Topic: Album Art Browser (Read 100930 times) previous topic - next topic
Album Art Browser
I put together a columns ui panel that lets you browse albums by their album art.  Works similar to my foo_browser plugin.
It's in its beta stages now, and I'm really not ready for an onslaught of feature requests, but if you do find bugs, please let me know.
Details can be found: http://www.bazquux.com/wiki/Foobar2000:foo_cwbowron
Direct download link: http://foobar.bazquux.com/downloads/foo_cwbowron.zip
The name of the dll is a very generic foo_cwbowron.dll so that any new plugins I create will be integrated into this dll so that I have fewer files to distribute.
There used to be a link to my website here.
Album Art Browser
your component does nothing in my foobar but the idea is nice
Album Art Browser
Doesn't work for me, gets an error message when i start foobar that it failed to load
Album Art Browser
No problem so far for me.    It's work like a charm.
this is godsend for someone who use Column UI like me.  and if another feature were add it would be awsome.
looking forward for update version
Album Art Browser
Yesssss! Finally! Someone got to do this. I'm looking forward for updated versions.
Album Art Browser
Hi Chris,
I am getting a "Failed to load DLL: foo_cwbowron.dll
Reason: This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem."
Do you have any idea as to why the dll is failing to load?
Edit: Spelling
Surf's Up!
"Columnated Ruins Domino"
Album Art Browser
this Plugin really has great potential.
I've already got some feature requests, but these will have to wait.
I've actually found a "bug":
I've set the following String as Album Art Location:
C:\Users\Raphael\Pictures\Scans\Cover\%album artist% - %album%.jpg
When I searched for my AC/DC Albums, the component found nothing.
That's because the Album Art got the following filename, for example:
Every component I know of,  automaticly replaces invalid characters for filenames  with  "_". So  I think this component should do it, too.
P.S.: The invalid characters for filenames are the following chars:
Album Art Browser
You could use a code that replace all these characters in %album artist% with "_". This would solve your problem.
Album Art Browser
Could be missing DLL's... You might need MSVCR80.dll and GDIPLUS.DLL... Not sure where you can find them...
Album Art Browser
got the same problem as drbeachboy, both MSVCR80.dll and GDIPLUS.DLL are available and properly registered
Album Art Browser
Of course, I could, but why? Even the official components (for example foo_converter.dll) do it for you.
Album Art Browser
But this is the other way round.
You have some characters replced by "_"
But how should you get from "_" to each single of these characters
Album Art Browser
My explanation was maybe a tad bit confusing.
The String
gives the following result:
C:\Users\Raphael\Pictures\Scans\Cover\AC/DC - Let there be Rock.jpg
But:
The File in
is called:
,because the following chars are invalid in a filename:
Result: Album Art Browser won't find the file. It would have to replace the invalid chars with "_". This is the method of every other component.
But currently it isn't using this method.
Album Art Browser
First off: AWESOME! It's been ages since a feature like this was requested. Thank you for this component.
I added the browser in a tab using (foo_uie_tabs). When i doubleclick the blank area, foobar crashes:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01552045h
Access violation, operation: read, address: FFFFFFFCh
Call path:
entry=>app_mainloop
Code bytes (01552045h):
01552005h:  55 00 50 50 8B 42 24 56 8B CD FF D0 8B 55 00 8B
01552015h:  F0 8B 42 5C 56 8B CD FF D0 8B 55 00 8B 52 44 8D
01552025h:  44 24 44 50 56 8B CD C7 44 24 4C 90 94 55 01 FF
01552035h:  D2 8B 44 24 40 8B 48 2C C7 44 24 18 9C 94 55 01
01552045h:  8B 04 B9 8B 55 00 8B 52 50 8D 4C 24 18 51 50 6A
01552055h:  FF 56 8B CD FF D2 8B 45 00 8B 50 14 56 8B CD FF
01552065h:  D2 8B 45 00 8B 50 1C 56 8B CD FF D2 89 5C 24 40
01552075h:  8D 7C 24 40 C6 44 24 38 03 E8 6D 29 00 00 C6 44
Stack (0012F468h):
0012F448h:  00000000 00000000 00000000 00000000
0012F458h:  00000000 00000000 00000000 00000000
0012F468h:  E88F9658 0012F794 0000004E 0012F4BC
0012F478h:  00000000 004DF178 0155949C 015594C0
0012F488h:  01D970A8 00000016 00000016 00000005
0012F498h:  0012F554 01558A18 00000002 01551CFF
0012F4A8h:  055114F8 01559490 0012F538 0000004E
0012F4B8h:  00000000 0012F4E8 77081A10 000805EE
0012F4C8h:  0000004E 000003E9 0012F794 0000004E
0012F4D8h:  DCBAABCD 00000000 0012F538 0000004E
0012F4E8h:  0012F564 77070E04 01551CA0 000805EE
0012F4F8h:  0000004E 000003E9 0012F794 E96C3937
0012F508h:  0000004E 000805EE 00D66980 00000024
0012F518h:  00000001 00000000 00000000 00000030
0012F528h:  FFFFFFFF FFFFFFFF 77070DBA 00000000
0012F538h:  7707916A 00000000 00000001 00000000
0012F548h:  00000000 0012F504 0012F088 0012F65C
0012F558h:  770C76CC 9E79C27B 00000000 0012F5AC
0012F568h:  77070C7E 00000000 01551CA0 000805EE
0012F578h:  0000004E 000003E9 0012F794 00D66994
Registers:
EAX: 055114F8, EBX: 00000000, ECX: 00000000, EDX: 00302138
ESI: 00000007, EDI: FFFFFFFF, EBP: 004DF178, ESP: 0012F468
Crash location: "foo_cwbowron", loaded at 01550000h - 01562000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 77D80000h - 77E9E000h
kernel32                        loaded at 76880000h - 76958000h
COMCTL32                        loaded at 753D0000h - 75564000h
msvcrt                          loaded at 766F0000h - 7679A000h
ADVAPI32                        loaded at 76A00000h - 76ABF000h
RPCRT4                          loaded at 767A0000h - 76863000h
GDI32                            loaded at 76640000h - 7668B000h
USER32                          loaded at 77060000h - 770FE000h
SHLWAPI                          loaded at 76690000h - 766E5000h
SHELL32                          loaded at 772B0000h - 77D7E000h
ole32                            loaded at 76AC0000h - 76C04000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 77100000h - 77174000h
IMM32                            loaded at 77FA0000h - 77FBE000h
