Topic: Critique my Foobar2000 and PatchMixDSP settings please :) (Read 1773 times) previous topic - next topic
  • isamu
Hi guys
Well I just got my E-MU 1616M laptop card today and have just downloaded Foobar2000 for the first time. I want to get true ASIO sound but know almost nothing about how to go about doing it. But, I have read some things and after a few minutes have experimented with both the PatchmixDSP and Foobar2000 software. I would like you to critique my setup for Foobar2000 and PatchMixDSP software to see if I am doing this right. I THINK I got ASIO now but I'm not sure.
My setup is as follows:
Using a 1616M with PatchmixDSP software. Running a set of Sony 7506 cans directly from the card's headphone/line-out jack.
FOOBAR2000 settings is as follows:
Playback-->DSP Manager-->
Equalizer(all parameters are flat at the moment)
Resampler(PPHS) Target sample rate = 44100Hz UltraMode box is ticked(should I use this or not?). Please tell me what I should change here.
Advance Limiter
Winamp DSP Bridge using the DFX Plugin - I gotta say this is FANASTIC!!
Output:
Output Device: E-MU ASIO, Buffer length 1000ms, Dither box ticked.
ASIO Virtual Devices: E-MU ASIO
In the virtual device editior under "Channel Map" I have it set as follows:
AUX1          32Bit          Left
AUX1          32Bit          Right
AUX2          32Bit          Left
AUX2          32Bit          Right
Back to the PatchmixDSP software....in the GUI, in the four little insert channel boxes, I have them set to "Insert Send(Output to ASIO/WAVE or Physical Out)" Is this the correct setting to get the EMU1616M to deliver ASIO out? There is also "Insert Direct Monitor"....but I get NO sound whatsoever when selecting this option.
Please tell me what I should change as far as Foobar is concerned. Should I increase the target sample rate in the PPHS Resampler to 96Hz? Should I even use the PPHS resampler at all? Or swap it out for the SSRC resampler plugin?
I have NO idea if the settings above means I am currently getting true ASIO output directly from my E-MU1616M or so please tell me if I am and if there's a better setting out there than this. I really want to maximize this software along with Foobar2000. I *think* I'm hearing ASIO because the music  sounds OUT OF THIS WORLD! And DFX just makes it sparkle that much more!
  • TREX6662k6
OH god.
You should really read up on the options you select. For example resampling to 44100Hz isn't gona do you any good.
