Topic: foo_spdif - SPDIF support for foobar (Read 112804 times) previous topic - next topic
  • newanti
Reply #100
Hi. I can't  access to http://ga.cba.pl/ for some reason. Can anyone send foo_spdifer.dll to my mail newanti@yandex.ru or share it somewhere?
Reply #101
Hello I can't load this foo_spdif and when I turning on my foobar with this addon it shows me this note: Failed to load DLL: foo_spdif.dll
Reason: Not a valid Win32 application.
And I don't know what to do with this, can anyone help mee?
  • Last Edit: 23 June, 2012, 09:51:48 AM by westuaragorn
  • lvqcl
Reply #102
Reply #103
Redownload foo_spdif here: http://web.archive.org/web/20100512160004/.../www.ga.cba.pl/
Thnaks this works ofr me. But i thought that this plugin will work with mp3 too on foobar, and why version don't work with my win xp?
And there is only this plugin for coaxial spdif or is there another stuff?
  • Last Edit: 23 June, 2012, 10:21:50 AM by westuaragorn
  • lvqcl
Reply #104
This plugin is needed for bitstreaming of DTS and AC3, and is useless for MP3 files.
Reply #105
Is there anything which can be used with mp3? Or I just have to rely on my speakers decoder( I have logitech z 5500) ?
  • newanti
Reply #106
Reply #107
where can i found foo_ousKS ? Can anyone help me? because even google  didn't found it
  • Brazil2
Reply #108
I guess you're talking about foo_out_ks, Kernel Streaming support component, so here it is:
http://www.foobar2000.org/components/view/foo_out_ks
Reply #109
  • Lurker
Reply #110
Can somebody share a copy of the latest foo_spdifer.dll?
  • newanti
Reply #111
  • Lurker
Reply #112
U can get it here http://liveweb.archive.org/http://www.ga.c...l/spdif_w7.html
Thank you! I've read it worked for somebody under WinXP SP3, but for me it does not work, while the old foo_spdif.dll works correctly.
  • Lurker
Reply #113
OK, played around, and realized that the new spdifer is like "direct PCM mode" in other similar output plug-ins: it does not requests S/PDIF mode from the sound card. For me, it finally works via ASIO output.
But both foo_spdif and foo_spdifer miss gapless playback! Also, the both miss playback of compressed (flac, ape) DTS files.
For me, direct streaming via ASIO to the sound card connected via coaxial or optical cable to the sound processor works without any plugins, finally. Though it would be good to have a plug-in like foo_spdif, but which provides gapless playback, at least.
  • Ptijohn
Reply #114
I'm trying to use spdifer on windows 7 pro (64 bits), with wasapi and realtek onboard chipset.
However, after installing the dll, every time i reboot foobar, it crashes after a few seconds... (without starting any song)
Moreover, if i am lucky enough to launch a DTS file, the sound that i get is just a sizzling (is that how you say it in English ?), so nothing good.. And foobar crashes anyway just after that...
I was running foobar v1.1.10 (not working), so i tried v1.2.6 but the result wasn't better.
Any idea of what i'm doing wrong ? I disabled the inbuilt dts component of foobar, but i'm not sure what components i should also disable :/ (no DSP is activated, default in foobar)
PS : The passthrough is working well with MPC-HC (with LAV Filters), but it would be great to have it working with foobar.
Thanks in advance !
  • Ptijohn
Reply #115
Nevermind, WASAPI was just badly installed... It wouldn't load correctly at first.
It's now working like a charm ! Thanks a lot for your work !
  • Sandrine
Reply #116
foobar 1.2.7, dts pass-through not working for me despite foo_spdifer 1.0. Anyone else had more luck?