MSCTF                            loaded at 76F90000h - 77057000h
LPK                              loaded at 76870000h - 76879000h
USP10                            loaded at 76DF0000h - 76E6D000h
guard32                          loaded at 00290000h - 002AD000h
fltLib                          loaded at 764C0000h - 764C7000h
winsta                          loaded at 76490000h - 764B4000h
ws2_32                          loaded at 77EB0000h - 77EDD000h
NSI                              loaded at 76960000h - 76966000h
uxtheme                          loaded at 756D0000h - 7570F000h
foo_audioscrobbler              loaded at 013D0000h - 01407000h
foo_autoplaylist                loaded at 01220000h - 01250000h
foo_benchmark                    loaded at 01390000h - 013B8000h
foo_bitcompare                  loaded at 01410000h - 01437000h
foo_cdda                        loaded at 01470000h - 014A5000h
foo_common                      loaded at 014F0000h - 01523000h
foo_converter                    loaded at 01580000h - 015E9000h
LVPrcInj                        loaded at 01530000h - 01547000h
foo_convolve                    loaded at 01760000h - 017B1000h
foo_cwbowron                    loaded at 01550000h - 01562000h
gdiplus                          loaded at 74E80000h - 7502A000h
MSVCR80                          loaded at 70FD0000h - 7106B000h
foo_cwb_hooks                    loaded at 01660000h - 016AD000h
foo_dbsearch                    loaded at 016B0000h - 01720000h
OLEAUT32                        loaded at 77F10000h - 77F9C000h
foo_dsp_crossfader              loaded at 01AA0000h - 01AFD000h
libmmd                          loaded at 01DA0000h - 02051000h
foo_dsp_dolbyhp                  loaded at 01720000h - 01741000h
VERSION                          loaded at 75D00000h - 75D08000h
foo_dsp_std                      loaded at 01940000h - 01981000h
foo_freedb2                      loaded at 01B00000h - 01B40000h
foo_input_alac                  loaded at 017C0000h - 017DD000h
foo_input_dts                    loaded at 01CA0000h - 01D05000h
foo_input_monkey                loaded at 01D10000h - 01D5A000h
foo_input_shorten                loaded at 01B40000h - 01B6D000h
foo_input_std                    loaded at 02550000h - 02663000h
foo_input_tak                    loaded at 02160000h - 021A7000h
tak_deco_lib                    loaded at 022F0000h - 02321000h
foo_input_tta                    loaded at 023D0000h - 023FD000h
foo_lyricsdb                    loaded at 02400000h - 0242F000h
WININET                          loaded at 76EC0000h - 76F8F000h
Normaliz                        loaded at 77EA0000h - 77EA3000h
iertutil                        loaded at 76E70000h - 76EB5000h
foo_masstag                      loaded at 02460000h - 024AF000h
foo_playcount                    loaded at 024C0000h - 024E8000h
foo_playlist_tree                loaded at 02670000h - 026E5000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 73BB0000h - 73BB7000h
libmzgc360_000                  loaded at 02820000h - 028C4000h
foo_pqview                      loaded at 024F0000h - 0250B000h
foo_rgscan                      loaded at 028F0000h - 02938000h
foo_run                          loaded at 02960000h - 0298B000h
foo_scrobblecharts              loaded at 02AC0000h - 02AF3000h
foo_tradersfriend                loaded at 02B40000h - 02B7A000h
foo_uie_albumart                loaded at 02B90000h - 02BCC000h
foo_uie_albumlist                loaded at 02C30000h - 02C73000h
foo_uie_peakmeter                loaded at 02B00000h - 02B28000h
foo_uie_playlists_dropdown      loaded at 02CB0000h - 02CE9000h
foo_uie_queuemanager            loaded at 02CF0000h - 02D29000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 6CDF0000h - 6CE6D000h
mscorwks                        loaded at 79E70000h - 7A3D6000h
mscorlib.ni                      loaded at 790C0000h - 79BDE000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 75A20000h - 75A58000h
System.ni                        loaded at 7A440000h - 7AC0C000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF70000h
foo_uie_tabs                    loaded at 03010000h - 0303A000h
foo_ui_columns                  loaded at 065A0000h - 06642000h
foo_ui_panels                    loaded at 06810000h - 068F9000h
foo_unpack                      loaded at 03080000h - 030AE000h
foo_utils                        loaded at 05C50000h - 05C88000h
foo_verifier                    loaded at 05CA0000h - 05CD0000h
WindowsCodecs                    loaded at 716D0000h - 71782000h
apphelp                          loaded at 76430000h - 7645C000h
CLBCatQ                          loaded at 76970000h - 769F4000h
cscui                            loaded at 70D40000h - 70DD5000h
PROPSYS                          loaded at 74AA0000h - 74B57000h
CSCDLL                          loaded at 70E30000h - 70E39000h
CSCAPI                          loaded at 709D0000h - 709DA000h
IconCodecService                loaded at 70940000h - 70946000h
LINKINFO                        loaded at 70950000h - 70959000h
SETUPAPI                        loaded at 76C10000h - 76D98000h
dciman32                        loaded at 6DC80000h - 6DC86000h
DolbyHph                        loaded at 061E0000h - 062DC000h
Msimg32                          loaded at 75970000h - 75975000h
NLAapi                          loaded at 74C40000h - 74C4F000h
IPHLPAPI                        loaded at 75EE0000h - 75EF9000h
dhcpcsvc                        loaded at 75EA0000h - 75ED5000h
DNSAPI                          loaded at 76170000h - 7619B000h
Secur32                          loaded at 764D0000h - 764E4000h
WINNSI                          loaded at 75E90000h - 75E97000h
dhcpcsvc6                        loaded at 75E70000h - 75E90000h
mswsock                          loaded at 75C90000h - 75CCB000h
winrnr                          loaded at 73510000h - 73518000h
WLDAP32                          loaded at 76DA0000h - 76DE9000h
PSAPI                            loaded at 76630000h - 76637000h
