Topic: Playlist_bind REALLY slow? (Read 4914 times) previous topic - next topic
  • db78
Is it just me, or is playlist_bind taking forever to rescan your music folder? I have about 8500 songs in my folder, and it take's forever to scan the folder. I think the problem is that instead of just scanning for any new additions or anything that was deleted, it rescans every file. It takes a good 3 or 4 minutes to finish. It's not a big deal but kind of a pain when you only add a few songs to the playlist, but have to wait for the playlist to be updated.
  • Last Edit: 19 April, 2007, 08:52:10 AM by db78
  • slinger1182
That may be true but what you can do is use Foobar's file moving capabilities to add files to your music folder. That would automatically get added to your Albumlist and you wouldn't have to use playlist_bind at all.
  • db78
o_O
What file moving capabilities?
  • buktore
right click at items > file operations > move,rename or copy files
try understand it. and you will love it.
  • db78
Hmm could you give me some insight on understanding it? I looked at it for a while today and I didn't understand what its supposed to do at all
it rename files, create dirrectories, and move files to them... quite sexy for some thing but imho absolutly not for you. for playlist bind just binds playlists to directories and file opperations are for catalogizing and others stuf... but it depends on what you use playlist bind for. i for example like to have complete playlist of two of my dirrectories which can be actualized with just one click... dont know how can file operrations help me with that
  • slinger1182
Yeah, I kind of agree cartman. If you are using playlist bind as an alternative to media library which i gathered from your first post, then File Operations is a good idea.
For example: I sometimes rip Pandora streams to see if I really like the songs enough to buy a CD so I use playlist bind those songs in a playlist. But If I'm adding songs to my media library, I use file operations so that I dont have to rescan my entire library again.
  • db78
Well I tried using it today, and I kind of got the idea. I moved a music file from my desktop to my music folder, renamed it to what I want to. The only problem was that I had to play the file in a separate playlist first. Then when I looked at my playlist with all my songs, the file that I added wasn't there, but it was in another playlist that I use to see which songs I recently added to my library.
  • $char(9836)
You need to have the playlist that is supposed to show all music as a autoplaylist that shows up all music in the library.
I just like listening to music
  • db78
Hmmm, sounds interesting enough. I did what you said, and something weird happened. When I used playlist bind, the playlist showed up with 9016 songs. When I used autoplaylist (query =  1), the playlist had 9020 songs? o_O
  • $char(9836)
Well you must have 4 songs in the ML that isn't from your music folder check the preference to see if the ML is queuing a extra map
  • db78
Nope, the only folder set under my ML is my music folder, and playlist bind is binding the same music folder. o_O
