Topic: Converting MPC and WMA to MP3 (Read 4727 times) previous topic - next topic
  • Marc
I have some Wma, m4a and MPC that I ned to convert to MP3.  What MP3 bit rate should I use.
Marc
320 kbps for top quality.
  • Jens Rex
  • Global Moderator
  • Zao
  • Developer (Donating)
Crank your encoder up to 11!
  • Frank Bicking
  • Global Moderator
128 is quite good nowadays.
  • xmixahlx
lol @ "11"
  • greynol
  • Global Moderator
Even when transcoding from a lossy source?
  • pdq
The OP made no mention of the bit rate of the original files. For all we know these are 48 kbps WMA, for which 128 kbps MP3 should be more than adequate. OTOH if they are very high bit rate lossy files and he wants to squeeze them down to play on his DAP then again 128 kbps MP3 could work quite well. We really need to know more about the source files and the intended application before making recommendations.