napinsp                          loaded at 73440000h - 7344F000h
pnrpnsp                          loaded at 732E0000h - 732F2000h
wshbth                          loaded at 73430000h - 7343C000h
rasadhlp                        loaded at 73450000h - 73456000h
wship6                          loaded at 75CF0000h - 75CF6000h
wshtcpip                        loaded at 75960000h - 75966000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC5E000h
imagehlp                        loaded at 77EE0000h - 77F09000h
dbghelp                          loaded at 73D80000h - 73E5C000h
Stack dump analysis:
Address: 004DF178h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0155949Ch, location: "foo_cwbowron", loaded at 01550000h - 01562000h
Symbol: "foobar2000_get_interface" (+0000408Ch)
Address: 015594C0h, location: "foo_cwbowron", loaded at 01550000h - 01562000h
Symbol: "foobar2000_get_interface" (+000040B0h)
Address: 01558A18h, location: "foo_cwbowron", loaded at 01550000h - 01562000h
Symbol: "foobar2000_get_interface" (+00003608h)
Address: 01551CFFh, location: "foo_cwbowron", loaded at 01550000h - 01562000h
Address: 01559490h, location: "foo_cwbowron", loaded at 01550000h - 01562000h
Symbol: "foobar2000_get_interface" (+00004080h)
Address: 77081A10h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 77070E04h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetTitleBarInfo" (+00000437h)
Address: 01551CA0h, location: "foo_cwbowron", loaded at 01550000h - 01562000h
Address: 77070DBAh, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetTitleBarInfo" (+000003EDh)
Address: 7707916Ah, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "DestroyWindow" (+0000053Ch)
Address: 770C76CCh, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "AlignRects" (+00001926h)
Address: 77070C7Eh, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetTitleBarInfo" (+000002B1h)
Address: 7707123Bh, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77081AE8h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetMessageW" (+00000146h)
Address: 77071219h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77081A91h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetMessageW" (+000000EFh)
Address: 7708286Ah, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetDesktopWindow" (+0000010Ah)
Address: 77082BBAh, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "SendMessageW" (+00000049h)
Address: 75439BFDh, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "ImageList_ReplaceIcon" (+0000011Ah)
Address: 75417E7Bh, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "RegisterClassNameW" (+000004BEh)
Address: 7544B393h, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "CreateToolbarEx" (+00000EEDh)
Address: 75417D4Bh, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "RegisterClassNameW" (+0000038Eh)
Address: 754031B4h, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "TaskDialogIndirect" (+0002F3AFh)
Address: 7541F365h, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "ImageList_GetIconSize" (+00003F02h)
Address: 7540E94Eh, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "DPA_Clone" (+00001E9Ah)
Address: 7540DA8Bh, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "DPA_Clone" (+00000FD7h)
Address: 7541B4D6h, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "ImageList_GetIconSize" (+00000073h)
Address: 75439DACh, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "ImageList_ReplaceIcon" (+000002C9h)
Address: 77081B41h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetMessageW" (+0000019Fh)
Address: 77082539h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77082545h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "GetWindowLongW" (+00000037h)
Address: 75438494h, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "DPA_GetPtrIndex" (+0000035Fh)
Address: 7543848Ch, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "DPA_GetPtrIndex" (+00000357h)
Address: 75438454h, location: "COMCTL32", loaded at 753D0000h - 75564000h
Symbol: "DPA_GetPtrIndex" (+0000031Fh)
Address: 77082A47h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "IsWindow" (+0000014Dh)
Address: 77078C2Eh, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "DestroyWindow" (+00000000h)
Address: 77082A98h, location: "USER32", loaded at 77060000h - 770FE000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042FE21h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0530h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430967h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC438h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D88BF2h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 77DC1EDFh, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "wcscmp" (+00000E23h)
Address: 77DE2447h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B61h)
Address: 77DE214Ch, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "RtlTryEnterCriticalSection" (+00000866h)
Address: 77DE5BA9h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "RtlFindActivationContextSectionGuid" (+000002FDh)
Address: 77DE1843h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "RtlAllocateHeap" (+00000216h)
Address: 77DC1747h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "wcscmp" (+0000068Bh)
Address: 77DE16DCh, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "RtlAllocateHeap" (+000000AFh)
Address: 77DE162Dh, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00407E27h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4218h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004991DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0540h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF4F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430B6Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004973CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936F6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B33D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4210h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF8E8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496284h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 768C3833h, location: "kernel32", loaded at 76880000h - 76958000h
