Topic: Any windows frontends that are compatible with CDRDAO 1.2.2? (Read 5303 times) previous topic - next topic
There are Win32 binaries of the most recent version of CDRDAO (1.2.2) available at this page.  However, I cannot seem to find a Windows-based frontend program that actually supports this version.  Trying to use it with Burrrn or BurnAtOnce generates incompatability errors (presumably from where neither app has recently been updated in a while), and I can't seem to find any other program that explicity uses CDRDAO.  Even EAC seems to use an older CDRDAO for some reason (1.1.9).
Any suggestions?  Or is there not anything important in 1.2.2?
Something like this?
That's for CDRTools isn't it?  I don't believe it utilises CDRDAO.
My bad  You're right.
It does if you copy it in the instalation directory. Check the settings page, you  have the tab "cdrdao" and it's controls are greyed if you don't have the cdrdao in the program's directory.
Hmmmmmmm, looking at it and trying it out....... is there even any way to make it use CDRDAO when writing audio CDs?  It keeps using CDRecord everytime, even when cdrdao.exe exists.  Reading the readme or help documents don't help at all.
Any other suggestions???
You click the "Settings" button, then you go to cdrdao tab and check "Write CUE images using cdrdao" and appropriate driver checkbox.
I believe I already did that though, and it still used CDRecord.  Besides, I'm writing an audio CD out of MP3s, so how would a CUE file be of any use or importance to me, particularly as CDRDAO tends to use TOCs?
Well, here is the snapshot of a cdtfe - output window. You go to CD Image tab and select "Write image". Then with the "Browse" find apropriate CUE file. You have to make a cue or toc file in order to burn with cdrdao. You need to decode your mp3's to wavs and write the cuesheet. Maybe CueMaster can help you. If you use this frontend and have a toc file use the "toc2cue" tool from cdrdao package.
"D:\Install\Audio software\cdrdao\cdrtfe_portable\cdrdao" write --device 1,0,0 --driver generic-mmc --speed 10 "/cygdrive/D/Musick/1/Jose Miguel Moreno - Pieces Pour Theorbes Francaises/CDImage1.cue"
Cdrdao version 1.2.2 - (C) Andreas Mueller <andreas@daneb.de>
  SCSI interface library - (C) Joerg Schilling
  Paranoia DAE library - (C) Monty
Check http://cdrdao.sourceforge.net/drives.html#dt for current driver tables.
Using libscg version 'schily-0.8'
1,0,0: PIONEER DVD-RW  DVR-107D    Rev: 1.22
Using driver: Generic SCSI-3/MMC - Version 2.0 (options 0x0000)
OS lock on device \\.\F:. Unit won't be accessible while burning.
Starting write at speed 10...
Pausing 10 seconds - hit CTRL-C to abort.
Process can be aborted with QUIT signal (usually CTRL-\).
Turning BURN-Proof on
Executing power calibration...
Power calibration successful.
Writing track 01 (mode AUDIO/AUDIO )...
Writing track 02 (mode AUDIO/AUDIO )...
Writing track 03 (mode AUDIO/AUDIO )...
Writing track 04 (mode AUDIO/AUDIO )...
Writing track 05 (mode AUDIO/AUDIO )...
Writing track 06 (mode AUDIO/AUDIO )...
Writing track 07 (mode AUDIO/AUDIO )...
Writing track 08 (mode AUDIO/AUDIO )...
Writing track 09 (mode AUDIO/AUDIO )...
Writing track 10 (mode AUDIO/AUDIO )...
Writing track 11 (mode AUDIO/AUDIO )...
Writing track 12 (mode AUDIO/AUDIO )...
Writing track 13 (mode AUDIO/AUDIO )...
Writing track 14 (mode AUDIO/AUDIO )...
Writing track 15 (mode AUDIO/AUDIO )...
Writing track 16 (mode AUDIO/AUDIO )...
Writing track 17 (mode AUDIO/AUDIO )...
Writing track 18 (mode AUDIO/AUDIO )...
Writing track 19 (mode AUDIO/AUDIO )...
Writing track 20 (mode AUDIO/AUDIO )...
Writing track 21 (mode AUDIO/AUDIO )...
Writing track 22 (mode AUDIO/AUDIO )...
Writing track 23 (mode AUDIO/AUDIO )...
Wrote 309043 blocks. Buffer fill min 87%/max 100%.
Flushing cache...
Writing finished successfully.
Device \\.\F: unlocked.
Execution completed.
