Topic: Converting 24-bit FLAC files to 16-bit (Read 2552 times) previous topic - next topic
  • Doug N
I have a live audio disk that contains 24-bit FLAC files.  That's fine if I want to play the files on my PC, but how do I convert 24-bit to 16-bit in order to burn to a CD?
I tried to use Foobar, by unclicking "Keep lossless sources at original bit depth", and verified that my "Preferred Bit Depth" is 16.  I then tried to burn the .wav files to a CD, but it didn't work for me.
I get these sorts of errors:
"found sampling rate 48000, require 44100"
"Header of audio file "X.wav" is corrupted"
I apologize in advance if this has been asked and answered many times, I searched around for 20 minutes or so, and came up with no answer.  I'm 100% clueless about bit-rate though, so that might have hindered my chances of success.
  • Seiitsu
  • saratoga
Assuming you have nero, you should just use foobar's burn CD function.  It will handle resampling for you.
  • Doug N
I'm starting to regret the decision to go with Roxio, although it was pre-loaded on my external burner, so I didn't have that much of a choice.  Nero seems to be mentioned favorably quite often.