Symbol: "BaseThreadInitThunk" (+00000012h)
Address: 77DBA9BDh, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "LdrInitializeThunk" (+0000004Dh)
Address: 76915984h, location: "kernel32", loaded at 76880000h - 76958000h
Symbol: "UnhandledExceptionFilter" (+00000000h)
Address: 77DC1B87h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "wcscmp" (+00000ACBh)
Address: 004962EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Decoding Speed Test 1.0  (foo_benchmark)
TAK Decoder 0.3.2  (foo_input_tak)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Database Search 1.4  (foo_dbsearch)
Dolby Headphone Wrapper 1.1  (foo_dsp_dolbyhp)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Album Art Browser 0.0.3 [Jul 11 2007 - 11:15:14]  (foo_cwbowron)
Run services 0.3.2  (foo_run)
File Integrity Verifier 1.0.1  (foo_verifier)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
RAR reader 1.1  (foo_unpack)
Autoplaylist Manager 1.0  (foo_autoplaylist)
ZIP/GZIP reader 1.0  (foo_unpack)
Playlist Tools 0.5.9  (foo_utils)
Album Art Panel 0.2.6  (foo_uie_albumart)
Common services 0.1  (foo_common)
DTS decoder 0.1.7  (foo_input_dts)
Converter 1.0.1  (foo_converter)
ALAC Decoder 1.0  (foo_input_alac)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
CD Audio Decoder 2.1.1  (foo_cdda)
WMA Decoder 1.1  (foo_input_std)
Binary Comparator 1.1  (foo_bitcompare)
Convolver 0.3  (foo_convolve)
Shorten decoder 0.4.2a  (foo_input_shorten)
freedb Tagger 0.5.2a  (foo_freedb2)
TTA Audio Decoder (unofficial) 2.4.2  (foo_input_tta)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Masstagger 1.6  (foo_masstag)
Audioscrobbler 1.3.6  (foo_audioscrobbler)
Playback Statistics 1.3.2  (foo_playcount)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
foobar2000 core 0.9.4.3  (Core)
Gapless Crossfader 0.3.2.2 (Intel SSE)  (foo_dsp_crossfader)
Peakmeter Panel 0.0.3 beta  (foo_uie_peakmeter)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Standard DSP array 1.0  (foo_dsp_std)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Columns UI 0.2.0 alpha 1  (foo_ui_columns)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
FLAC Decoder 1.1.0  (foo_input_std)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
Album Art Browser
Illegal operation:
Call path:
entry=>app_mainloop
Stack (0012F468h):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
I can confirm this too.
And "Crash location" is differrent if i doubleclick empty space before and after browse album art.
before browse album art
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00E42045h
Call path:
entry=>app_mainloop
Code bytes (00E42045h):
00E42005h:  55 00 50 50 8B 42 24 56 8B CD FF D0 8B 55 00 8B
00E42015h:  F0 8B 42 5C 56 8B CD FF D0 8B 55 00 8B 52 44 8D
00E42025h:  44 24 44 50 56 8B CD C7 44 24 4C 90 94 E4 00 FF
00E42035h:  D2 8B 44 24 40 8B 48 2C C7 44 24 18 9C 94 E4 00
00E42045h:  8B 04 B9 8B 55 00 8B 52 50 8D 4C 24 18 51 50 6A
00E42055h:  FF 56 8B CD FF D2 8B 45 00 8B 50 14 56 8B CD FF
00E42065h:  D2 8B 45 00 8B 50 1C 56 8B CD FF D2 89 5C 24 40
00E42075h:  8D 7C 24 40 C6 44 24 38 03 E8 6D 29 00 00 C6 44
Stack (0012F528h):
0012F508h:  0120DCDC 7C9C93C0 77F643DD 7C9C93C0
0012F518h:  00000004 00000000 0120D1E8 00000000
0012F528h:  56942038 0012F81C 00E41CA0 0012F578
0012F538h:  00000000 004DF178 00E4949C 00E494C0
0012F548h:  00E861B0 00000025 00000025 00000014
0012F558h:  0012F600 00E48A18 00000002 00E41CFF
0012F568h:  00E86708 00E49490 0012F5E0 00E41CA0
0012F578h:  0012F5A4 77D48734 001A036A 0000004E
0012F588h:  000003E9 0012F81C 00E41CA0 DCBAABCD
0012F598h:  00000000 0012F5E0 00E41CA0 0012F610
0012F5A8h:  77D5418D 00E41CA0 001A036A 0000004E
0012F5B8h:  000003E9 0012F81C 0000004E 001A036A
0012F5C8h:  00736B50 00000014 00000001 00000000
0012F5D8h:  00000000 00000010 00000000 77D4C331
0012F5E8h:  00000000 00000001 00000000 00000000
0012F5F8h:  0012F5C0 0012F14C 0012F6F8 77D70467
0012F608h:  77D541B0 00000000 0012F658 77D53FD9
0012F618h:  00000000 00E41CA0 001A036A 0000004E
0012F628h:  000003E9 0012F81C 00736B64 0012F660
0012F638h:  0012F6DC 77D541E2 00000000 000003E9
Registers:
EAX: 00E86708, EBX: 00000000, ECX: 00000000, EDX: 00153510
ESI: 00000012, EDI: FFFFFFFF, EBP: 004DF178, ESP: 0012F528
Crash location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F2000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00A30000h - 00A63000h
foo_autoplaylist                loaded at 00A80000h - 00AB0000h
foo_benchmark                    loaded at 00AD0000h - 00AF8000h
foo_bitcompare                  loaded at 00B20000h - 00B47000h
foo_burninate                    loaded at 00B70000h - 00BA7000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00BD0000h - 00C05000h
foo_converter                    loaded at 00C30000h - 00C99000h
foo_convolve                    loaded at 00CC0000h - 00D11000h
foo_cuesheet_creator            loaded at 00D40000h - 00D6D000h
foo_custominfo                  loaded at 00D90000h - 00E15000h
foo_cwbowron                    loaded at 00E40000h - 00E52000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_cwb_hooks                    loaded at 00E90000h - 00EDD000h
foo_dsp_bs2b                    loaded at 00F00000h - 00F1C000h
foo_dsp_crossfader              loaded at 00F40000h - 00F9D000h
libmmd                          loaded at 00FB0000h - 01261000h
foo_dsp_crossfeed                loaded at 01280000h - 012A4000h
foo_dsp_soundtouch              loaded at 012D0000h - 012DF000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_dsp_std                      loaded at 012F0000h - 01331000h
foo_dsp_vlevel(3)                loaded at 01360000h - 01384000h
foo_dsp_winamp                  loaded at 013B0000h - 013D3000h
foo_dumb                        loaded at 01400000h - 01489000h
foo_freedb2                      loaded at 014B0000h - 014F0000h
foo_fullscreen                  loaded at 01510000h - 0152B000h
foo_infobox                      loaded at 01550000h - 01590000h
foo_input_alac                  loaded at 015B0000h - 015CD000h
