Topic: lossyWAV Development (Read 585430 times) previous topic - next topic
Reply #825
When it was up to introducing our current clipping prevention scheme I searched hard for clipped tracks with the result that my collection has clipping next to nothing.
IMO we should stick to your suggestion for -3. After all clipping exists. But I think my clipping album is an extreme case of clipping, and AlexB's sample is more representative for clipped tracks.
Because of this and the fact that clipping is very rare I suggest to allow only 1 clipped sample in a block for -3, and keep the clipping prevention scheme in full action with -2.
I would certainly agree that -1 should have full clipping prevention. For -2, maybe 1 clip per channel per codec_block would be acceptable. For -3, 2 clips per channel per codec_block seems to work well. I will strip out the -clips parameter and post v0.7.1 RC3 sometime tomorrow.
I've been optimising in IA-32 / x87 again and the speed is getting marginally better.
Given that v0.6.7 RC2 has 95 downloads at the moment with no negative comments, I feel that we're *really* close to v1.0.0 final - we just have to agree amongst ourselves as to the exact number of (rounded down) clips acceptable for each quality preset.
Reply #826
I would certainly agree that -1 should have full clipping prevention. For -2, maybe 1 clip per channel per codec_block would be acceptable. For -3, 2 clips per channel per codec_block seems to work well ... we just have to agree amongst ourselves as to the exact number of (rounded down) clips acceptable for each quality preset.
Well to me the pretty rare event of clipping is an argument not to circumvent the clipping protection scheme with -2 and keep -2 in a 'pure' form. But we shouldn't continue this forever, so do go ahead with your favorite choice. I also don't think giving away clipping protection for 1 sample per channel and block will be audible.
lame3995o -Q1.7 --lowpass 17
Reply #827
lossyWAV beta v0.7.1 attached to post #1 in this thread.
Reply #828
Thank you Nick, especially for -noclips.
Can you tell a bit about the new window function and the noise constants? Are these changes conservative, or is it necessary to do some testing?
Reply #829
I had a brief PM discussion with David and I realised that I was using a zero-ended window function - values 0.5 fft_length apart did not sum to 1. I modified this slightly and the values 0.5 fft_length apart now sum to 1. The noise constants were re-calculated and incorporated into the code.
The bitrate has come down slightly (462.22kbps [v0.6.7 RC2] to 461.54kbps [beta v0.7.1]) at -3 for my 53 sample set.
If you have the time, I would welcome validation of the new window function. However, I feel that all it does is to use more samples per codec_block (64 not 62, etc.) so it should not sacrifice quality.
Reply #830
I had a thought - at present -1 uses 4 FFT's (64, 128, 512 & 1024 samples); -2 uses 2 FFT's (64, 256 & 1024 samples) and -3 uses 2 FFT's (64 & 1024 samples).
I am thinking about implementing a "-extrafft" parameter to add an extra FFT analysis to the existing quality preset at the user's discretion, which will basically increase the processing time, but also increase the scope of the analysis.
In this way, -1 would use 5 FFT's (64, 128, 256, 512 & 1024 samples); -2 would use 4 FFT's (64, 128, 512 & 1024 samples) and -3 would use 3 FFT's (64, 256 & 1024 samples).
Thoughts, anyone?
Reply #831
From my understanding we need more than 1 FFT because for getting a good temporal resolution (catching transients) we need a rather short FFT, and for a good frequency resolution in the low to medium frequency range we need a long FFT (for the very high frequency range the short FFT should be sufficient).
From this and from practical results I don't see why we should have more than 2 FFTs. It's okay to have an addtional FFT for safety reasons when going from -3 to -2, and from -2 to -1, but I don't see why we should go beyond that.
Sorry for being so negative towards your recents suggestions. I see you're eager to get further improvements the one or other way.
To me personally I think things are very good and don't need refinement as long as no issues come up in practice.
