I'd like to exclude sample10 bibilolo and 13 aquatisme and change the length of sample 1 (43sec).
IMHO those samples are interesting because they seem to be hard to encode. Why removing them?
In the 48 kbps test I spent a lot more time with bibilolo than with any other sample. The bibilolo files were obviously very bad, so hearing various problems was not a problem. The problem was to rate the contenders fairly. On each listening time different problems seemed to be more annoying.
After spending an hour or so with bibilolo I ended up with this judgement:
ABC/HR for Java, Version 0.52b, December 07, 2006
Testname: Sample10: bibilolo
Tester: Alex B
1R = Sample10\Sample10_3.wav
2L = Sample10\Sample10_4.wav
3L = Sample10\Sample10_1.wav
4L = Sample10\Sample10_6.wav
5R = Sample10\Sample10_5.wav
6L = Sample10\Sample10_2.wav
Ratings on a scale from 1.0 to 5.0
General Comments:
1R File: Sample10\Sample10_3.wav (WMA Std)
1R Rating: 1.8
1R Comment: heavily low passed, but less distorded than #2
2L File: Sample10\Sample10_4.wav (WMA Pro)
2L Rating: 1.5
2L Comment: highs have bad distortion
3L File: Sample10\Sample10_1.wav (Vorbis)
3L Rating: 2.5
3L Comment: preecho, lowpass
4L File: Sample10\Sample10_6.wav (low anchor)
4L Rating: 1.0
4L Comment: most of the sample is missing because of the lowpass
5R File: Sample10\Sample10_5.wav (high anchor)
5R Rating: 3.5
5R Comment:
6L File: Sample10\Sample10_2.wav (Nero HE-AAC)
6L Rating: 2.1
6L Comment: Not so lowpassed, but the highest frequencies are "wrong" HE-AAC?
ABX Results:
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--](I added the encoder names.)[/size]
However, I am not sure if I could repeatably end up with the same results.
Aquatisme was a killer sample too. There was no doubt about the huge amount of problems. In addition it was even more difficult to rate. I really couldn't put the contenders in any order. After trying for a little while I decided to pass the sample and move on.