foo_input_monkey                loaded at 015F0000h - 0163A000h
foo_input_std                    loaded at 01660000h - 01773000h
foo_input_tak                    loaded at 017A0000h - 017E7000h
tak_deco_lib                    loaded at 01800000h - 01831000h
oleaut32                        loaded at 77120000h - 771AC000h
foo_input_tta                    loaded at 01960000h - 0198D000h
foo_joystick_control            loaded at 019B0000h - 019CB000h
DINPUT8                          loaded at 6CE10000h - 6CE48000h
foo_lnk                          loaded at 019F0000h - 01A09000h
foo_masstag                      loaded at 01A30000h - 01A7F000h
foo_masstag_addons              loaded at 01AA0000h - 01ABD000h
foo_menu_addons                  loaded at 01AD0000h - 01B21000h
foo_navigator                    loaded at 01B40000h - 01B71000h
foo_out_ks                      loaded at 01BA0000h - 01BCA000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playcount                    loaded at 01BF0000h - 01C18000h
foo_psf                          loaded at 01C40000h - 01D21000h
foo_rgscan                      loaded at 01D50000h - 01D98000h
foo_rg_trn                      loaded at 01DC0000h - 01DDB000h
foo_run                          loaded at 01E00000h - 01E2B000h
foo_scheduler                    loaded at 01E50000h - 01EBF000h
POWRPROF                        loaded at 74AD0000h - 74AD8000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_skip                        loaded at 01F60000h - 01F7B000h
foo_snesapu                      loaded at 01FA0000h - 01FB3000h
foo_uie_albumart                loaded at 01FD0000h - 0200C000h
foo_uie_albumlist                loaded at 02030000h - 0206D000h
foo_uie_peakmeter                loaded at 02090000h - 020B8000h
foo_uie_playlists_dropdown      loaded at 020E0000h - 02119000h
foo_uie_queuemanager            loaded at 02140000h - 02179000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA6000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
foo_uie_quicksearch              loaded at 048D0000h - 04916000h
foo_uie_tabs                    loaded at 04930000h - 0495A000h
foo_uie_vis_egoh                loaded at 04980000h - 0499D000h
foo_ui_columns                  loaded at 049B0000h - 04A53000h
foo_ui_panels                    loaded at 04A80000h - 04B69000h
foo_unpack                      loaded at 04B90000h - 04BBE000h
foo_utils                        loaded at 04BE0000h - 04C18000h
foo_verifier                    loaded at 04C40000h - 04C70000h
ctagent                          loaded at 05090000h - 05096000h
dciman32                        loaded at 73BC0000h - 73BC6000h
dsp_iZOzone                      loaded at 05C60000h - 05FC2000h
MSVCP60                          loaded at 76080000h - 760E5000h
WININET                          loaded at 771B0000h - 7725A000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
Msimg32                          loaded at 76380000h - 76385000h
HID                              loaded at 688F0000h - 688F9000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Address: 00E41CA0h, location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Address: 004DF178h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00E4949Ch, location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Address: 00E494C0h, location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Address: 00E48A18h, location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Address: 00E41CFFh, location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Address: 00E49490h, location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D5418Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D4C331h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D541B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D53FD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 77D541E2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D484FCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D485A4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D54204h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B89Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetParent" (+0000016Ch)
Address: 77D4B903h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 773EAFF1h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal414" (+00000FB4h)
Address: 7743C666h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+000507C6h)
Address: 77D4B96Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsWindow" (+00000038h)
Address: 774206BFh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0003481Fh)
Address: 011F010Bh, location: "libmmd", loaded at 00FB0000h - 01261000h
Symbol: "_csqrtq_f90" (+0023D7CFh)
Address: 77420AA6h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00034C06h)
Address: 774214D9h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00035639h)
Address: 77420C82h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00034DE2h)
Address: 05C614E7h, location: "dsp_iZOzone", loaded at 05C60000h - 05FC2000h
Address: 77D48BD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 77D541DCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+00000301h)
Address: 77D541A9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002CEh)
Address: 77DA0088h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D53FEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+0000010Fh)
Address: 77D6E54Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcA" (+00000000h)
Address: 049818AFh, location: "foo_uie_vis_egoh", loaded at 04980000h - 0499D000h
Address: 77D48B26h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 77D6E571h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcA" (+00000022h)
Address: 77D4EB3Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D5E04Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsDialogMessageW" (+0000008Eh)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 0042FE21h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004C0530h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00D4DAEAh, location: "foo_cuesheet_creator", loaded at 00D40000h - 00D6D000h
