Topic: foo_input_reverse (Read 13712 times) previous topic - next topic
foo_input_reverse
* read my component requirements in my blog before reporting it doesn't work *
current version: 0.1.3
allows you to play music reversed, only support files that have a fixed time duration.
add a file location in the menu item (CTRL+U), then enter the way like mslive: rev://|c:\1.mp3|/
you can do it nested, but will double the resource needed:
rev://|rev://|c:\1.mp3|/|/
have fun.
change log
0.1.3
- added a context menu item for handy reverse playback
0.1.2
- fixed crashing when tag to a reversed item
0.1.1
- added option in input preference, you can specified the threshold to decide if to decode to memory or temp disk file
foo_input_reverse
Thank you as always. This component is fun. Anyway about your foobar components on your blog. I think listing two VC8 runtimes is unnecessary. Your older and newer components should run ok on VC8 SP1 runtime anyway. Even when you install both runtime only the VC8 SP1 runtime will be used.
foo_input_reverse
thanks for pointing out, I didn't think about it.
foo_input_reverse
Haven't tested it as I don't need it, but: IMO you should put it into dsp_soundtouch.
foo_input_reverse
it can't be done in a dsp properly, or do some unnecessary process. (eg. seeking problem)
foo_input_reverse
Just tried out that little toy - and it works
Tested with the song "Untitled #5" by John Frusicante from "Niandra Lades..." since the piano in the original song was just reversed
foo_input_reverse
foobar crashes when I try to edit tags on reversed playlist item.
foo_input_reverse
fixed now.
foo_input_reverse
Bug: If you have a few reversed songs in a row on a playlist or you repeatedly use the 'Reverse and Play' context option, each time a reversed song plays it increasingly adds onto foobar's memory usage until you play a normal song.
Also, it would be nice to have just a 'Reverse' context option that just adds the reverse tags to the playlist item so you can cue several reversed songs in a playlist without playing them.
Thanks for this... Its pretty cool.
foo_input_reverse
I don't see the bug, tried to play a few reversed files in a row, no memory leaks.
I'll add it later, just didn't want to add.
foo_input_reverse
I have found this  cool plugin searching with Google:
http://wiki.hydrogenaudio.org/index.php?ti...nput_reverse%29
but the links to download the required DLL components:
VC8 sp1 runtime libraries and libmmd.dll  are missing (404 not found)
Someone knows if there exists an alternative link to download them ?
foo_input_reverse
there is no support given to banned components.
foo_input_reverse
Ah, excuse me, I had not noticed that this is a banned component
foo_input_reverse
I wouldnt trust any of the developer's components, to be honest.
Especially when most of them violate the SDK rules.
foo_input_reverse
Not all of Acropolis' components are banned. For example, Gapless Crossfader isn't.
About missing dlls: http://www.rarewares.org/others.php#libmmd
And you can download VC8 (aka MSVS2005) redistributable from microsoft.com
foo_input_reverse
@lvqcl,,
thanks for the links to missing DLL, but,  if I understand it, the component  I'm interested in - foo_input_reverse - is a banned component, I prefere to no install it  :-(
I continue to use sox to reverse  audio.
Thanks again
Sandro
foo_input_reverse
Well, I found very annoying behavior of Autoplaylists... If you create ANY autoplaylist, this component will won't work there. Because Autoplaylist content can not be altered in any way... I took me about 1,5 hour to manually remove and restore all my input plugins in various configurations, to delete and restore my DSP chains... when removing input plugins didn't help I started removing other non essential components. And when I removed foo_albumlist, everything started working fine. Because after that my playlists became regular playlists, not monitored ones. Restoring Album List component caused that Reverse component stopped working on my main playlists which are all Autoplaylists. I tried it on additional, normal playlist and there it worked without problems...
foo_input_reverse
The context menu command extends the path of each file with 'rev://|file://' which serves as the trigger for the actual effect, so that's sort of expected.
