Topic: Anyone who wants to write foo_accuraterip_db? (Read 34911 times) previous topic - next topic
  • odyssey
But does it write the results in tags or even work with multiple albums at the same time ??
It is first test version) you're demanding too much from it. Multiple albums support is planned AFAIR.
That's quite nice then.
Will it detect offset in the future? Maybe even be able to correct it?
Results would be saved most probably to a text file only.
Isn't it quite easy to call foobar2000 with the input filename and make it store a specific tag? Maybe you could ask the developer this. It should be as easy as outputting a textfile.
  • XPEHOPE3
I will tell the author about my post here and hopefully he will look through the topic and answer your questions.
  • Parsi
odyssey, According to my tests arcue supports pregap tags.
the only thing annoying is that everythings has to be cue+wav.
I hope this program (I dont know if it is correct to call it a plugin..) will get deveolped further, looks promising. I am not going to install it until its out of the testing stage
All tracks accurately ripped
End of status report
  • odyssey
Yes it supports it correctly - Problem was that I were unable to re-create the pregap because it will always be missing in single-track rips, and I would have no clue how long - if any it might be.
But that's past now. I've discovered tripleflac (thanx to graynol) that verifies my singletrack rips. I'll try out this foobar "addon" soon to see it's capabilities.
  • odyssey
Just tried it out today. It seem to work very well, although it could be VERY powerful!
Here's a list of feature requests I hope to see in a future version:
* I don't understand the concept of the dummy-files - Could they not be ignored?
* Write results into tags (can be done by calling foobar2000.exe with the filename and the tag that should be written)
* Support album grouping. Not sure which way is the best through converter, but maybe something similar to CUI NG grouping?
* Detect possible different offset values (just like tripleflac)
* Correct offset with any value available through entire album (I noticed some tracks usually differ with tripleflac). It could even automatically try to correct each possible offset values and present multiple possebilities to the user.
  • foorious
  • Banned
Reply #30
I definitely second that.
  • Borisz
I imagine a foobar integrated accuraterip verifier to be something like a cross between the Replaygain scanner and the freedb tagger. Nevertheless this app works fine, but as it was said before, theres a lot of room for improvement. Multiple album checking and lack of dummy files are what I consider the most important.
  • foorious
  • Banned
Any upcoming news on FooAccRip ? Our friend odyssey has mentioned a good list of wanted features, and I'd like to know if we can expect them to be taken into consideration (or not) by FooAccRip's developer in a future version. Thank you.
I'd like to add as a 'most-wanted feature' (if it hasn't been mentioned before) the possibility to analyze single-track files in lossless form (FLAC, etc.). FooAccRip could automatically generate all the needed temp files (single WAV + CUE, etc.) so that it would be transparent for the end user.
I personally don't imagine having to convert 1000 or 2000 albums with single-track files to WAC/CUE form... so I hope this request will soon be heard.
Reply #33
Check out new version of CUETools, i added support for accurate rip and embeded flac cuesheets.
  • Last Edit: 02 October, 2008, 07:27:32 AM by Gregory S. Chudov
CUETools 2.1.4