Address: 00430967h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004BC438h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 004E4198h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004B49CCh, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 004E3E68h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004E4218h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00407E27h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 0049812Dh, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004C0540h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004AF4F4h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00430B6Eh, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004973CAh, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004936FCh, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004936F6h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004B33D0h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004E4210h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004AF8E8h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00496284h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839A10h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004962EDh, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 01C79D42h, location: "foo_psf", loaded at 01C40000h - 01D21000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004F2000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Album list panel 0.2.1  (foo_uie_albumlist)
Shell Link Resolver 1.2  (foo_lnk)
ReplayGain override 0.1.1  (foo_rg_trn)
bs2b 2.1.0  (foo_dsp_bs2b)
VLevel 20060324.0  (foo_dsp_vlevel(3))
Special file info box 2.0.4  (foo_infobox)
Joystick Control 0.0.2  (foo_joystick_control)
Cuesheet Creator 0.4.5  (foo_cuesheet_creator)
foo_skip 0.2  (foo_skip)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Menu Addons 0.3.9.5 (Intel SSE)  (foo_menu_addons)
DUMB module decoder 0.9.8.4  (foo_dumb)
Columns UI 0.2.0 alpha 2  (foo_ui_columns)
foo_custominfo 0.1.2  (foo_custominfo)
Highly Experimental 2.0.5  (foo_psf)
Winamp DSP Bridge 1.4.1  (foo_dsp_winamp)
SoundTouch DSP 0.1  (foo_dsp_soundtouch)
Masstagger Addons 0.3.4 (Intel SSE)  (foo_masstag_addons)
Crossfeed 0.92  (foo_dsp_crossfeed)
Scheduler 3.53  (foo_scheduler)
Navigator 0.6  (foo_navigator)
Kernel Streaming Output 1.2.2  (foo_out_ks)
ABX Comparator 1.3.1  (foo_abx)
SNESAPU SPC Decoder 0.50  (foo_snesapu)
Audio CD Writer 2.0.1  (foo_burninate)
Fullscreen 0.3.1  (foo_fullscreen)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
Album Art Browser
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00451F5Eh
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Code bytes (00451F5Eh):
00451F1Eh:  8B 06 8B CE FF 10 B0 01 EB 11 83 4D FC FF 8B 4D
00451F2Eh:  F0 85 C9 74 04 8B 01 FF 10 32 C0 8B 4D F4 5F 5E
00451F3Eh:  5B 64 89 0D 00 00 00 00 C9 C2 08 00 B8 30 86 4A
00451F4Eh:  00 E8 78 41 05 00 83 EC 14 8B 4D 10 8B 01 53 57
00451F5Eh:  FF 10 8D 5E 18 89 45 F0 8B 03 8B CB FF 10 8B 7D
00451F6Eh:  0C 3B F8 76 0B 8B 03 8B CB FF 10 89 45 0C 8B F8
00451F7Eh:  8B 55 F0 85 D2 0F 86 FE 00 00 00 8B 4E 4C 85 C9
00451F8Eh:  74 11 FF 75 14 8B 01 FF 75 10 57 FF 50 0C 8B 55
Stack (0012F4D0h):
0012F4B0h:  0012F7A0 7C9C93C0 77F643DD 7C9C93C0
0012F4C0h:  00000004 00000000 0012ECAC 00000000
0012F4D0h:  FFFFFFFF 00000000 00CD4478 00000000
0012F4E0h:  FFFFFFFF 004BDD00 00451F54 0012F558
0012F4F0h:  004A8630 FFFFFFFF 004DF178 00452C67
0012F500h:  0000000F FFFFFFFF 000801ED 0012F540
0012F510h:  0000000F 00E4205B 0000000F FFFFFFFF
0012F520h:  000801ED 0012F540 30A37F4E 0012F81C
0012F530h:  00E41CA0 0012F578 00000000 004DF178
0012F540h:  00E4949C 00E494C0 00E8DFC8 00000011
0012F550h:  00000011 00000000 0012F600 00E48A18
0012F560h:  00000002 00E41CFF 00E86708 00E49490
0012F570h:  0012F5E0 00E41CA0 0012F5A4 77D48734
0012F580h:  001C0290 0000004E 000003E9 0012F81C
0012F590h:  00E41CA0 DCBAABCD 00000000 0012F5E0
0012F5A0h:  00E41CA0 0012F610 77D5418D 00E41CA0
0012F5B0h:  001C0290 0000004E 000003E9 0012F81C
0012F5C0h:  0000004E 001C0290 007295C8 00000014
0012F5D0h:  00000001 00000000 00000000 00000010
0012F5E0h:  00000000 00000000 00000000 00000001
Registers:
EAX: 00000000, EBX: 00000000, ECX: 000801ED, EDX: 00452C34
ESI: 04CD4460, EDI: FFFFFFFF, EBP: 0012F4F8, ESP: 0012F4D0
Crash location: "foobar2000", loaded at 00400000h - 004F2000h
Loaded modules:
dsp_iZOzone                      loaded at 05E60000h - 061C2000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
browseui                        loaded at 75F80000h - 7607D000h
ksuser                          loaded at 73EE0000h - 73EE4000h
xpsp2res                        loaded at 20000000h - 202C5000h
Address: 00CD4478h, location: "foo_convolve", loaded at 00CC0000h - 00D11000h
Address: 004BDD00h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00451F54h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 004A8630h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00452C67h, location: "foobar2000", loaded at 00400000h - 004F2000h
Address: 00E4205Bh, location: "foo_cwbowron", loaded at 00E40000h - 00E52000h
Address: 7741C0D5h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00030235h)
Address: 01830113h, location: "tak_deco_lib", loaded at 01800000h - 01831000h
Address: 05E614E7h, location: "dsp_iZOzone", loaded at 05E60000h - 061C2000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Just to inform you.
Album Art Browser
I'm using this as my cover art string:
$if($cwb_fileexists(c:\album art\%artist% - %album% '('front')'.jpg),c:\album art\%artist% - %album% '('front')'.jpg,$if($cwb_fileexists(c:\album art\%artist% - %album% '('front')'.gif),c:\album art\%artist% - %album% '('front')'.gif,c:\nocover.jpg))
Sometimes the final nocover.jpg is used, sometimes nothing is used, and the album doesn't appear -- I don't think this is something wrong with the string, as I've put it in a playlist view column, and it comes out fine.  I can't find a pattern -- this happens even with albums that don't have weird characters in their names.
