • Developer
Reply #69
Weird. An Italian WMP shouldn't be a problem either.
I will prepare a special debug version of WMPCDText for you to try. When it's ready (somewhere later this weekend), I'll PM you the download link. Or if you prefer e-mail, PM me your e-mail address first.
  • gabrus
Reply #70
Very thanks, i really appreciate your work, and also i loved this plugin: i seriously hope that i can use again with windows 7... u can pm when the debug version is ready, i will answer soon
  • gabrus
Reply #71
I'm really glad to say that the plugin works now for me also. Very thanks for it and for the support also.
  • Last Edit: 16 January, 2012, 11:08:53 AM by gabrus
  • Tim De Baets
  • Developer
Reply #72
You're welcome
gabrus's issue turned out to be a problem with non-English versions of WMP 12 after all: in those versions, the Read CD-Text menu item is never shown (my mistake for only testing in an English WMP 12). I am planning to release an updated version of WMPCDText in the coming months.
Reply #73
Just a short question: Does this nice plug-in also works with Windows 7 Starter?
  • Tim De Baets
  • Developer
Reply #74
Yes, as long as you have Windows Media Player, WMPCDText should work fine.
