Topic: Columns UI:Custom Buttons & Currently Highlighted? (Read 1662 times) previous topic - next topic
  • db78
Hmm it says Columns UI, but I'm actually using Panels UI. Anyways, I'm adding some buttons to my layout, and one of them is to open the properties dialog and delete file. The commands working out great, but is there a way to apply those commands to the file that's being selected rather than being played?
Edit: I can't get the buttons panel to work, so I have to code it into the layout. Is there some component for this?
  • Last Edit: 04 May, 2007, 06:34:40 PM by db78
  • buktore
when you change your button command. select "Current playlist selection" in "Item group" box.
  • db78
I can't get the button panels to work right, so I'm just adding it in through editing the layout.