Album Art Browser
I use this.
$if($cwb_fileexists($replace(%path%,%filename_ext%,)folder.jpg)
,$replace(%path%,%filename_ext%,)folder.jpg,C:\Program Files\foobar2000\no\nocover.jpg)
All album that not have album art will group in "nocover.jpg" album pic in album browser. and use first album name it can find.
this maybe fix in future. i think
Album Art Browser
I can get a panel to show up in PanelsUI with this plugin, no problem there.
I can configure the colors, and the size of the thumbnail, no problem there.
Double-clicking on the Album Art does create a new playlist with the appropriate name, and does start playing the playlist, no problem there.
Bug Report:
1.)  I can add one album art, however when I select the second album art to add, it replaces the first one.  So, it will show no more than one album art in the panel.
2.)  As already mentioned earlier in this thread, double clicking on a blank spot in the panel produces a crash and burn......
3.)  As far as I can tell, there is no way to remove the one and only Album Art that does show up in the panel.  I've gone thru all the context menu options, and the closest I've come is to empty the newly created playlist, but the playlist still remains, and so does the thumbnail in the panel.
I think this has some good possibilities, once things are ironed out...  Thanks!
Album Art Browser
I use this.
Yes, currently the groupings are based on the image paths and since your files that don't have art all resolve to the nocover.jpg, all the files without album art fall into that one no cover file.  I plan to add a nocover file option so that you can just use the part that looks for a folder.jpg and if doesnt find one then it will use the nocover picture, but each album without art will show up with different labels.
Album Art Browser
Reason: This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.  "
Windows XP SP2, Panels UI, FB2K 0.9.4.3
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
Album Art Browser
Chris,
Everything works as expected during the instance of fb2k that is running. If I close down and re-open fb2k, my browser is wiped clean. Is that what is supposed to happen?
If I double left click my mouse in the browser window, fb2k crashes.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00C82045h
Call path:
entry=>app_mainloop
Code bytes (00C82045h):
00C82005h:  55 00 50 50 8B 42 24 56 8B CD FF D0 8B 55 00 8B
00C82015h:  F0 8B 42 5C 56 8B CD FF D0 8B 55 00 8B 52 44 8D
00C82025h:  44 24 44 50 56 8B CD C7 44 24 4C 90 94 C8 00 FF
00C82035h:  D2 8B 44 24 40 8B 48 2C C7 44 24 18 9C 94 C8 00
00C82045h:  8B 04 B9 8B 55 00 8B 52 50 8D 4C 24 18 51 50 6A
00C82055h:  FF 56 8B CD FF D2 8B 45 00 8B 50 14 56 8B CD FF
00C82065h:  D2 8B 45 00 8B 50 1C 56 8B CD FF D2 89 5C 24 40
00C82075h:  8D 7C 24 40 C6 44 24 38 03 E8 6D 29 00 00 C6 44
Stack (0013F528h):
0013F508h:  0117DCDC 7C9C93C0 77F643DD 7C9C93C0
0013F518h:  00000004 00000000 0117D1E8 00000000
0013F528h:  1C7C69A1 0013F81C 00C81CA0 0013F578
0013F538h:  00000000 004DF178 00C8949C 00C894C0
0013F548h:  00CC2A78 00000020 00000020 0000000F
0013F558h:  0013F600 00C88A18 00000002 00C81CFF
0013F568h:  00CC3DB0 00C89490 0013F5E0 00C81CA0
0013F578h:  0013F5A4 7E418734 001F0714 0000004E
0013F588h:  000003E9 0013F81C 00C81CA0 DCBAABCD
0013F598h:  00000000 0013F5E0 00C81CA0 0013F610
0013F5A8h:  7E423745 00C81CA0 001F0714 0000004E
0013F5B8h:  000003E9 0013F81C 0000004E 001F0714
0013F5C8h:  0079DC40 00000014 00000001 00000000
0013F5D8h:  00000000 00000010 00000000 7E41C331
0013F5E8h:  00000000 00000001 00000000 00000000
0013F5F8h:  0013F5C0 0013F14C 0013F6F8 7E440457
0013F608h:  7E423768 00000000 0013F658 7E423591
0013F618h:  00000000 00C81CA0 001F0714 0000004E
0013F628h:  000003E9 0013F81C 0079DC54 0013F660
0013F638h:  0013F6DC 7E42379A 00000000 000003E9
Registers:
EAX: 00CC3DB0, EBX: 00000000, ECX: 00000000, EDX: 00163538
ESI: 0000000B, EDI: FFFFFFFF, EBP: 004DF178, ESP: 0013F528
Crash location: "foo_cwbowron", loaded at 00C80000h - 00C92000h
Loaded modules:
USER32                          loaded at 7E410000h - 7E4A0000h
apphelp                          loaded at 77B40000h - 77B62000h
foo_ac3                          loaded at 00A70000h - 00A9F000h
foo_albumlist                    loaded at 00AC0000h - 00B07000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_burninate                    loaded at 00B30000h - 00B67000h
foo_cdda                        loaded at 00B90000h - 00BC5000h
foo_converter                    loaded at 00BF0000h - 00C59000h
foo_cwbowron                    loaded at 00C80000h - 00C92000h
foo_dop                          loaded at 00CD0000h - 00D36000h
foo_dsp_std                      loaded at 00D60000h - 00DA1000h
foo_freedb2                      loaded at 00DD0000h - 00E10000h
foo_infobox                      loaded at 00E30000h - 00E70000h
foo_input_dts                    loaded at 00E90000h - 00EF5000h
foo_input_matroska              loaded at 00F20000h - 00FA8000h
foo_input_std                    loaded at 00FD0000h - 010E3000h
foo_input_tak                    loaded at 01110000h - 01157000h
tak_deco_lib                    loaded at 01170000h - 011A1000h
foo_masstag                      loaded at 012D0000h - 0131F000h
foo_playcount                    loaded at 01340000h - 01368000h
foo_rgscan                      loaded at 01390000h - 013D8000h
foo_uie_albumart                loaded at 01400000h - 0143A000h
foo_uie_albumlist                loaded at 01460000h - 0149F000h
foo_uie_explorer                loaded at 014C0000h - 014FC000h
foo_uie_playlists_dropdown      loaded at 01520000h - 01559000h
foo_uie_tabs                    loaded at 01580000h - 015A9000h
foo_uie_trackinfo                loaded at 015D0000h - 015FE000h
foo_ui_columns                  loaded at 01620000h - 016C2000h
foo_ui_std                      loaded at 016F0000h - 01747000h
foo_unpack                      loaded at 01770000h - 0179E000h
foo_utils                        loaded at 017C0000h - 017F8000h
foo_utils_matroska              loaded at 01820000h - 0183A000h
ctagent                          loaded at 01960000h - 01966000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
