Topic: Personal Multiformat ABC/HR test at 96 kbit/s (Read 23596 times) previous topic - next topic
  • IgorC
Codecs :
High anchor  Lame 3.98b1 --vbr-new -V 5
Low anchor Lame 3.98b1 --abr 96
Nero 1.0.7.0 VBR -q 0.34 (approx 96 kbps)
Itunes 7.1.1.5  96 kbit/s VBR
WMA10pro 96 kbit/s CBR 1pass (dbpower converter 12.1)
Lancer Vorbis Aotuv (last oggdropXP nov 10 2006) -q 2.00 (approx 96 kbps)
Decoders:
Nero, itunes, Lancer, lame were decoded by foobar 0.9.4.3
wma10pro by dbprower converter 12.1
Headphones Sennheiser HD 447 and soundcard Audigy SE 24/96
Results:
http://rapidshare.com/files/34474605/96kbps.xls.html
  • Last Edit: 31 May, 2007, 01:36:15 PM by IgorC
  • pepoluan
Thanks for your efforts! Just one suggestion, put the anchors on the left/right ends of the table. Less confusing
But thanks!
Nobody is Perfect.
I am Nobody.
http://pandu.poluan.info
  • IgorC
But thanks!
Thanks for suggestion.
I added more samples to test.
  • IgorC
I added more samples. Now it's 50. New table http://rapidshare.com/files/34474605/96kbps.xls.html
iTunes surprised. It cuts more frecuencies than other encoders however has a higher score.
  • Last Edit: 31 May, 2007, 01:38:28 PM by IgorC
  • ff123
  • Developer (Donating)
Your excel file made it easy to cut and paste to the statistical webalyzer at my site:
http://ff123.net/friedman/stats.html
All tied except for the low anchor.  There is the suggestion (though not statistically validated) that you prefer itunes and Lancer over Nero.
FRIEDMAN version 1.24 (Jan 17, 2002) http://ff123.net/
Tukey HSD analysis
Number of listeners: 50
Critical significance:  0.05
Tukey's HSD:   0.335
Means:
itunes   Lancer   Lame_v5  wma10pro Nero     Lame_abr
  4.60     4.58     4.46     4.45     4.33     3.20
-------------------------- Difference Matrix --------------------------
itunes     0.014    0.136    0.146    0.264    1.396*
Lancer              0.122    0.132    0.250    1.382*
Lame_v5                      0.010    0.128    1.260*
wma10pro                              0.118    1.250*
Nero                                           1.132*
itunes is better than Lame_abr
Lancer is better than Lame_abr
Lame_v5 is better than Lame_abr
wma10pro is better than Lame_abr
Nero is better than Lame_abr
  • IgorC
There is a trouble. The number format is x,xx in Excel and not x.xx as here http://ff123.net/friedman/stats.html
  • Last Edit: 03 June, 2007, 06:15:32 PM by IgorC
  • vinnie97
Look at that, most of the formats are matching or slightly better in quality than the high anchor!  I haven't done any ABX to verify but I suspect my results would be similar.  I'm content with 80 kbps Vorbis on my portable after all.  This would be interesting to see again with the same high anchor but testing for 80 kbps transparency.
  • haregoo
My try.
Encoders
96kbps contenders
aoTuV beta5 (q 2)
iTunes v7.3.1.3 (96k VBR)
Nero AAC Enc v1.1.34.0 (q 0.35)
128kbps contenders
LAME v3.97 (-V5 --vbr-new)
LAME v3.98b4 (-V5)
Samples
All samples comes from Sebastian's choice on 64kbps multi-format listening test. But I couldn't finish every one of them, because it's too hard for this comparison or unfamiliar to me.
Results
sample n    aoTuV    iTunes    L397    L398    Nero
sample 01    3.50    4.20    3.80    2.70    4.30
sample 02    3.50    4.30    4.20    4.20    3.40
sample 03    3.50    4.10    4.30    4.30    4.00
sample 04    3.90    4.10    3.50    3.70    4.20
sample 05    3.00    4.00    5.00    4.00    3.70
sample 06    3.00    5.00    5.00    5.00    5.00
sample 07
sample 08    3.50    5.00    5.00    5.00    5.00
sample 09    3.20    3.50    4.00    2.80    4.20
sample 10    4.00    4.50    4.50    4.00    5.00
sample 11
sample 12    3.90    3.70    3.20    3.90    4.00
sample 13    3.30    4.00    3.50    2.80    4.00
sample 14    3.20    4.00    4.20    3.70    4.00
sample 15    3.50    4.30    4.50    5.00    4.00
sample 16
sample 17    4.00    4.10    3.70    3.20    4.20
sample 18    3.40    4.20    3.70    3.90    4.20
Overall      3.49    4.2    4.14    3.88    4.21
AACs on top, followed by LAME 3.97, then 3.98. aoTuV loses.
Overall quality at this bitrate isn't impressive. I was rarely required to ABX. But AACs and 128kbps MP3 perform well with orchestral samples (No. 6 and 8).
Tukey HSD analysis
Number of listeners: 15
Tukey's HSD:  0.458
Means:
Nero    iTunes  LAME397  LAME398  aoTuV
  4.21    4.20    4.14    3.88    3.49
Nero      0.013    0.073    0.333    0.720*
iTunes              0.060    0.320    0.707*
LAME397                      0.260    0.647*
LAME398                              0.387
Nero is better than aoTuV
iTunes is better than aoTuV
LAME397 is better than aoTuV
  • IgorC
haregoo
Thanks for share the results
Speaking of my test also I think Itunes 96 kbit/s VBR mode doesn't produce 96 kbit/s. For a lot of albums with enough silence itunes still has 105 kbit/s  while Vorbis -q2 and Nero 1.0.7.0 produce something like 89-90 kbits.On average Vorbis and Nero respect with their VBR mode 96 kbit/s bitrate while Itunes always ends on 105-110 kbit/s.
wouldn't be more fair to shift bitrate? something like:
Vorbis -q 2.5 (Instead of -q 2.0)
Nero 1.0.7.0 -q 0.36
Nero 1.1.34 -q 0.34 / -q0.35(?)
But it would be test for 105 kbit/s . Not 96 kbit/s.
  • Last Edit: 08 August, 2007, 12:37:32 PM by IgorC
  • muaddib
What you can expect with Nero 1.1.34 is:
-q 0.34  ->  92kbps
-q 0.35  ->  96kbps
-q 0.37  ->  103kbps
-q 0.38  ->  107kbps
So for test at 105kbps one should be using -q 0.375
  • haregoo
Perhaps iTunes AAC is more like CBR unlike quality-based VBR encoder including aoTuV and Nero VBR setting. iTunes's one doesn't save bitrate for quieter simple part of music, thus most of music will end up with 96-105kbps. As far as these above samples are concerned, I could get fair bitrate table.
  • kennedyb4
I was told that Itunes VBR can only select larger frames and in this case will never have a frame at less than 96. In this respect it does not sound like a true VBR implementation, more like enhanced CBR.