The only thing I personally would like to have consideration one last time is the coverage of the FFT windows of the 1024 sample FFT over the block.
We have a different sight on this as you feel the need that there is a 50% overlap of FFT analyses between adjacent blocks. I don't see any overlapping necessary for the blocks, and I think your consideration is based on one of 2Bdecided's remarks but I beleive this is a misunderstanding. Bits to remove decision in my understanding is not a global decision, not a block-overlapping decision, IMO not even a block-orientated decision (but I think the latter has no practical impact). IMO we can assign to each singular sample a number of bits to remove based on the analysis of those FFT windows where the specific sample has a contribution.
Block consideration comes in as the lowest number of bits to remove (per sample) must be chosen in order to assign a bits to remove number to the block. Moreover it's useful to base the FFT window partitioning based on the block. What's necessary is a good overlapping of the FFTs in the block under consideration. According to 2Bdecided the overlapping of the FFT windows (within the block!) should be 50% or more. We had a discussion before from which I thought we have an overlapping of 5/8 but IIRC this is not practice currently.
My suggestion once was that in order to have the overlapping not to go far into neighboring blocks as their samples have nothing to do with the block under consideration, and I suggested to have the centre point of the most outward FFT windows a little bit within the block. 2Bdecided preferred the edge position because of a good temporal resolution at the very beginning and end of the block, but this cannot be an issue with the 1024 sample FFT, simply because this job is up to the short FFT.
So can you please reconsider using the following 1024 sample FFT windows: -448:575, -64:959. With this the center of the FFT window is just 64 samples (1/16 of the window length) away from the edges, and think this isn't a problem for catching problems at the edges (and temporal resolution issues are catched up by the short FFT, not the 1024 sample FFT, and the 64 sample FFTs can be centered at the edges). The advantage is in the middle area of the block as this area is covered better now by the 2 FFT windows. With the center points at the very edges we are already 50% away from the FFT centers when it's about the middle of the block, and the samples there participate only partially in the FFT analyses. If you do a third long FFT centered at the block center the way you wrote about (but I'm not sure whether this is in action right now) things are alright of course, but at the cost of an additional FFT window.
Reply #832
The -448/-64 method does not benefit from the code speedup as the 0:1023 existing FFT is recycled as the -512:511 in the next codec_block, neither does it benefit from a 50% overlap between FFT analyses.
I would rather go down the -256:767 route if we are going to deviate from the -512:511;0:1023 route. Someone with more knowledge than me should ultimately make the decision, but if the existing -512:511;0:1023 is not acceptable then my preference is clear.
Reply #833
The -448/-64 method does not benefit from the code speedup as the 0:1023 existing FFT is recycled as the -512:511 in the next codec_block ...
I see, this was the speedup trick. Clever done.
... neither does it benefit from a 50% overlap between FFT analyses. ....
I do not understand why you want a 50% FFT overlap for neighboring blocks. We have a per block analysis and determination of bits to remove. Ideally we don't consider samples at all from neighboring blocks, it is a negative side effect that we have to accept due to the nature of the FFT window. Sure we want accuracy at the block's edges so the FFT windows will reach into the neighboring block. But to do so to a smaller degree than 50% if we can allow is better than reaching 50% into the neighborhood.
But the speedup thing is valuable, especially for -3 with its excellent speed.
What do you think about the -448:575, -64:959 windows for -2, or at least for -1?
Reply #834
I hear what you say - all three options are now available in lossyWAV beta v0.7.2, attached to post #1 in this thread.
Reply #835
... I hear what you say - all three options are now available in lossyWAV beta v0.7.2, attached to post #1 in this thread.
Wonderful - you make me happy. Thank you very much.
Reply #836
Not quite - the concepts of time and frequency are linked, and you can only have the frequency accuracy of a 1024-point FFT by looking at 1024 samples. If you want that accuracy (and I believe we do) you need that many samples. So no, even "ideally" we need to consider samples from neighboring blocks - just as, at the limit, a single sample tells you nothing.
