Topic: Exact Audio Copy V0.99 prebeta 3 (Read 95898 times) previous topic - next topic
  • magic75
Change Log
- Better AccurateRip support (reading ranges and CD images)
- Improved log file output
- Flac encoder now comes with EAC
- Much improved configuration wizard
- Writing CD-Text using CDRDAO
- Copy and test range
- Added writing new tags for ID3V2 like duration, encoder settings and the CD TOC
- Correction of Xing header after writing ID3V2
- Drive options are now stored by the drive name and not by adapter and LUN
- Fixed many issues and bugs
Homepage & Download: http://www.exactaudiocopy.de/
Alternative: http://www.exactaudiocopy.de/en/index.php/...tive-servers-2/
  • Last Edit: 30 June, 2007, 05:04:32 AM by magic75
  • Synthetic Soul
  • Global Moderator
Test & Copy for images.
I guess I'm going to have to give that a try.
Thanks for the info.
I'm on a horse.
  • Fandango
<fanboymode>  Eat that dMC!  </fanboymode>
AR and T&C for images!
FLAC and AR come with the Installer now!
Great work, Andre!
  • gib
So AccurateRip is usable even when ripping to images?  Woo hoo!
  • greynol
  • Global Moderator
...and ranges as well.
  • Fandango
Yep, since image rips are actually a range copy.
  • greynol
  • Global Moderator
Nope, there is a distinct difference:  ripping an image is a specific case of copying ranges.
  • Last Edit: 30 June, 2007, 12:54:35 PM by greynol
  • Keykey
Installed the new EAC and I am testing the T&C for images.
Ripping now a cd and it will take well over 40 minutes!!!      Read speed is just (while re-reading) 1.2X
I use Secure Mode and a cd is ripped normally in 7 - 8 minutes. Why does it take so long to "check" the Image?? Am I losing something in the way?
EDIT
LOG:
Exact Audio Copy V0.99 prebeta 1 from 25. May 2007
EAC extraction logfile from 30. June 2007, 19:04
Aces High / Pull No Punches
Used drive  : PLEXTOR CD-R  PREMIUM  Adapter: 1  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 30
Overread into Lead-In and Lead-Out          : Yes
Delete leading and trailing silent blocks  : No
Used interface                              : Installed external ASPI interface
Used output format              : User Defined Encoder
Selected bitrate                : 32 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Archivos de programa\Exact Audio Copy\wapet.exe
Additional command line options : %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" mac.exe %s %d -c3000 -v
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.32 |  4:50.65 |        32    |    21846
        2  |  4:51.22 |  4:23.30 |    21847    |    41601
        3  |  9:14.52 |  4:02.73 |    41602    |    59824
        4  | 13:17.50 |  5:33.57 |    59825    |    84856
        5  | 18:51.32 |  4:20.08 |    84857    |  104364
        6  | 23:11.40 |  6:30.17 |    104365    |  133631
        7  | 29:41.57 |  4:21.18 |    133632    |  153224
        8  | 34:03.00 |  5:04.35 |    153225    |  176059
        9  | 39:07.35 |  4:29.65 |    176060    |  196299
      10  | 43:37.25 |  5:14.45 |    196300    |  219894
Range status and errors
Selected range
    Filename C:\RIPEOS EAC\Aces High - Pull No Punches.wav
    Peak level 0.0 %
    Range quality 97.0 %
    Test CRC 28697CAA
    Copy OK
AccurateRip summary
Track  1  accurately ripped (confidence 1)  [945F87DF]
Track  2  accurately ripped (confidence 1)  [381493BD]
Track  3  accurately ripped (confidence 1)  [A8E4D508]
Track  4  accurately ripped (confidence 1)  [E1B66268]
Track  5  accurately ripped (confidence 1)  [1A80E060]
Track  6  accurately ripped (confidence 1)  [57F8461C]
Track  7  accurately ripped (confidence 1)  [5A7AEA3A]
Track  8  accurately ripped (confidence 1)  [6F112F39]
Track  9  accurately ripped (confidence 1)  [5BC45176]
Track 10  accurately ripped (confidence 1)  [E4A14345]
No errors occurred
End of status report
After over 40 minutes I get a 0.08 MB *.ape file!!!  or    --> don't know what to do!
  • Last Edit: 30 June, 2007, 01:09:14 PM by Keykey
  • eofor
10 years in beta - this must be the longest development-stage ever? Google must be jealous
  • Elbart
Another one who fell into the version-number-trap...
  • Fandango
You know what really irritates me here? This:
While the rip obviously went wrong, correct data was actually extracted at some point... wasn't it? Or did you manage to change your computer ID for AR somehow?
  • Last Edit: 30 June, 2007, 01:32:54 PM by Fandango
  • greynol
  • Global Moderator
How do you know that the actual rip went wrong?
Seems like there was a problem with the encoding, not the rip.
  • Last Edit: 30 June, 2007, 01:40:47 PM by greynol
  • Fandango
Peak level 0.0 %
A CD filled with silence?
  • greynol
  • Global Moderator
Good point.
  • Keykey
Peak level 0.0 %
I have just noticed this
I am doing additional rips to see if I find what went wrong
  • greynol
  • Global Moderator
...though it looks like there was only a test CRC that was generated.  Was that the enitre log?
btw, the "-v" in your command line does absolutely nothing(!) (unless it's causing an error).
Why not test one thing at a time instead of blowing your wad all at once?  Try T&C of the image as a wave file.
  • Last Edit: 30 June, 2007, 01:46:49 PM by greynol
  • Fandango
Yes! That's odd.  The Copy CRC is missing.
