Topic: freedb Problems (Read 21131 times) previous topic - next topic
  • broodwich
freedb Problems
At some point yesterday freedb just stopped working. I have been trying to get it to work or to find alternatives ever since and I had no luck. EAC reports "Error - cannot connect to host" or "Error - Server Error" or "HTTP Protocol Failure" after searching for 30 seconds or so. I have the URL for the server set to "http://freedb.freedb.org:80/~cddb/cddb.cgi" I am running Vista 32bit and I was not having any trouble until some point yesterday. Are the freedb servers down?
  • Last Edit: 16 February, 2007, 01:48:14 PM by broodwich
  • psycho
freedb Problems
Why don't you try another freedb server, like some localised one.
Here's the link to Austrian freedb server: http://at.freedb.org:80/~cddb/cddb.cgi
lame -V 0
  • broodwich
freedb Problems
I couldn't find a list of fredb mirrors. Is there one? The freedb site just says it's random. I tried using the URL you posted and I still got a Server Error message.
  • psycho
freedb Problems
EAC already has all the mirrors to select from. Just go to EAC -> freedb options -> freedb server drop down menu. I just tried the Austrian mirror, it works for me... Maybe you have some kind of connection problems... maybe your EAC can't access the net because of your firewall or smth.
lame -V 0
  • broodwich
freedb Problems
For some reason my EAC did not have a list of mirrors. I uninstalled EAC and reinstalled and now I have a list of mirrors but I still get the server error message. I tried some of the other servers and I got the same error. I checked Windows Firewall and added EAC to the list of exceptions but that didn't make any difference. EAC was working with freedb before without any modifications to Windows Firewall. My Internet access seems to be fine I'm not having an trouble getting out to the web.
  • psycho
freedb Problems
That's interresting, broodwich... sorry I can't help you.
lame -V 0
  • broodwich
freedb Problems
Thanks anyway, perhaps somone else will have some ideas. I tested EAC on my other computer which is running XP and I get the same problem, "Server Error". I reset my hardware router as well, that did not help either.
  • broodwich
freedb Problems
At Last! I'm back in business. I just fired up Foobar2000 on my machine and asked it to get the tags for an audio cd that I had inserted and it went out to freedb right away. So that gave me a clue that something was wrong or different in EAC. I was poking around in Foobar trying to figure out if there was a way to export the ID3 tags from it so that I could impiort them into EAC. I didn't figure that out but I did find the Console command in the Foobar menu. The console listed the commands and communication sent to freedb to query the tag information for my CD. I noticed that Foobar was using a differnt URL so I copied that url...
http://freedb2.org:80/~cddb/cddb.cgi
and pasted it into EAC and now things are working again!
  • rockdog
freedb Problems
I was having the same issue last night and this morning.  When I get home from work I will try the new URL you posted.
  • broodwich
freedb Problems
I hope it works for you and I hope it continues to work for me. I have ripped three CDs so far with the new settings and it's still working. It also seems much faster at getting the names from freedb than it ever was before.
Edit: I just found this post about freedb2... looks like it's old news.
http://www.hydrogenaudio.org/forums/index....showtopic=46184
  • Last Edit: 16 February, 2007, 03:56:59 PM by broodwich
  • bhoar
  • Members (Donating)
freedb Problems
On thursday of last week, I had a lot of trouble with lookups to freedb.org.  Some other folks corroborated that.
Didn't try Fri/Sat, but if thursday was bad, maybe the server problems continue?
-brendan
Hacking CD Robots & Autoloaders: http://hyperdiscs.pbwiki.com/
freedb Problems
Bad news...
Well here it is November and I'm having the exact same issues with freedb.org too. freebd2.org worked once I sent EAC over there
Goodnews...
Vista x64's DRM doesn't affect EAC rips
  • Last Edit: 20 November, 2007, 12:02:24 AM by audioaficionado
  • greynol
  • Global Moderator
freedb Problems
You guys do try mirrors when the main site goes down, right?  I usually don't have a problem with the original site, but occasionally it's down.  HA is occasionally unavailable from time to time also; this stuff just happens.
at.freedb.org
au.freedb.org
bg.freedb.org
ca.freedb.org
es.freedb.org
fi.freedb.org
lu.freedb.org
no.freedb.org
uk.freedb.org
us.freedb.org
  • SamHain86
freedb Problems
I can't access the FreeDB server through EAC. I can access it through FB2K, I can ping the servers and it works. I have scrolled through all the mirrors and no dice in EAC... what is going on?
UPDATE: I just tried a complete reinstall of EAC and REACT... no dice.
  • Last Edit: 06 December, 2007, 02:15:38 PM by SamHain86
OP can't edit initial post when a solution is determined  :'-(
  • bilbo
freedb Problems
Try this:
EAC forum mentioned there was a change in the site. It worked for me>
Glass half full!
  • greynol
  • Global Moderator
freedb Problems
This happens from time to time and I am experiencing it as well (EDIT: though it worked fine yesterday).
Try again later or try freedb2.
The funny thing I never mentioned with my previous reply was that HA became unavailable just after I had posted it.
  • Last Edit: 06 December, 2007, 02:34:57 PM by greynol
  • SamHain86
freedb Problems
@ Bilbo:
Fantastic! Worked like a charm!
@ Greynol:
Thanks for the reply. When it comes to technical advice you are one of the few on this forum I always look for first. So when you come out and say, "Yep it doesn't work for me either," I feel confident that I am not loosing my mind. Try Bilbo's suggestion, it worked for me.
Thanks again for the swift reply.
  • greynol
  • Global Moderator
freedb Problems
I did and it worked, though I don't like the fact that with freedb2 EAC bugs you to choose what version you want when there's only one available.  Well, it did suggest that the information was inexact, so maybe the Disc ID was slightly off or inverted.
Thanks for the kind words.
Has anyone tried http://freedb.musicbrainz.org:80/~cddb/cddb.cgi?
  • Last Edit: 06 December, 2007, 02:44:38 PM by greynol
  • phaedra
freedb Problems
I had the same problem (never had it before, haven't changed my config in almost a year). Tried bilbo's tip and it worked for me too. Thank you bilbo.
- p
  • phaedra
freedb Problems
I can't try it until tonight. What is the difference between this and freedb2? Is one better than the other?
Thanks,
- p
  • greynol
  • Global Moderator
freedb Problems
They are just different databases and each database is only as good as the entries people submit.
When it comes to using them with EAC I wouldn't say either was better than the other.
  • Last Edit: 06 December, 2007, 04:02:59 PM by greynol
  • phaedra
freedb Problems
  • odyssey
freedb Problems
Greynol: I had the same problems (seems to be a DNS problem), but NONE of the (at least builtin EAC) mirrors worked!
  • greynol
  • Global Moderator
freedb Problems
As I just posted to Digital-Inn, both freedb2 and musicbrainz are working for me, while freedb still is not.
  • Last Edit: 06 December, 2007, 08:47:22 PM by greynol
  • greynol
  • Global Moderator
freedb Problems
http://us.freedb.org:80/~cddb/cddb.cgi is currently working.
This happens from time to time and I am experiencing it as well.
Don't say I didn't tell you so!
  • Last Edit: 07 December, 2007, 03:27:33 PM by greynol
