Topic: Mouse click as 'keyboard' shortcut (Read 5042 times) previous topic - next topic
First of: I'm a Vista user with a fresh install of Foobar. So when switching from XP I didn't copy my Foobar folder over to Vista or anything.
Foobar works fine on Vista; I have and had no crashes whatsoever.
My mouse is a Logitech MX310, but Logitech has no Vista drivers for this one so it's functioning on the default Vista drivers (» only left/right button and scrollwheel work, clicking the scrollwheel also works).
To the 'problem': under XP I had a shortcut set up; when I middle-clicked a song (so click with my scrollwheel), it got added to my playback queue. When I try to add this as a shortcut under Vista, it does not work. When I middle-click in the "Key" input box the click isn't registered. All my keyboard keys DO register when I click them.
So to put it short: Foobar won't allow a mouse-button as a shortcut in Vista, while it did under Windows XP.
My theory is that under XP it would because I had the Logitech drivers, however I'm not shure: is Foobar designed to also accept mouse buttons as shortcuts or not?
AFAIK I am using the latest Foobar version. These are my installed components:
Core (2007-04-20 21:36:34)
    foobar2000 core 0.9.4.3
foo_albumlist.dll (2007-04-20 21:34:58)
    Album List 3.2.0
foo_audioscrobbler.dll (2007-05-13 14:23:40)
    Audioscrobbler 1.3.6
foo_browser.dll (2007-03-23 16:53:12)
    Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]
foo_cdda.dll (2007-04-20 21:34:44)
    CD Audio Decoder 2.1.1
foo_converter.dll (2007-04-20 21:34:28)
    Converter 1.0.1
foo_cwb_hooks.dll (2007-05-04 12:45:42)
    cwbowron's title format hooks 1.1.1 [May  4 2007 - 12:39:47]
foo_dsp_crossfader.dll (2007-06-13 00:02:08)
    Gapless Crossfader 0.3.2.2 (Intel SSE)
foo_dsp_crossfeed.dll (2006-03-21 16:32:54)
    Crossfeed 0.92
foo_dsp_delta.dll (2006-03-21 18:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_std.dll (2007-01-20 01:36:56)
    Standard DSP array 1.0
foo_input_std.dll (2007-04-20 21:34:22)
    FLAC Decoder 1.1.0
    Standard Input Array 1.0
    WMA Decoder 1.1
foo_masstag.dll (2007-04-20 21:33:44)
    Masstagger 1.6
foo_rgscan.dll (2007-04-20 21:33:22)
    ReplayGain Scanner 2.0.2
foo_ui_columns.dll (2006-11-22 14:05:24)
    Columns UI 0.1.3 beta 1v7
foo_ui_panels.dll (2007-05-23 02:07:40)
    Panels UI 0.13.3 beta [May 23 2007 - 02:07:20]
foo_ui_std.dll (2007-04-20 21:33:14)
    Default User Interface 0.9acc
foo_uie_peakmeter.dll (2007-06-05 21:12:42)
    Peakmeter Panel 0.0.1
foo_uie_queuemanager.dll (2006-12-17 03:21:36)
    Queue manager panel 0.2.3
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_uie_tabs.dll (2006-10-17 22:54:32)
    Tabbed panel modified 0.2.5
Thanks in advance for helping!
Les mots d'amour...
Just go here to get your Vista driver...
http://www.radarsync.com/vista/index.php?vendor=Logitech
Problem solved all the way around, yes?
Aha apparently Logitech now ahs Vista drivers for older mouses.
However, I still can't assign a mouse click to a shortcut.
Does anyone know: is Foobar designed to accept mouse-buttons as shortcuts?
Les mots d'amour...
No. Your mouse driver on XP must have translated a middle-click into a keyboard event.
Ok. I can live with that; at least it's not something I can do anything about
Thanks for the reply.
Won't that driver I pointed you to let you set what each mouse click does, for any specific program?
For example, I run a Kensington Expert Pro Trackball, and the driver lets me translate any one of the clicks into any keyboard event I choose, for any specific program I have installed.  A middle click can mean one thing in one program, and another thing in another program.
Doesn't your driver do this also, I thought that was somewhat universal?
My mouse is a "Microsoft IntelliMouse Optical" (Generic 5-button mouse) and I'm also running Vista.
The mouse button Shortcuts work fine for me...
