Topic: Speex batch decoding (Read 5986 times) previous topic - next topic
  • N00berd
I need a programm that can batch decode speex files. It should be able to decode all speex files in a directory to wav files and it should be free and a commandline programm because I want to run it from an installer.
I've heard speexdec.exe is able to batch convert files: http://lists.xiph.org/pipermail/speex-dev/...ary/005227.html but it did'nt work.
What's wrong?
Hallo,
ich suche ein Programm, das mehrere Speex-Dateien in einem Verzeichnis auf einmal in Wav-Dateien umwandeln kann. Es sollte ein Commandline-Programm sein, weil ich es aus einem Installer heraus ausrufen möchte (wird eine Mod für ein Computerspiel, das aber nur .wav-Dateien annimt, die sind mir aber zu groß).
Ich habe gehört, dass es mit speexdec.exe möglich sei: http://lists.xiph.org/pipermail/speex-dev/...ary/005227.html Aber das funktioniert nicht.
Was mache ich falsch?
  • Polar
Hate to break the fun, but it seems to me
http://www.hydrogenaudio.org/forums/index....showtopic=23120
http://www.hydrogenaudio.org/forums/index....amp;s=&f=31
might be interesting reading for you.
Another hint: Foobar ;)
  • Synthetic Soul
  • Global Moderator
Thread moved.
Save the text below as speex-decode.bat, first editing the path to SPEEXDEC.EXE, and then drag the folder containing the SPX files onto the file icon.
@FOR /R %1 %%G IN (*.spx) DO "C:\Path To\SPEEXDEC.EXE" "%%G" "%%~dpnG.wav"
Edit: Just noticed that you want to run this from an installer.  If you can run the command from the installer the syntax should be:
FOR /R %1 %G IN (*.spx) DO "C:\Path To\SPEEXDEC.EXE" "%G" "%~dpnG.wav"
The alternative is to use the batch file, and call it passing the folder as a parameter, i.e.:
speex-decode "C:\Path\To\My Wave Files"
  • Last Edit: 07 June, 2007, 11:58:11 AM by Synthetic Soul
I'm on a horse.
  • N00berd
Thx it works!
But I can hear many loud clicks in the speex files that weren't in the original file except I choose quality 8-10 but the general quality is good (not that metallic as vorbis aO tuv b5  ). Is this a problem with speex or what's wrong?
I'm using speexenc.exe and speexdec.exe both v. 1.2 beta2