As long as there is at least 50% overlap, and all the blocks is covered by a 0.5 or higher parts of the window function, it really doesn't matter which of the two or three proposed schemes you use.
You're looking for the quietest part, and that could be anywhere in the block. Focusing on the start, middle, end, or any point(s) in between has no advantage in this respect.
What we do know is that something special can happen at block boundaries which cannot happen anywhere else (we introduce a transition), so focussing on these has some merrit, but I wouldn't argue to the death for it!
The worst case scenario is this: you have a notch in the frequency spectrum that's narrow enough that you need a 1024 point FFT to catch it (otherwise the shorter FFT will catch it anyway, and the position of the 1024 point FFT doesn't matter!). Now, switch this notch in and out at block boundaries, so one block has it, and the next doesn't. If the notch is in white noise, we won't hear the switching transients, so we can switch in a single sample.
So, if you use a 64-point FFT, you can't see this notch - it's too narrow.
Yet if you use a 1024-point FFT, you'll hit your problem - the centred window sees more of the notch than the edge window.
Does it make any audible difference? I can't tell, but I've attached a sample if you want to check. It's only 1 second long, the first 1/2 has alternate filtered/not filtered 512-sample blocks. The second 1/2 is all unfiltered. You can clearly hear the difference between these two, but does lossywav processing change it at all, with either window position?
Reply #837
Thanks David,
The idea of using the centred analysis, i.e. -256:767, has the whole codec_block in the 50% or higher zone and will also include 256 samples from the codec_blocks either side, although that does mean that the block edge samples are only at 50%.
However, prioritising the codec_block edges, the existing method (-512:511; 0:1023) has the samples at each end of the codec_block at 100% in one or other analysis.
[edit] Your sample using v0.7.2, FLAC -5, -3: (e) 54031bytes; -3 -overlap: (o) 54158bytes; -3 -centre: © 53326 bytes. (attached) Will try listening to them. [/edit]
[edit2] All I'm getting is a slight difference in tone of a sub-frequency that isn't the noise itself..... Mind you, my ears have visited !loud! environments a few times too often. [/edit2]
Reply #838
It was the lowest frequencies that I removed, but my ears at least can't hear that they're absent/present/absent/present every 512 samples in the original file - they just sound quieter overall for the first half of the file.
Looking at the bits removed, the different modes are doing what you'd expect: the centred mode clearly picks up the blocks with the notch filter and removes fewer bits (and removes more bits where there's pure white noise), the others don't really notice a difference.
However, during the second 1/2 of the file (which is just white noise), the centred mode jumps around a lot in bits removed even though there's no difference (other than the noise being random) between blocks. I've attached an image showing how the added noise jumps around (all three lossy-original=difference signals boosted by 42dB for display).
All three lossy versions sound the same as the original to me.
If anyone can think of a more critical test sample, please post.
Reply #839
The worst case scenario is this: you have a notch in the frequency spectrum that's narrow enough that you need a 1024 point FFT to catch it (otherwise the shorter FFT will catch it anyway, and the position of the 1024 point FFT doesn't matter!). Now, switch this notch in and out at block boundaries, so one block has it, and the next doesn't. If the notch is in white noise, we won't hear the switching transients, so we can switch in a single sample. ...
I think it's all a misunderstanding, probably I didn't make my point clear enough.
Of course we want a 1024 sample FFT, and of course every sample in the 1024 sample window counts, and of course if we want accuracy at the edge any 1024 sample FFT window which takes good care of the edges stretches its samples in a significant way into the neighboring block.
I just call this a negative side effect as we do want to assign a number of bits to remove to the block under consideration, and in this respect it's a negative (though necessary) side effect in my understanding.
In the end: do you think with the two FFT windows -448:575, -64:959 for the 0:511 block the edges are not covered well by these?
