Topic: SPTD 1.45 Beta (also affects Daemon Tools) (Read 10569 times) previous topic - next topic
Download (32bit and 64bit)
DuplexSecure's official announcement forum post.
(Users of Daemon Tools are also affected by this.)
DuplexSecure released a beta version of SPTD that fixes issues with audio ripping and burning in various apps:
Issues addressed:
- Fixed problem with burning programs based on GearASPI layer (e.g. iTunes)
- Fixed long delay problem in some programs, e.g. Ashampoo Burning Studio
- Fixed crash issue with WinAmp
- Fixed issues with some software tools like Exact Audio Copy, Nero and other programs using SPTI-based ASPI layer
(Edit: links)
There's a new beta out now here. I'm going to test it tonight with EAC and my PX-760 and see if the FUA issue has been fixed or not.
Hopefully iTunes ripping from images with Daemon Tools will finally work with Vista using the new 1.47 Beta ...
The name was Plex The Ripper, not Jack The Ripper
My test with the new SPTD v1.47 beta:
Test drive: PX-760A with the latest firmware revision
Software: Exact Audio Copy V0.95 beta 4
Other interesting things of some interest:
Use of SCSI interface: Installed external ASPI interface (Adaptec's ASPI v4.60)
Drive read command: Read command D8 (found with 'auto detect read command')
Allow speed reduction during extraction: Checked
Without SPTD installed:
EAC without -usefua
[/size]
Test 1:
Drive settings:
Drive has 'Accurate Stream' feature: Checked
Drive caches audio data: Unchecked
Drive is capable of C2 data: Unchecked
Results:
Track ripped with NO reported errors (even though there are)
Test 2:
Drive settings:
Drive caches audio data: Checked
Results:
Read error then sync error, then canceled as it was going at .3x.
Test 3:
Drive settings:
Drive is capable of C2 data: Checked
Results:
Read/sync then canceled
Test 4:
Drive settings:
Results:
Sync error no read error
EAC with -usefua
Test 1:
Drive settings:
Results:
Read error then sync error. Canceled due to slowness.
Test 2:
Drive settings:
Results:
Test 3:
Drive settings:
Results:
Test 4:
Drive settings:
Results:
Read and sync error reported.
Conclusion thus far:
Well, it seems like Plextor's PX-760A does support -usefua with Exact Audio Copy (afterthought: this may not be new news, lol). This is rather good news, especially for people that would decide to use Test 4's settings as the test started out at 17x.
Now to continue on. We know how the PX-760 acts without the -usefua switch so I'm not going to repeat those tests with SPTD installed (though I will upon request) so I'm going to jump right into the with -usefua switch
With SPTD installed
EAC with -usefua
[/size]
Test 1:
Drive settings:
Results:
Sync error reported. Doesn't look good.
Test 2:
Drive settings:
Results:
Read error then sync error. Canceled due to slowness. Nothing new
Test 3:
Drive settings:
Results:
Same as Test 2
Test 4:
Drive settings:
Results:
Sync error reported
Conclusion:
Well, it seems that the newest beta still breaks EAC's -usefua command. I'm going to post this test in the forum, maybe they can do something to address this issue. I'm kinda curious what in SPTD causes this to happen..
Everyone having problems with SPTD and EAC's -usefua command, I need them to register to the SPTD forum (located here) and post in the 1.47 Public Beta forum that SPTD is breaking -usefua for you. Post your system specs, what kind of drive you have, what adapter and position (I don't know if that's correct terminology) your drive is located on, if you use microsoft's controller drivers or vendor specific... I think we can get this bug worked out if enough of us post that we're having issues.
I'm still using the old Daemon Tools 3.47 because I know it works with EAC -usefua on my Plextor drive.  I think the latest Daemon Tools is using SPTD version 1.53.  Does anyone know if they fixed the -usefua problem yet?  Is it safe to use the latest Daemon Tools Lite now?
-Robert
The issue with -usefua should have been fixed as of SPTD 1.49.
Can you confirm that?  Yah, I could try it myself, but I hate tinkering with a working PC.
Robert
