Topic: What do these FLAC Errors mean (Read 5288 times) previous topic - next topic
I am re-encoding about 750 GB worth of FLAC files from 1.1.2 & 1.1.3 (-5 or -6) to 1.1.4 (-8).  The files are contained on three 250 GB hard drives and one 300 GB hard drive; each hard drive is between 65 - 75% full.  I have finished re-encoding 2 complete hard drives and am working on the last two.  I am having difficulty with the FLAC files on the 300 GB hard drive.  It seems that at least one song is corrupted on every album.  I have checked the hard drive for errors and found none.  I have checked for ID3v1 and ID3v2 tags and found none.  The files were ripped using EAC and then encoded to FLAC via EAC.
I keep getting the following errors:
Checking: "G:\Music\Iggy & The Stooges\1973 - Raw Power"
Verifying: "G:\Music\Iggy & The Stooges\1973 - Raw Power\Iggy & The Stooges-Raw
Power-03-Your Pretty Face Is Going To Hell.flac"
________________________________________________________________________
flac 1.1.4, Copyright (C) 2000,2001,2002,2003,2004,2005,2006,2007  Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
Iggy & The Stooges-Raw Power-03-Your Pretty Face Is Going To Hell.flac: testing,
43% completeIggy & The Stooges-Raw Power-03-Your Pretty Face Is Going To Hell.f
lac: *** Got error code 3:FLAC__STREAM_DECODER_ERROR_STATUS_UNPARSEABLE_STREAM
Iggy & The Stooges-Raw Power-03-Your Pretty Face Is Going To Hell.flac: *** Got
error code 0:FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
Iggy & The Stooges-Raw Power-03-Your Pretty Face Is Going To Hell.flac: ERROR wh
ile decoding data
        state =
FLAC__STREAM_DECODER_READ_FRAME
The FLAC stream may have been created by a more advanced encoder.  Try
  metaflac --show-vendor-tag Iggy & The Stooges-Raw Power-03-Your Pretty Face Is
Going To Hell.flac
If the version number is greater than 1.1.4, this decoder is probably
not able to decode the file.  If the version number is not, the file
may be corrupted, or you may have found a bug.  In this case please
submit a bug report to
    http://sourceforge.net/bugs/?func=addbug&group_id=13478
Make sure to use the "Monitor" feature to monitor the bug status.
File failed verification [ERR#1]...
Power-07-Shake Appeal.flac"
Iggy & The Stooges-Raw Power-07-Shake Appeal.flac: testing, 76% completeIggy & T
he Stooges-Raw Power-07-Shake Appeal.flac: *** Got error code 3:FLAC__STREAM_DEC
Iggy & The Stooges-Raw Power-07-Shake Appeal.flac: *** Got error code 0:FLAC__ST
Iggy & The Stooges-Raw Power-07-Shake Appeal.flac: ERROR while decoding data
                                                   state = FLAC__STREAM_DECODER_
READ_FRAME
  metaflac --show-vendor-tag Iggy & The Stooges-Raw Power-07-Shake Appeal.flac
Power-08-Death Trip.flac"
Iggy & The Stooges-Raw Power-08-Death Trip.flac: testing, 18% completeIggy & The
Stooges-Raw Power-08-Death Trip.flac: *** Got error code 0:FLAC__STREAM_DECODER
Iggy & The Stooges-Raw Power-08-Death Trip.flac: *** Got error code 2:FLAC__STRE
AM_DECODER_ERROR_STATUS_FRAME_CRC_MISMATCH
Iggy & The Stooges-Raw Power-08-Death Trip.flac: ERROR while decoding data
                                                 state = FLAC__STREAM_DECODER_SE
ARCH_FOR_FRAME_SYNC
3 file(s) verified.
3 file(s) returned an error.
Files that failed verification:
  "G:\Music\Iggy & The Stooges\1973 - Raw Power\Iggy & The Stooges-Raw Power-03-
  "G:\Music\Iggy & The Stooges\1973 - Raw Power\Iggy & The Stooges-Raw Power-07-
Shake Appeal.flac"
  "G:\Music\Iggy & The Stooges\1973 - Raw Power\Iggy & The Stooges-Raw Power-08-
Death Trip.flac"
Press any key to exit
What are these errors?  Is there any way to fix them without having to find each CD and rerip it?  I still have the CDs; however, they are just not organized very well and finding them all is sort of a pain.
My OS is Window XP PRO SP2 and the cpu is AMD Athlon 1.16 Ghz with 768 MB of RAM.
Please let me know if you need any additional information to help solve my problem.
Anyone have any thoughts on this?
John
if the errors are in the middle, the files were probably corrupted at some point in time.  if you could host one of them I can take a look.
Josh
I got the file.  it looks like a few bad sectors occur near the middle.
you can use -F to force through decode errors.  there may be dropouts or silence for the damaged frames.
Josh
Thanks! I will just re-rip and start over.  Any idea what could have caused the corruption?  My HD tested fine.
John
The most probable cause is faulty hardware.
- check your ribbon IDE cables for damages
- check HDD for overheating
- check memory for errors http://www.memtest.org/
- perform advanced HDD diagnostics (chkdsk /r; with manufacturer's utility; with mhdd)
Everything tested fine.
I think maybe my media server (Firefly) was causing some corruption.  I am still checking this idea out.
John
John
What filesystem are you using on the drives, NTFS or FAT32? The latter is a lot less robust and could be the problem if you're using it. NTFS very rarely messes up on its own.
Also, check your security or backup software, if you use any. Reason being that I've had F-Secure Internet Security literally wipe out some files on my PC (they were not infected and F-Secure reported no malware). In another episode, Norton Ghost 10 nuked my WMP library database and the settings on several other programs I use regularly.
Another thought: if you're running a 3rd party defrag or some other system maintenance tool, that could also be a problem... Basically look at any software that's likely to be accessing your filesystem at a low level.
Let us know how it's going.
I know that it's time consuming, but you should use Quickpar or ICE-EEC to protect your data in future.