As for your sample I didn't understand what you want to show other than that a good accuracy for the edge region is needed for the 1024 sample FFT. That's again the question to me: don't you think the -448:575, -64:959 windows are a good choice for preserving the accuracy of the 1024 FFT at the edges?
According to your graphs for your sample BTW noise is (slightly) lower with these windows then with the exactly edge positioned ones.
I guess we have the same thing in mind: accuracy at the edges, but for that IMO the centre point needn't be exactly at the edge but can be a little bit interior to the block. The advantage is that with such a choice the centre region is taken better care of which is a bit underexposed with the center of the 2 FFT windows situated exactly at the edges.
Reply #840
As there were several changes since I tested lossyWAV the last time, I did it again (using -3 -noclips -overlap) and tried to abx my usual problem samples and 2 regular tracks with french female voices.
Everything's fine. The only slight suspicion was with badvilbel where I thought I could hear more noise than in the original. I arrived at 4/4 which turned into a 5/10 finally. So I can't abx it.
Reply #841
To allow better tuning of this particular variable, I'll revise the -overlap parameter to take a value (0..16) which will set the overlap of the 1024 sample FFT to 512-16*(overlap_value), i.e. 512..256 samples. I will revise the -centre parameter to add in a central 1024 sample FFT where overlap size>256.
lossyWAV beta v0.7.3 attached to post #1 in this thread.
Reply #842
Great, Nick! Thank you very much (cause I was thinking already that it wouldn't be bad to have the center of the 1024 sample windows a further bit more inside the block.
Just in order that I don't do something wrong can you please comfirm ot tell me I'm wrong:
a) -overlap 6 means: we have 2 1024 sample FFT windows per block with the center of each being in the block and 96 samples away from the edges?
b) -centre means: we have 3 1024 sample FFT windows per block, 1 with the centre at the block's centre and 2 with the centre at the block's edges?
Reply #843
To summarise:
-overlap 0 := -512:511;0:1023;
-overlap 4 := -448:575;-64:959;
-overlap 8 := -384:639; -128:895;
-overlap 12 := -320:703; -192:831;
-overlap 16 := -256:767;
-centre := additional -256:767. (unless -overlap 16 has been specified, obviously ).
Have fun!
Reply #844
Thanks a lot!
Reply #845
Oops - immediate bug-fix (affects v0.7.2 and the first two downloaders of v0.7.3). The end_overlap of the second (possibly third) FFT analyses at 1024 sample length was being calculated incorrectly (it was still assuming end_overlap = fft_length div 2). Apologies for the error.
Reply #846
Using new v0.7.3 -3 -noclips -overlap 8 I tried my usual killer samples as well as some regular music again.
Everything's fine.
Average bitrate for my sample set of full length regular tracks is exactly 400 kbps.
Reply #847
Everything's fine.
Good to hear - I'll leave the -overlap parameter where it is at the moment.
I've added a few options to the quality presets:
-1 now has an additional variant -1a (1 added FFT length);
-2 now has 2 additional variants -2a & -2b (1 and 2 added FFT lengths respectively);
-3 now has 3 additional variants -3a, -3b & -3c (1, 2 and 3 added FFT lengths respectively);
In this way, the user can opt to spend a bit more time on the processing (if time is not an important factor) by carrying out FFT analyses at additional FFT lengths.
-extrafft parameter removed as superseded.
lossyWAV beta v0.7.4 attached to post #1 in this thread.
[edit] Immediate update required: I must have "broken" the 24-bit handling some time ago.... Now fixed at beta v0.7.5 in the usual place. [/edit]
Reply #848
Not a big issue, but 0.7.5 beta still says 0.7.4
lossyWAV beta v0.7.4, Copyright © 2007,2008 Nick Currie.
Reply #849
  Oops.... Will be corrected in beta v0.7.6 - I'm trying to implement the -merge parameter to revert lossy + lwcdf to lossless.
