Topic: Is there a VST plugin to host Winamp DSP? (Read 9923 times) previous topic - next topic
Please help me out.
May I ask why you need to use a winamp plugin in a VST host?
Technically, it is easy ( easier than making a winamp dsp plugin to host vst's, which already exists ).
Quality-wise, it's not too good ( vsts run with 32bit floating point, while winamp dsp effects only work in 16bits, and some with 24bits integer ) so if you plan to use it in an editing program, results can become noisy after some  modifications.
That said, i don't know of any.
Well.. the answer is simple. I need it for some experiment with sounds...
Here's why I would like to use winamp plugins via VST
The Winamp plugin Stereo Tool does a great job of compressing audio and fixing tape recordings. With all the noise in tape recordings, I don't mind it being 16bit only.
I know of no free (or below $50) tool that does the job nearly as good as this tool.
I tried it and it's work.
What bit depth are used in winamp DSP process if use with this VST plugin? 16bit fix point?
I still see that's still a lot of bug though.
Yes, i've hardcoded it to 16 bits stereo, and the samplerate is determined by the host application.
It would be very easy to add two parameters to the UI that would allow setting 8bits/16bits/24bits and mono/stereo. Some code would be required in the Process function to convert between them, but that's not a problem either.
I've opted for these ones, because I'm not sure if there are many dsp's that work at 24bits.
Edit: After reading a bit more, i'm unsure if dsp effects in winamp support 24bits. ( the buffer passed is short int* , which means 16bits, if it doesn't use hacks which i haven't found documented).