It is possible to save and see the log of a test without actually doing a rip to the disk, but only for Track based tests ("Test Selected Tracks" F8). How did you manage to do "Test Image"? Maybe there is something wrong with the encoder settings and it will make EAC skip the copy part?
  • Last Edit: 30 June, 2007, 01:53:26 PM by Fandango
  • Keykey
1.- Yes, it was the entire log.
2.- Thanks for the tip about the -v commnad. I had never been sure it should be there or not
This time I did not use the "Test and copy" but just "Copy the Image":
EAC extraction logfile from 30. June 2007, 19:43
Deep Purple / Machine Head
Read mode              : Secure
Quality                        : High
Add ID3 tag                    : No
        1  |  0:00.33 |  6:08.57 |        33    |    27689
        2  |  6:09.15 |  4:50.33 |    27690    |    49472
        3  | 10:59.48 |  5:03.50 |    49473    |    72247
        4  | 16:03.23 |  3:59.55 |    72248    |    90227
        5  | 20:03.03 |  5:40.55 |    90228    |  115782
        6  | 25:43.58 |  7:22.00 |    115783    |  148932
        7  | 33:05.58 |  4:32.57 |    148933    |  169389
Selected range
    Filename C:\RIPEOS EAC\Deep Purple - Machine Head.wav
    Peak level 100.0 %
    Range quality 100.0 %
    Copy CRC 6FBD68AD
    Copy OK
AccurateRip summary
Track  1  accurately ripped (confidence 7)  [648E1CE7]
Track  2  accurately ripped (confidence 7)  [022C25E2]
Track  3  accurately ripped (confidence 7)  [BD1E3539]
Track  4  accurately ripped (confidence 7)  [E1697794]
Track  5  accurately ripped (confidence 8)  [4DF6E910]
Track  6  accurately ripped (confidence 7)  [69A5A7BE]
Track  7  accurately ripped (confidence 7)  [662A3CE0]
No errors occurred
Doing now another rip with T&C
  • Fandango
But that's a different CD.
  • Keykey
Yes.
I am going to try again with the previous one. Results in an hour or so.
  • Synthetic Soul
  • Global Moderator
NB: Here's the log from my first image T&C.
EAC extraction logfile from 30. June 2007, 14:35
Kings of Leon / Aha Shake Heartbreak
Used drive  : PLEXTOR CD-R  PX-W5224A  Adapter: 1  ID: 0
Read mode              : Secure
Make use of C2 pointers : Yes
Overread into Lead-In and Lead-Out          : No
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
       1  |  0:00.00 |  3:54.09 |        0    |    17558
       2  |  3:54.09 |  2:25.36 |    17559    |    28469
       3  |  6:19.45 |  3:05.43 |    28470    |    42387
       4  |  9:25.13 |  2:20.52 |    42388    |    52939
       5  | 11:45.65 |  4:00.20 |    52940    |    70959
       6  | 15:46.10 |  2:55.44 |    70960    |    84128
       7  | 18:41.54 |  2:59.24 |    84129    |    97577
       8  | 21:41.03 |  2:15.63 |    97578    |  107765
       9  | 23:56.66 |  3:33.01 |    107766    |  123741
       10  | 27:29.67 |  2:09.33 |    123742    |  133449
       11  | 29:39.25 |  2:11.00 |    133450    |  143274
       12  | 31:50.25 |  3:22.39 |    143275    |  158463
       13  | 35:12.64 |  2:23.61 |    158464    |  169249
Selected range
     Filename E:\CDBackup\Kings of Leon - Aha Shake Heartbreak.wav
     Peak level 100.0 %
     Test CRC 95EB659B
     Copy CRC 95EB659B
     Copy OK
AccurateRip summary
Track  1  accurately ripped (confidence 7)  [26C3C3B3]
Track  2  accurately ripped (confidence 7)  [021E9A14]
Track  3  accurately ripped (confidence 7)  [4C3E3743]
Track  4  accurately ripped (confidence 7)  [4E7A5ED3]
Track  5  accurately ripped (confidence 7)  [4969222B]
Track  6  accurately ripped (confidence 7)  [12513A61]
Track  7  accurately ripped (confidence 7)  [FC28C812]
Track  8  accurately ripped (confidence 7)  [8BA6ECBC]
Track  9  accurately ripped (confidence 7)  [81053A0E]
Track 10  accurately ripped (confidence 7)  [EB37A4B2]
Track 11  accurately ripped (confidence 7)  [99260264]
Track 12  accurately ripped (confidence 7)  [CD02F674]
Track 13  accurately ripped (confidence 7)  [7E6B6A3B]
No errors occurred
I'm on a horse.
Only the alternate download links go to 0.99 PB1 for me... the main links still point to 0.95 B4.
"Have you ever been with a woman? It's like death. You moan, you scream and then you start to beg for mercy, for salvation"
  • Keykey
Same result, again
EAC extraction logfile from 30. June 2007, 21:10
Read mode               : Secure
Quality                         : High
Add ID3 tag                     : No
Selected range
     Peak level 0.0 %
     Test CRC 28697CAA
     Copy OK
AccurateRip summary
No errors occurred
  • prankstare
Nice,
Besides the fact FLAC codec is now packed together with the new release, EAC will now store their log file into the extracting directory. Speaking of changes, the selective bitrate range now goes from 32 to 1024kBit/s in 'User Defined Encoder' parameter.
Slight changes but, Wow. Great job.
  • odyssey
SERIOUS BUG FOUND!
When you tick "Eject CD after extraction", and performs a T/C image, it will eject the CD after the test is done, and proceed ripping as if the disc were present.
