Topic: TAK support for OggdropXPd (Read 9732 times) previous topic - next topic
  • gottkaiser
Hello,
I love using OggdropXPd with FLAC. And now the TAK SDK is out.
So I thought maybe it is possible create a TAK Plugin for OggdropXPd or an extra compile?
I'm sure, a lot of user would like to have an easy way to transcode from lossless TAK to the lossy OGG.
Not quite sure if it's possible. Maybe you know?
Thanks in Advance!
  • TBeck
  • Developer
Unfortunately i don't know OggdropXPd, but if it's an windows application and only TAK-decoding functionality is needed for your purpose, the TAK library should provide anything needed.
  Thomas
  • gaekwad2
Yes and (mostly*) yes.
It's a drag-and-drop Vorbis encoder.
*also tag reading, so unicode tags (written with eg. foobar) might be a problem
  • Last Edit: 13 April, 2007, 05:28:46 AM by gaekwad2
  • rjamorim
Well, OggDropXPd is GPL, and the TAK library is not (yet) GPL-compatible.
Then again, Monkey's Audio, LPAC and OptimFrog are supported in OggDrop, and none of these is GPL compatible either.
So, ummmm...
http://www.rarewares.org
  • TBeck
  • Developer
The TAK SDK provides functions for reading APEv2 tags.
  • IrfCore
So now four years later, is there any TAK support for OggDrop?
  • Cantrip
As a previous user of OggDrop, I also was looking for a similar solution since switching to Tak for lossless storage.
I found LameXP 3.18 to directly convert Tak to Aac for Iphone listening with one-click.  It does not have a drop pad, but is very easy to use.
You can download LameXP 3.18 hotfix2 here:
http://forum.ru-board.com/topic.cgi?forum=...700&start=8
Sadly LameXP discontinued support for Tak with version 4.0 (which has the cool drop pad mode I was originally looking for) due to lack of Unicode support (whatever that is).  LameXP 3.18 is the lastest version with Tak support.
  • DonP
  • Members (Donating)
Short description is extended alphabet to support many languages.
  • Cantrip
Thanks for the simple explaination Don.
I just noticed the following...
Features of TAK DirectShow Source Filter:
- Playback TAK audio files in any DirectShow Player (Windows Media Player, MediaPlayerClassic, …)
- Now supporting TAK 2.2.0 (multi-channel audio, …)
- Support UNICODE filenames and Sample Rates > 44.1 KHz
- Now correctly works in Windows 7 64bit ! (and other 64bit Windows versions)
Perhaps MuldeR can now add TAK support to the latest LameXP.  Then TAK would have the simple drop pad convertor, and also an easy GUI for direct Apple AAC conversion (I have been using Nero AAC).
  • CoRoNe
All of that no problem for the DC-Bass Source Mod as well.