Address: 00C81CA0h, location: "foo_cwbowron", loaded at 00C80000h - 00C92000h
Address: 00C8949Ch, location: "foo_cwbowron", loaded at 00C80000h - 00C92000h
Address: 00C894C0h, location: "foo_cwbowron", loaded at 00C80000h - 00C92000h
Address: 00C88A18h, location: "foo_cwbowron", loaded at 00C80000h - 00C92000h
Address: 00C81CFFh, location: "foo_cwbowron", loaded at 00C80000h - 00C92000h
Address: 00C89490h, location: "foo_cwbowron", loaded at 00C80000h - 00C92000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E423745h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41C331h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E423768h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E423591h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E42379Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4184FCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4185A4h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4237BCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B89Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B903h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B96Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 015D9B37h, location: "foo_uie_trackinfo", loaded at 015D0000h - 015FE000h
Address: 015D9B56h, location: "foo_uie_trackinfo", loaded at 015D0000h - 015FE000h
Address: 77F15B80h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SelectObject" (+00000000h)
Address: 015DC030h, location: "foo_uie_trackinfo", loaded at 015D0000h - 015FE000h
Address: 015D30F3h, location: "foo_uie_trackinfo", loaded at 015D0000h - 015FE000h
Address: 015D33EBh, location: "foo_uie_trackinfo", loaded at 015D0000h - 015FE000h
Address: 015EC05Ch, location: "foo_uie_trackinfo", loaded at 015D0000h - 015FE000h
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41F896h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4189CDh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41DAEAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E42D950h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4189F0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E418A10h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 0041DAEAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C90EA00h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtWriteFile" (+0000000Dh)
Address: 00441621h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01000000h, location: "foo_input_std", loaded at 00FD0000h - 010E3000h
Address: 00499193h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0117D19Ch, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 77DDE350h, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "ObjectOpenAuditAlarmW" (+000007B7h)
Address: 00470045h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041004Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00480043h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0053h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0117CFA4h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 7C914D8Fh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAppendUnicodeToString" (+0000004Dh)
Address: 77DDD248h, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "SaferComputeTokenFromLevel" (+000024F3h)
Address: 0117D018h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117CFC4h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117D0BCh, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117CF24h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117F8C0h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 77DDE0AEh, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "ObjectOpenAuditAlarmW" (+00000515h)
Address: 0117D250h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 010800CCh, location: "foo_input_std", loaded at 00FD0000h - 010E3000h
Address: 0117D204h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 77DDE32Eh, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "ObjectOpenAuditAlarmW" (+00000795h)
Address: 0117D054h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117D06Ch, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117D180h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 7C90E1FEh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwQueryValueKey" (+00000000h)
Address: 0117D0C0h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117D07Ch, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 7C90FB6Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosError" (+0000002Fh)
Address: 77F643D0h, location: "SHLWAPI", loaded at 77F60000h - 77FD6000h
Symbol: "SHRegGetValueW" (+000000B1h)
Address: 0117D1E8h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 0117DCDCh, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 7C9C93C0h, location: "SHELL32", loaded at 7C9C0000h - 7D1D5000h
Symbol: "Ordinal517" (+000093C0h)
Address: 77F643DDh, location: "SHLWAPI", loaded at 77F60000h - 77FD6000h
Symbol: "SHRegGetValueW" (+000000BEh)
Address: 0117D0B8h, location: "tak_deco_lib", loaded at 01170000h - 011A1000h
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Tabbed panel modified 0.2.4  (foo_uie_tabs)
iPod manager 0.4.1 TEST  (foo_dop)
AC3 decoder 0.9  (foo_ac3)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Matroska Utility Plugin 1.0.2  (foo_utils_matroska)
Album List 3.2.0  (foo_albumlist)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Playlists Dropdown 0.5.7.1  (foo_uie_playlists_dropdown)
Track info panel 0.8  (foo_uie_trackinfo)
Album Art Panel 0.2.5.2  (foo_uie_albumart)
Default User Interface 0.9acc  (foo_ui_std)
Matroska Plugin 0.9.2.0  (foo_input_matroska)
This is a pretty cool plugin. I'm impressed with it's possibilities.
Dirk
Surf's Up!
Album Art Browser
I'm getting the same error.
Album Art Browser
Just for the sake of testing, this doesn't function for me under Columns UI either. I am using the 2.0 Beta, Number 2.
Album Art Browser
I am using columns UI 2.0 beta 2. I have no preference panel. One other little thing, if i select file in my playlist and do browse alum art it works, but if i select an item in album list panel and do browse album art, it doesnt work.
Seems to be a very cool component, thanks for your work
